Question about Canon PIXMA MP130 All-In-One InkJet Printer
Canon pixma mp130
I have similar problem. I tried to clean the cartridge golden contacts with a q-tip and some alcohol. Also tried to dip the print head cartridge in hot water (worked before...).
So far, no success.
  • motimil Oct 05, 2009
    Problem was solved !!!
    As mentioned, I used a q-tip with alcohol and carefully cleaned the golden contacts on the printer head and cartridge. Then I dipped the cartrige in a hot water bowl, leaned the drained ink with a papertowel , waited for 24 hours, and that's it !
1. Take out black and coloured ink cartridges.
2.Clean golden contacts with a q-tip dipped in alcohol'both on the print head and on the cartridge.
3. Dip the cartridge in a hot water bowl, let all the ink left flow out.
4. Wipe with a paper towel.
5. Let the parts dry out for at least 24 hours
Posted on Oct 05, 2009
Printer printing blank. New ink cartridges.Clean and Deep Clean utilities done.
Hello, first unplug the the printer and take out the cartridges, first dab them on a wet paper towel until the ink start flowing, then take a q-tip dipped in alcohol and where u insert the cartridges, clean the print heads, replace the cartridges and power up. If that doesn't help it you have bad cartridges.
Nov 28, 2015 | Canon PIXMA iP4300 InkJet Photo Printer
Service error 5100
Unplug for 30 seconds then replug, clean the cartridge's contacts, check and make sure the encoder strip is not out of place behind the carriage. Do a full cleaning of the print head manually:
(1) Open the printer
(2) Remove the ink cartridges from the print head.
(3) Use cotton swabs dipped in hot water to thoroughly clean the print head.
(4) Repeat this until there is no ink residue coming off on the cotton swab.
(5) Once finished, allow to dry and replace the cartridges
(6) Try to print something now
If none of that works, most likely you need a new print head.
Apr 30, 2013 | Canon PIXMA MP130 All-In-One InkJet...
My caanon pixma 130 has full ink cartridge but prints very light
You can try this steps..
cartridges out of the printer..take a small plastic container and boil some water then put just enough boiling water in the container to cover the bottom just a touch more then take the cartridge and dip it in and out of the hot water a few times and do the paper towel dip again. The hot water will break up any dry ink in the cartridge head.
If your cartridge has an electronic board on it use 99% isopropyl alcohol and a Q tip and apply it to the cartride board and don't use the tip use the side of the Q tip and apply a bit of pressure, not only will you clean the contacts but you will evaporate the water that got on the board then wait 5 minutes and try it in the printer.
If you need any technical help on printer then you can reach at..here
Dec 26, 2012 | Canon PIXMA MP130 All-In-One InkJet...
The orange light on pixma iP4300 is flashing 5 times. I have cleaned the printhead (gold contacts) with alcohol PJ
Use cotton swabs dipped in hot water or a mixture of hot water and isopropyl alcohol
Use it to clean the print head and the electronic contacts on each ink cartridge
Once done, allow to dry and try again
If the error still persists, you have a damaged print head which needs to be replaced with a new one
Hope this help!
Sep 06, 2011 | Canon PIXMA iP4300 InkJet Photo Printer
My Canon Pixma MP130 keeps giving me the 5100 error. Can't even complete the nozzle print test. The ink cartridges do not appear to be jammed as they move. What is the problem? Please help.
Turn off printer.
Remove both the cartridges from the printer. Use a clothe moistened with alcohol to clean the surface contact on the cartridges where the terminals inside the printers touches.
Return the cartridges and turn on the printer.
Error 5100 means that the cartridge can not be detected by the printer.
Hope it helps!
May 22, 2011 | Canon PIXMA MP130 All-In-One InkJet...
Canon pixma mp130 service error 5100 - won't print
Turn off printer.
Hope it helps!
Dec 17, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Canon Mx320 printing error 5200.How do I fix it?
Just remove the ink cartridge from the printer and clean the surface contact using a cotton moistened dipped in an alcohol .
Return back the cartridge and try to print again.
Try also to Press and Hold the STOP/RESET button until printer restart. Release the button when to completely initialize the printer
Aug 20, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Printer mp130
take the ink cradle out and take the cartridges out. clean the print head on cradle with alcohol, and you might wanna try blowing the ink residue out of the head becuase the black ink cartridge leaks
Jul 10, 2008 | Canon PIXMA MP130 All-In-One InkJet...
My printer says "cartridge jammed" and wont print! HELP!
Have you removed and replaced the cart with a new one? If that hasn't fixed it, you may be looking at goo in the cartridge area. You can often use a swab (Q Tip) soaked in alcohol to clean this up.
Jan 05, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Canon PIXMA MP130 All-In-One InkJet Printer Logo
145 people viewed this question
old marine
old marine
