Question about Refrigerators
I have a lucozade sport fridge but it keeps freezing the drinks how can you turn down the temp?
    Sergeant:
    Champion:
  • 323 Answers
Should be a temp setting on the bottom of the fridge, you can also unplug the fridge for 3 seconds and plug it back in this will reset the unit into a normal cooling mode
Posted on Oct 03, 2009
We just bought a GE gbe21dgkarww we are having trouble wth the crisper, they are freezing my fruit and vegetables. Temp. Cool on freezer on coldest
Fridge temps are actually cooled by the freezer,try turning freezer temp down somewhat-and I highly recommend buying a fridge thermometer,generally speaking I try to keep my fridge at about 34-35 degrees,you can go SLIGHTLY higher,is fridge section directly over freezer??
May 09, 2017 | GE Refrigerators
Hi, I have a 3 yr old Haier Fridge serial #HBP18GAAWW, the feezer is on the bottom. The food and drinks keep freezing in the fridge and there is alot of frost in the freezer. Is there a problem with his...
Have you tried to lower the temp.settings?? If settings are about 1/3 of the range, then it could be a thermostat problem.
Keep me posted!! Rate this post!!
Aug 12, 2010 | Haier Refrigerators
Idesit BAAN134 PSUK fridge keeps freezing food . The fridge part of my tower f/f keeps freezing food even though I have turned the dial down to the minimum the temperature regularly drops to below...
If it is an electronic thermostat it could be that the engineer has changed the board but not the sensor which reads the temp. If it is a mechanical thermostat it may be hes fitted the wrong type.It could also be that the system is short of refrigerant and the actual refrigerant charge is not getting all the way to the thermoststs sensor to switch it off, the back wall of the fridge should be frosted at least 3/4 of the way down and not just forming in a small part of the fridge.
Jan 05, 2010 | Refrigerators
My Frigidaire refrigerator side by side is freezing drinks.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Sep 22, 2009 | Frigidaire FRS26H5AS Side by Side...
We have a GDM-26 commerical coke machine. Only
If any of your drinks are freezing you need to adjust your temp setting. The suggested setting is 5. changing the temp setting basically tells the refrigerator to stop cooling when the temp hits a low degree, and to start cooling when it hits a high degree. This keeps your drinks not to hot, not too cold, but just right. If this doesn't work I would change the cold control altogether, it might've went bad. If you have a few minutes, locate the condensor fan (bottom) and make sure it is periodically turning on and off like it should.
Jun 08, 2009 | True GDM-12 Refrigerator Commercial
Fridge and freezer both freezing
If your control is not turned up too high you likely have an insensitive one. In this case it needs to be replaced with a new one, not too serious.
Dec 18, 2008 | Kenmore Freezer 20.6 cu. ft. Manual...
Refrigerators Logo
130 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
