Question about Maytag Bravos MTW6600T Top Load Washer
I have a maytag bravos and i keep getting LF WHAT Dose that mean
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 50 Answers
(Washer is taking too long to fill)
Check the following:
Are the hot and cold faucets turned on?
Are the water inlet hoses kinked or clogged?
Are the water inlet valve screens clear?
Press POWER/CANCEL to clear display.
Hope this helps.........................
Posted on Jan 08, 2010
Maytag 2000 Error LF what does this mean
The LF error code indicates a long fill condition.
What you need to do is check the filter screens where the hoses connect to the unit. Remove the hoses at the back of the unit. The screens are hust inside of the connections. Make sure they are free from any debris.
or
https://www.youtube.com/watch?v=1M-XgRT3obc
or
http://ths.gardenweb.com/discussions/2441868/maytag-bravos-lf-error-code-solved
Apr 29, 2016 | Maytag Washing Machines
What does LF mean on the washer? When I start my load it pops up as LF and stops washing. What do I need to do or what is wrong?
LF (F30)
LF flashes when the control don't sense any water coming in like it is supposed to do. Things to check:
Hoses connected; water turned wide open.
Is water siphoning out due to having the drain hose too low? (30 inches above the floor)
Pressure hose from tub to control loose, pinched, hole, Sediment in tub? themobilian_1135.jpgthemobilian_1136.jpgBlow that tubing out and re-secure; retry with water OUT of tub so the pressure can properly build in that tubing. themobilian_1137.jpg
Bravos codes and service manual HERE
Jan 29, 2011 | Maytag Bravos 3.8 Cu. Ft. Washer
Washer starts then gets LF code
rwer
Hello and sorry to read about you LF issue
LF means long fill. Turn off the water and remove the hoses from the back of the machine, inspect the screens inside the washer water valve for debris. Stick the hoses into the washer tub and turn the water on, verify you have good water flow. If all of this checks ok then you either have a bad water valve or the control is sending power to the secondary diverter valve but not the primary hot/cold valve or vise versa.
I tried to help you.Please help me and rate/vote my response
Thanks and good luck
Dec 24, 2010 | Maytag Bravos MVWB400V Washer
I have a new Maytag Bravo top loader.
That means low flow. Turn up water valve. If that don't work then shut your water off take off hoses and clean the screens on the washer they are dirty that happens with hardwater
Apr 29, 2010 | Maytag Bravos 4.5 Cu. Ft. Washer
The LF error message pops up on Bravos washer
might want to check screens in fill valve where hoses attach to machine
Apr 23, 2010 | Maytag Bravos MTW6600T Top Load Washer
What does LF mean on my washer?
Hello there:
It is possible your line or tube that goes through the fabric softener dispenser is partially obstructed, giving the LF error which means it is taking too long to fill. I would try cleaning out all of the dispenser lines, and if that does not fix things then you may need to replace the inlet valve assembly which may not be working correctly. or you may want to make sure that your hoses are not all tangled up and are clear of any debris in the screens of the hoses
Jan 19, 2010 | Maytag Bravos 4.5 Cu. Ft. Washer
Maytag Bravos top load gives LF code..not working ... any idea?
Have same problem. Service tech said LF code is caused by low water pressure coming into machine. Tech verified water flow looked fine, getting new controller installed tomorrow.
Jul 18, 2009 | Maytag Bravos MTW6600T Top Load Washer
My maytag bravo top loader washer is displaying a code of LF and
it meant "low flow" check water connecting lines. mine has the same problem.
Dec 02, 2008 | Primera Technology Bravo (Refurbished)...
Maytag Bravos MTW6600T Top Load Washer Logo
568 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
