Question about Light Outboard Motor Boat Bass Fishing Saltwater Base
Hi,I am looking for an online manual for an 85 hp mercury outboard engine,I need to replace the water pump
  • 57 Answers
I have service manual for MERCURY IN LINE 75-150 HP-it covers all however my scanner printer down at present so unable to scan to lappy to be able to email at prez-hopefully this week-waiting on my computer man!
Posted on Oct 15, 2009
1995 mercury 115hp water pump replacement kit
https://www.marineengine.com/newparts/part_details.php?pnum=MER47-42038Q02
May 27, 2017 | Seloc Mercury Outboard Engine Repair...
Where might I find a working fuel pump for a 1966 Mercury 3.9 hp outboard motor?
there is a pump for sale on e-bay --seller is western furniture (1918) used condition for $25.00 us 2 people watching it but it has a buy now tab
I found this by going google and typing in --fuel pump for mercury outboard motor 3.9 hp-- and the site is www.ebay.tv>sch>ebay-motors-
mariner is also a part of the mercury range so check for mariner 3.9 or 4 hp parts
Sep 11, 2016 | Boating
I have a 1978 merc 85 hp outboard with a bad pump i purchased a used one that works mine has 4 hoses
Mercury Outboard Fuel Pump - Mercury Outboard Forums
forums.iboats.com/Mercury-Outboards/Fuel-Pump
5, 2004 Mercury 225 four-stroke EFI no power to Low Pressure fuel pump. Why please help · Mercury & Mariner Outboards. 13, Mercury 850 (85hp) - Gas pumps through the top carb - Failed fuel pump? ... 1, 1969 7.5 H.P. Mercury (Bad fuel Pump)? ... 1971 · 1972 · 1973 · 1974 · 1975 · 1976 · 1977 · 1978 · 1979 · 1980 · 1981 ...
Fuel Pump Diaphragm replacement Mercury outboard 110 ...
? 4:18
https://www.youtube.com/watch?v=vufekxTVZd8
Jun 22, 2012 - Uploaded by Brad Clark
My last test run of this motor lead me to believe I had fuel pumpissues...so in ... Mercury 9.8 h.p. 110 Outboard Motor WaterPump Repair and ...
How to remove the lower unit on a Mercury outboard motor ...
Dec 01, 2015 | Boating
I have a 1999 mercury villager with no heat is there anything I can do till find a heating core with inlets and outlet pipes
Hi Shawn,your thermostat may be stuck open,not letting your coolant heat up.check this first.here's a link on how to replace, GET 25 GIFT CARD FOR EVERY 100 SPENT ON ONLINE SHIP TO HOME ORDERS After removing,look at it,it should be closed,to see if it is working,boil water to 180 degrees with thermostat in pot,it should open at 180,remove from water and it should close,if it's doing this,then it's good,is your water pump working properly,no leaks.Here's another link to your heater core, GET 25 GIFT CARD FOR EVERY 100 SPENT ON ONLINE SHIP TO HOME ORDERS I am fixing to replace my heater core in my 85 Nissan 720 truck,did it 10 years ago,my heat still works,but my windows fog up super fast,which means it's leaking,can put my hand on the carpet by the heater core and feel coolant,it's a job.
Nov 24, 2014 | 1999 Mercury Villager
Mercury outboard problems
The alarm is the overheat horn. It means that your motor isn't pumping water from the bottom of the leg and through the engine cooling ports. You will see water shooting out the side of the motor when it starts getting hot, and if you're not seeing the water shoot out and the horn is on then chances are the pump impeller on the leg is shot. You should never start a boat motor (outboard or any other type of boat motor) without having it sitting in the water or with a water calliper with a garden hose attached on the lower inlets of the leg. If you run it without water you will melt the rubber impeller and damage the engine if it's run too long without water cooling. Take it in to a qualified tech to replace the impeller.
May 25, 2014 | Boating
Water pump
The water pump is a flexible impellor located in the top of the bottom section of the leg of the outboard. It is driven by the drive shaft to the prop that is spinning all the time the motor is running. You will find it behind or near the water inlet slots at the bottom of the leg
May 14, 2013 | Seloc Mercury Outboard Engine Repair...
85 hp force eng stops running when put into gear and then given more throttle(only hapens in the water)ok out carbs rebilt ,filters cleaned
check compressions 100psi or more on all cyls ! carbs balanced ? sparks on all cyls ? crank seals could be worn ! tick over 1000rpm then in gear 800rpm ish ! In water !
Oct 29, 2012 | Seloc Mercury Outboard Engine Repair...
Diagrams & specs sheets '85 chevy silverado
Go to autozone.com and register,and you'll be able to access their online repair manual.It contains everthing you'll need.
May 26, 2009 | 1985 Chevrolet Chevy
Light Outboard Motor Boat Bass Fishing Saltwater  Base Logo
413 people viewed this question
Top Light Boating Experts
ray gallant
fordexpert
ka4iup
ka4iup
Are you a Light Boating Expert? Answer questions, earn points and help others
