Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
Oven gets hotter than temperature set
The oven (Frigidaire self-cleaning electric) gets hotter than temperature it's set on especially the longer it is on
I don't know if there is a solution but I kbow every model like this does the exact same thing. I two of my family members have the same stove and they have the exact same problem.
Posted on Oct 03, 2009
How do I clean my Frigidaire electric oven, Model FEF352AWF?
See page 13 for specific instructions.
ShopYourWay FRIGIDAIRE Free Standing Electric ShopYourWay
As tedious as it may seem I suggest that cleaning the unit by hand is the preferred process. Most failures that I have experienced have occurred just after the clean cycle is completed. There is a lot of stress during self clean and critical components are stressed and are more likely to fail. On two occasions I have had a failure days before family dinners. Usually in preparation for family we had been cleaning the oven. Both the temperature sensor and heating element have failed.
With a free standing oven repairs are a lot easier than with a built in wall oven requiring saw horses to remove and set. In any case plan to clean long before company in the event a repair results.
Why You Should Almost Never Use Your Oven Self Cleaning Function
Jan 06, 2016 | Frigidaire 30" Self-Cleaning Freestanding...
Oven is hotter in the back of the over than the
Good Afternoon Essie, thank you for your post!
So I understand you're staying that the oven has a higher temperature in the front, is that correct? If so, technically speaking that is very rare or not possible. I suggest to make sure the pan is placed in the middle of the rack and not closer to the front or back. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if the unit's status has changed successfully. Thank you!
Nov 03, 2013 | Frigidaire 30 in. Electric Gallery Series...
I have an old Whirlpool Self-Cleaning oven. I've followed the use guide instructions but still can't get the cleaning light to come on. I have both knobs to clean but the oven light comes on and the...
Probably, in some models both the bake and broil come on to help it heat faster and hotter. In some units the self cleaning light will not come on until a certain temperature is attained. Are you setting the start time for right now, and the stop time for 2 to 3 hours from now?
Jan 28, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
The oven temp is 100 degrees hotter than the set temp.
On most oven temperture controls, if you pull the knob off there is an adjustment screw down in the shaft turn counterclock wise?? to lower setting. Good luck
Nov 14, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
I need to calibrate an electric oven
Probably. There is often a key sequence that will enable a calibration mode. We need the full model number to find the tech info, or you can probably find it in the tech sheet which is normally taped on behind the control panel.
Oct 13, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Self cleaning oven help
There is nothing wrong with cleaning a self-cleaning oven. Now, I don't have experience with your speicific oven, but I do have experience with other self-cleaning ovens. The self-clean function simply heats the oven up really hot. The actual temperature varies but the oven will get hotter than the hottest temperature setting. What happens is that when it get that hot it actually burns up spilled food and crumbs. sometimes in mine I even see small flames. The oven usually requires you to lock it as well since the temperature will be so high. Eventually you have to clean out the burnt "ashes" which are basically the stuff you get on food if you burn it. So the answer to what happens if you clean the oven is that you get a clean oven, nothing else. It won't hurt the oven at all. As a matter of fact even if you use the self-cleaning feature you will eventually have to clean out the "burnt crumbs" and such by hand anyway. So self-cleaning oven are designed to be cleaned by hand as well. And you won't hurt it by doing so even if you did it every day.
Jun 19, 2009 | GE Profile JTP56 Electric Double Oven
Range Cleaning Cycle not Working
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 22, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
FGB24L2ABB Frigidaire wall oven
local outlety to buy rack for oven
jeff
May 20, 2008 | Frigidaire 27 in. Electric Double...
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
225 people viewed this question
Top Frigidaire Ovens Experts
Oloyede Monsuru
ashburton
Starnley Johnwells
Starnley Johnwells
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
