Question about Samsung SyncMaster 2233BW 22" LCD Monitor
HDM1 BOX FLOATING
I have a HDMI box with three cloured squaire moving around mt screen. Check Signal Cable .Nothing on screen. Can you also respond to ryfsny@yebo.co.za
  • 63 Answers
This is telling you that you do not have a High Definition Mode source connected to teh screen.
Posted on Oct 03, 2009
I touched the wrong button on the remote and know tv says no signal and I can't get it back
Try going to your input button on your remote and see if you are still on the right input like if your tv is using a hdmi cable from your cable or satellite box then your input should be hdmi or hdmi 1 or hdmi 2 etc... also if you have cable or satellite make sure you didn't change the actual tv off of channel 3 or 4 whichever you have your cable or satellite box set on. I hope this helps.
Feb 06, 2016 | Televison & Video
Cable box is plugged into denon's hdm1, but I can't get a picture. Hdm1 out monitor (arc) is plugged to TV hdm1 in (arc).
Power up all components. Select the HDMI 1 input on the Denon amp, and the HDMI 1 input on the TV. Additionally, run the old analog cables between the cable box and the TV. If no picture, select the input on the TV that is associated with the analog input from the cable box. You should have a picture at this point - but it will be a standard definition type. Check the settings on the cable box to change the output from "A / V" to Digital on the HDMI jack - if present. You may have better luck unplugging power / replugging in the cable box first - or calling the cable company if you can't find settings for this. Once you have the output of the cable box to HDMI, select HDMI on the TV. If you still don't have it working - try bypassing the Denon and go directly into the TV from the cable box. Try it with BOTH HDMI cables. Also - try different inputs and out puts (HDMI 2, HDMI 3, etc.). Discard any HDMI cable that fails to show video and play audio.
May 04, 2015 | Audio Players & Recorders
Sreen blue, no signal floating across screen
Hello
Check all the signal cables at the backside of your Vizio for firmness. If there is any loose or bad cable connection, especialy with HDMI; will poise this problem. Check the input selection also. If improper input selection is done, there will be no signal logo will fly around.If you have selected TV instead of HDMI, when HDMI is connected and you want to see the programme, is an example of improper signal selection. Check these. OK.
May 12, 2011 | Vizio VO32L 32 in. LCD TV
The screen is black and a little box that says no signal is moving around on the screen
Check your inputs. The no signal box means exactly that - there's no incoming signal for the TV to decode. So you've either disconnected a cable somewhere or turned off your input device.
Try changing the inputs on the TV (this will be a button saying input or A/V)
Try changing the channels
Check that your cables are correctly connected and that whatever you are trying to use (dvd player, PS3, etc) is turned on.
Check that your TV is tuned to the corresponding input it is plugged in to (if you plugged your DVD player into HDMI input 8, tune your TV to input 8)
Hope this helps.
May 11, 2011 | Sanyo Televison & Video
The TV model is Sanyo DP32648. DVR Cable Box - Motorola DCT6412 III I have a DVR cable box connected via an HDMI cable to the TV's HDMI 1 slot. I have had the TV for around a year now and haven't had...
If you have the DVR connected to the TV with the Coaxial and the HDMI that is probably causing the problem I work for a Cable company and have dealt with this problem on numerous occasions. Try just disconnecting the Coaxial cable from the cable box that should fix this issue.
Dec 02, 2010 | Televison & Video
CABLE BOX HDDVR IT's NOT WORKING WITH HDM1 in put. I have to use av1 source with 3 wire cable. Comcast tech saying it is tv problem.
I am not with Comcast, but rather a much smaller family owned cable company.
You can check the user settings of the box to verify it is in the HDMI mode. Depending on what type of HDDVR you have that is.
For Motorola 62XX and 64XX models follow these steps to check.
1. make sure that your HDMI cable is connected to both the TV and the cable box.
2. Turn TV on, and verify it is on the proper input.
3. Turn cable box off.
4. Press menu button on remote or front of cable box.
5. A user settings menu will appear on the screen.
Note: if it did not appear you may have to connect another type of cables to continue.
6. Information displayed should be set to what your TV set is capable of. Most HDTV's will be set to the following:
16:9
1080i
480i
7. If you see additional HDMI settings as the forth item your TV and cable box are communicating across it, if not try unplugging both the TV and cable box and/or replacing the HDMI cable. Enter the additional settings by pressing the right arrow on the remote.
8. Change DVI to HDMI.
9. Press power to exit the user settings menu.
10. Turn cable box on, and switch TV to HDMI input if not already on it and see if the picture is coming in now.
Note: if you think that you messed up in the user settings you can always restore default settings by following steps 1 through 4 then press up arrow once and right arrow once.
I hope this helps you cable customers, as we appreciate your business unlike Dish and Direct!
Cheers!
Jun 18, 2010 | Philips 47PFL5704D 47 in. LCD TV
Why won't the HD channels come in on my lg flat screen monitor? We changed the cable box and everything. Any suggestions?
The first thing you need is the HD tuner. Since you stated that you changed the cable box I will assume that means it's HD ready.
So you have HD signal coming in to the cable box box by-way of a coaxial cable. Now you need to get that HD signal to the monitor. For this connection the standard coaxial cable normally used between the TV and cable box will not do the job. How many connection options you have depends entirely on the what is available on the monitor.
Normally there are three choices. Your monitor could have anyone of these, a combination of them or none if it's not HD ready.
They are Component cable, HDMI and DVI.
Component is a combination of three RCA type (red, blue, and green), connectors. Simply connect the "Component Out" from the cable box to the "Component In" on the monitor.
HDMI cable looks similar to a computer monitor cable but bigger. Same goes for this one. Connect the "HDMI Out" from the cable box to the "HDMI In" on the monitor.
An indirect connection can also be made if your monitor has a "DVI In" jack by using a cable that will allow you to come from the "Out" connection of either the HDMI or Component on the cable box to the "DVI In" on the monitor.
If you are unclear about anything or you have any other questions please just ask and I'll try and help out.
Oct 02, 2009 | LG Computers & Internet
On a Daytek 46 in LCD TV, no AV Digital Cable Signal, but HDMI OK
Had the same problem.
Fixed by unplugging everything from the power source, leaving for 2 minutes then plugging back in.
Works fine now.
Aug 11, 2009 | Dynex DX-LCD19-09 19 in. LCD TV
42" Sanyo HDTV with 3 HDMI Inputs
Everybody is having problems with sony products and HDMI cables. It's on a lot of forums. So, your not alone.
Most of the solutions are:
1. Unplug your TV for 30 mins.
2. Plug TV back in and put it on HDMI for PS3.
3. Hold down the power button for 10secs on the PS3
That should solve the problem.
Feb 17, 2009 | Sanyo DP42746 42 in. Plasma Television
No Signal HDMI
Had the problem. Turned out to be a defective hdmi port circuit board.
Aug 04, 2008 | Insignia 42" LCD Flat-Panel HDTV
Samsung SyncMaster 2233BW 22" LCD Monitor Logo
251 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
