Question about Cell Phones
I have a 1998 7 series with integrated phone & the phone shows "bad handset" on the display - any ideas?
  • Cell Phones Master
  • 19,396 Answers
Hi.
Did you already try disconnecting your BMW's battery for ten minutes, to reset the phone? The phone will synchronize back with the handset after re-connect. If it does not, then the handset is faulty. When you disconnect the battery ensure that you do not need an anti theft code for the car stereo afterward.
Regards.
G.
Posted on Oct 03, 2009
How do I leave a message for my answering machine
Ask the service provider
Panasonic KX-TG6531B Digital DECT 6.0 1X Handsets Dual
www.fixya.com/.../p3148769-panasonic_kx_tg6531b_digital_dect_6_0...
Recent Panasonic KX-TG6531B Digital DECT 6.0 1X Handsets Dual Voltage Cordless Phones Integrated Answering Machine 110-220 Volts questions, problems & answers. ... Model KX-TG4021 - How do I put in a new answering message? ... Why won't my answering machine, Panasonic Easa-Phone KX-T1460 allow the ...
change amount rings panasonic kx tg7643 Answering ...
Jan 12, 2016 | Panasonic KX-TG6531B Digital DECT 6.0 1X...
Tip
Nokia Asha 305 display light problem solution
With article and troubleshooting guide solution for Nokia Asha 305 display light problem solution Problem: No display lights, Dark display. Solution: Change LED, Change connector, Make jumper. phonetolls mobile repairing Nokia Asha 305 play light solution Article on this topic Thanks for checking out this Solution. Phonetolls.blogspot.com contents provide include dozens of cell phone artical additional, pictures, with hardware and software troubleshooting guides for you. Support us like and connect with this blogger for latest newsletter please follow me. By Admin shahid abbas. Troubleshooting guide Open display back panel carefully and change lights red marking here in this. Remember one thing to do this job, please be ensure that light controller integrated stage is working well then change or check LED (light emitting diode) on display. There are 4 LED with series you can check faulty LED with check meter. At connection with meter probe LED lights show us. There on light emitting diode(LED) Regulated voltage are equal to battery voltage- 4.2. There are series of LEDs if missing one LED then All series is damaged. Warning! During working on this trick if accidentally your handset may have dead or faulted we are not responsible for that please read our privacy policy., ,
on Jun 24, 2015 | Cell Phones
Hi, Bruce Kelly I have a Uniden DECT1480-3 That the screens on all hand set's say's SEARCHING. I can not get a dial tone so I am unable to make a call or recieve a call. Their is no dial tone and all of...
All of the handsets appear to have lost their
registration to the base and will need to
be first de-registered then re-registered.
It may be necessary to do this in three stages.
First be sure that all of the handset batteries
are fully charged.
1.
Clear one of the handsets of its registration:
hold down both the [END] and [#] keys
at the same time until the display shows the
SYSTEM RESET menu.
Since the handset is not recognized by its
base, select "Base Not Available".
Confirm the choice by selecting "Yes".
This handset will now display
"Handset Not Registered"
2.
With "...Not Registered" displayed, place
the handset into the base unit cradle.
The handset should now dieplay
"Handset Registering"
After ~30 seconds the display should show
"Registration Complete" and will have a
handset unit number.
If the unit shows "Handset 1" (doubtful)
then just repeat steps 1 & 2 above for each
additional handset in turn. This can also be
the route if you do not care what the numbers
are and do not exceed the maximum count
for your system ( some are 4, 5, or even 12 ).
If the handset is a number other than 1 you
may want to clear the base & re-register
all of the handsets:
3.
Using the now-registered and working handset
(number x), press both the [END] and [#] keys at the same time until the display shows the
SYSTEM RESET menu.
This time, choose "Deregister HS" and the
System Reset Menu will prompt you to
select from the list of registered handsets
which one you want to deregister: choose
one that is NOT the one you have working.
Cycle around deleting them all until only the
one that is working is left: select that one and
the system will be ready to start re-registering
all handsets again from Handset #1.
Start at process (1) above, then (2).
Good Luck!!
Apr 07, 2017 | Uniden Dect1480-3 Dect Cordless Phone, W/3...
Uniden 6.0 dect phone interchangeable with different 6.0 uniden
when the battery cover comes off there are a series of microswitches that are visible.. make sure the new ones are set with your originals..
Jan 11, 2014 | Uniden DECT 6.0 Cordless Telephone...
I have a D1680 system with one accessory handset. The hand set on the base is showing Searching although it is on the Base. It rings when a call comes in but when picked up it says out of range. The...
1. Press & hold End and # at the same time until you see the System Reset menu.
2. If you still have the base the handset is registered to, select Deregister HS, then select the handset you want to reset. If you don't have that base anymore, select Base Unavailable.
3. To confirm, select Yes. The handset displays "Handset not registered"
Now you want to register the phone again.
1. Place the handset in the base; the display should say Handset
Registering.
2. Wait until the display says Registration Complete (about 30
seconds), then pick up the handset and press Talk/flash.
You should now have a dial tone
Oct 16, 2013 | Uniden D1680 Cordless Phone
At&t lg prime gs390 free unlock codes
Please see below instructions in details on how to unlock code for LG phones, (i have included various model of LG for you to try)
Here are some unlock codes for AT&T LG phone available, menawhile , including the methods of entering the Unlock Code on your LG phones attached to them. Hope this is useful. AT&T cell phone Questions&Answetrs
Model : AT&T LG VU CU915 & CU920
1. Put a AT&T or Cingular SIM in the phone; it does not have to be an active SIM 2. Enter *#865625# then the 16 digit unlock code 3. Device should say: Network Lock Deactivated 4. Phone may automatically reboot and is now unlocked !
Model :AT&T LG C2000
Insert non-Cingular SIM card Power on the handset - phone will display "phone restricted" Select "Cancel" - phone will display "phone restriction code" Enter the SIM Unlock code. Select "OK" - the handset is now successfully unlocked
Model : LG TU720 - LG CU720 and all LG Shine SERIES
1) Power ON your phone with an accepted SIM card 2) Type *#865625#UNLOCK CODE 3) Press OK 4) Device is now unlocked
Model : LG CE110
1) Put a non AT&T or Cingular SIM in the phone; 2) The phone display: Invalid Smart Chip 3) Power on handset 4) Select "Cancel" - phone displays "phone restriction code" 5) Enter the unlock code (8 digit code*) 6) Select "OK'" - the handset is successfully unlocked
Model : LG CU400
1 - Insert non-Cingular SIM card" 2 - Power on the handset - Phone will display "Invalid SmartChip" 3 - Phone will display "Invalid SmartChip" 4 - Enter 159753#*# 5 - Enter the 8 digit SIM Unlock code 6 - Select "OK" 7 - The handset is now successfully unlocked
Model : LG CU500
1 - Insert non-Cingular SIM card" 2 - Power on the handset - Phone will display "Invalid SmartChip" (IF THE PHONE DOES NOT DISPLAY INVALID SMARTCHIP, PLEASE POWER OFF AND ON AGAIN) 3 - In Idle screen, enter 159753#*#. Phone will display "Enter NCK, Remaining 5 4 - Enter the 8 digit SIM Unlock code 5 - Select "OK" 6 - The handset is now successfully unlocked
How to Unlock LG CU515:
1-Insert non-Cingular SIM card" 2-Power on the handset - Phone will display "Invalid SmartChip". 3-Enter *#865625# then select option 1 and then again select 1 4-Enter the 16 digit SIM Unlock code 5-Device should say: Network Lock Deactivated 6-The handset is unlocked. 7-How to Enter Unlock Codes on CU575 (Trax) How to Enter Unlock Codes on LG F2250:
1-With allowed sim card in the start menu type: 2945#*3311#. 2-Handset shows saved, then return to startup screen 3-Press Menu key, choose Settings > Security > Sim Lock> Network > Deactivate, handset will now show 'Enter NCK' 4-Enter your unlock code and OK. How to Enter Unlock Codes on LG U8110:
1-With a not allowed sim card in your phone enter Pin code then validate, type: 277634#*# 2-Select 'Sim Unlock' menu # 3-Enter NCK code then validate 4-Your phone is now unlocked. How to Enter Unlock Codes on LG U8210:
1-With a not allowed sim card enter Pin code then validate, type: 277634#*# 2-Shows test menu 3-Choose sim test menu and type: 2945#*#, choose Sim Unlock menu 4-Handset shows 'Enter NCK' 5-Enter code, then hit OK. How to Enter Unlock Codes on LG U81xx:
1-To bring up the unlock menu on the phone with a SIM card, type 2945#*88110# 2-Enter the code 3-In case you need to reset the phone without a SIM card first, type 277634#*# or 47328545454#. If your cell phone is not listed, please follow instructions for LG C2000 above
If If instruction above does not help you i would strogly suggest to contact your Service Provider to provide some alternatives.
Thank you for using fixya
Please rate me and give testimonials if ever to continue my assistance
lg-phones
Jun 03, 2011 | LG Cell Phones
I have a Motorola L404 cordless phone. i bought an additional handset. I cannot get it to register with the base unit. It just keeps saying "registration failed"
On the Motorola L404 series, to deregister all handsets you unplug both the phone and power to the base station. Press and hold the 'find' button while plugging the power back in. The display will show "CL". Continue to hold the find button till the display shows '00' and all the handsets will show 'unregisterd'. You then proceed by registering all your handsets again in the order you want them listed.
Sep 01, 2010 | Motorola Mobility L4 Cordless Expansion...
My uniden tect1580 doesn't ring
First thing to try is while the phone is in "On-Hook" mode, press the up key on the handset several times, you should hear a beep each time you press the button and the display should show "Ringer Volume" with a graduating series of bars. If the display shows as above, but you do not hear any rings, try pressing the "Speaker" button and listen for the dial tone. Most of the time on these phones, it is a simple matter of turning up the ringer volume, but sometimes, the handsfree speaker (Which also acts as the ringer speaker) goes bad. If the speaker is bad, it is a fairly easy replacement if you are handy with a soldering iron.
Feb 17, 2010 | Uniden DECT 6.0 Cordless Phone ID
Motorola showing "no service",using idea num
you antenna could be faulty so it would be better to take the phone to a mobil service center to have it fix.
Dec 18, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Display on handset does not display any info!
The display could be bad or the didplay driver could be bad or it could be a simple wiring problem if you're lucky. Try pressing around the edges of the display to see if anything appears (press firmly but not so hard as to break anything). If you are mechanically inclined, open up the handset and connect the battery so the handset works. Normally the display is connected to the phone circuit board by a ribbon cable and frequently there is a tiny "edge card connector". If present, make sure the connector is plugged in completely. Watching the display, try pressing on the ribbon cable where it attaches to the display and to the circuit board. If anything appears, keep trying to isolate the problem.
I recently had this same problem with a Sony handset but I was not able to find anything as I just described and I ended up replacing the handset with a new one of the same model. Good places to look for a replacement are eBay and Amazon.
Nov 13, 2008 | Uniden Cordless Phone
Cell Phones Logo
29 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
