Question about HP Pavilion dv9000z Notebook
MY WIRELESS SWITCH WILL NOT STAY ON- SWITCHES OFF AFTER 2 SECOND
AS ABOVE
    Problem Solver:
  • 18 Answers
Check the light of the WLAN on the Noteboot. Does it go off or Oragne? Check the drivers in Device Manager for the Wireless Driver. Update the Bios from hp.com and Reinstall the Driver for Wireless. The Light Should Stay on.
Regards
Naveen
Posted on Oct 11, 2009
How to wire dual switch
Plug a ethernet cable from any port on the first switch to any port on the second switch. Thats pretty much it. If it's a managed switch then it's dependent of how you have the managed switch configured. Managed switches typically cost several hundred to several thousand dollars so if your just running cheap switches then the above applies.
Dec 09, 2011 | Computers & Internet
I AM REPLACING THE HEADER IN H250FDN HEATER. NEW HEADER INSTRUCTIONS MATCH OLD HEADER AND NUMBERS MATCH ON OLD AND NEW BUT NEW HEADER IS DIFFERENT. OLD HEADER HAS 2 LIMIT ON BOTTOM NEW ONE HAS 1 ON BOTTOM...
As long as it still has 2 hi limit switches, this will be easy.
You will need one wire going from one limit switch to the other. (on any terminal)
take either of the incoming wires from the old limit wiring and connect to second terminal on either limit switch.
Now take the last remaining wire and connect ot to the last terminal on the second limit switch.
Basically, you are just creating a bridge. Power will go into first limit switch, then go into the second limit switch via the first wire indicated above. Then the power will go back out to the pc board. If a high limit switch trips, then power is cut off (cicuit opens) and it tells the cpu there is a problem and shuts down the heater.
So to simplify: connect the wire in between the two limit switches. Then put the other 2 wires anywhere.
May 04, 2011 | Hayward 250fdn Low Nox Nat Gas Swimming...
Just hooked up the KVM cable and when I switch to the second computer, the mouse and keyboard do not work. Can someone help me with this?
Sounds like there's a bad connection on the second computer, may just have to plug another mouse/keyboard in.
(I sometimes use a wireless usb keyboard/mouse combo)
Jul 03, 2010 | IOGear GCS632U 2-port KVM Switch
We have just installed 2 x new HP KVM switches (main port 16 connects to A port on secondary switch) with HP TFT7600 rack mount monitor and keyboard. Issue is we cannot connect to Servers on secondary...
Try swapping the switches over, your second switch box may be faulty.
You could also check the ips to make sure u have no conflicts.
post back what you find. thanks
Jan 19, 2010 | HP (AF600A) KVM Switch
I currently have just a bathroom vent with no light. I want to install a vent with a light also. assuming the wiring is just 14/2 to the current switch, can I install the vent with the light using the...
I would add a second switch. Jumper the present black wire to feed both switches and then use 14-3 to go to the light with black wire and the fan with the red wire. You can get the double switches in a type that will fir in asingle box. They are the double switches that are one above the other where the levers are horizontal. hope this helps you. Jeepfxr
Dec 09, 2009 | Broan-NuTone FAN CONTROL SWITCH
Wireless switch
Here is all I know about Compaq Presario wireless switches. Sorry, but w/o a model I can't be more specific.
Compaq Presario, Model not specified - Button on the Back
C304NR - Button on upper right above keyboard deck, Blue is enabled
CQ Series - Button above the keyboard (antenna icon on button) next to power.
** CQ50-107NR (Conflicting reports on this model show:
Button above keyboard (antenna icon on button) next to power or lighted button below space bar that turns the touch pad on/off.
M2000 - Button above the keyboard (antenna icon on button)
Dec 11, 2008 | Computers & Internet
Connectioning a second pc on another level in my home
hi
I think you will need one "Switch" (name of device - which is used to provide connections for more than 5 computers at a time)
So in the market there are variety of switches available like 5 port switch (for 5 computers) 8 port switch (for 8 computers) like wise.
So you need to purchase switch.
You can use alternate for switch is HUB (same as above)
So once you are done with that, let me know so that we can proceed further with configuration of you network (for 3 computers)
Sep 15, 2008 | Microsoft Windows XP Home Edition
Kvm switch won't stay on second computer, switches back
You might try disabling any power saving schemes in use on either computer. The KVM (I believe) gets its power through the ports and one computer may be shutting down power.
Aug 31, 2007 | Belkin F1DL102P 2-port KVM Switch
HP Pavilion dv9000z Notebook Logo
406 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
