Question about Troy Bilt 5.5hp Self Propelled Mower
Super Bronce is Jerking while going forward
I have replaced both drive belts and the problem remains. I see a lot of gear oil on the rear differential so it's my guess that something in the rear differential is causing the problem.
    Champion:
  • 205 Answers
Your bevel gear forward my be out or you input shaft gear my be slipping. check your vauble drive pully sys make sure your bearing are not bad and you may check your belt to see if you have flat spots. if you have a lot greas your seals are out axles. ther are no gaskets used on this trany body. sealint only
Posted on Oct 11, 2009
How and were to replace gear oil
How to Care for Your Car's Differential - Popular Mechanics
www.popularmechanics.com/cars/.../how-to-care-for-your-cars-differenti...
Apr 3, 2013 - The differential oil lubricates the ring and pinion gears that transfer power... Checking and changing the differential oil in a light truck is actually ...
Differential / Gear Oil Replacement - YourMechanic
www.yourmechanic.com > Auto Repair and Maintenance Services
How much does Differential/Gear Oil Replacement cost? Get an estimate instantly. ...Some vehicles have a front differential and others have a rear differential. ... I'm from out of town and didn't know who to contact to fix a truck I was borrowing.
How to Change Transmission Fluid & Filter ' Step by Step
www.transmissionrepaircostguide.com/change-transmission-fluid/
A do-it-yourself transmission fluid change is an affordable way to maintain and ... It is often recommended that you change the fluid in your car every 30,000 to .... lifted up my truck with a jack, Jack stands, blocked the rear tires and went at it just ...
How often gear oil should be changed - Testing Autos
Feb 03, 2016 | Cars & Trucks
In turbo hydro 700 why would forward gears make the rear wheels go in reverse
Your differential is upside down. Ford model T's had the same problem. It was possible to mount the rear axle upside down which made the car go forward in reverse and backward in forward gears.
Mar 07, 2015 | Cars & Trucks
Rear End Whine Under Load
Replacing gears and/or bearings in a differental is not an easy project. You'll need a press. The positioning of the gears requires a great deal of precision. Shims are used to acheve the correct setting. Preload setting on the pinion bearings is critical. I would recommend leaving this one to the experts.
Jul 12, 2013 | Chevrolet Blazer Cars & Trucks
I changed my Prado 2007 rear Differential LSD type, we have put Mobil 1 LS, 75W-90 diff oil. I used for 4 days and noticed some jerking when doing turns. Immediate drained and put Whiz synteq mt1 80W90...
II think I would try some Motorcraft XL-3 Friction Modifier. That is what Ford uses to fix the same problem in their Limited Slip differentials. You can find it online or at any parts house that carries Motorcraft.
May 04, 2011 | 1997 Toyota Land Cruiser
When I make a turn going 30-35 mph and the weight of the vehicle is at maximum force, I hear a clunk from underneath the vehicle. What could be producing this sound?
Try changing the gear oil in the rear axle. Be sure to add a Slip Differential Additive paste to it (Autozone sells the paste and the gear oil).
The noise is coming from the differential in the rear axle and you will hear it when the vehicle changes from one direction to the other. Drive a hard zigzag line in a vacated parking lot and you should hear it at each shift in direction.
Change the front axle gear oil also if it had never been down. Usual interval for both is 30,000 miles.
Mar 01, 2011 | 1995 Isuzu Rodeo
The problem sounds and looks like its in my rear end when i turn left or right my rear end acks like its locked in and my rear tire sqeel but when im driving foward or back it dont act up. it only does...
Sounds like you have a limited slip or " Posi-Traction" rear differential, if this is the case than go to the GM dealer and ask them for a bottle of friction modifier oil for limited slip differential. This stuff is pure whale oil that helps to lubricate the clutches in the differential. After adding the lube find your self a big empty parking lot or other paved surface and drive the vehicle forwards then backwards in a slow figure 8 patern, turn as tight as you can each way, this will force the clutches to work and help limber them up. The differential might make some crunching sounds, but the noise should quit as the lube gets in and does its job.
Apr 14, 2010 | 2004 Chevrolet TrailBlazer
Where is the fill plug on the diffirential on a 1999 jeep grand cherokee laredo"
How to Fill a Rear Differential
You may need to add fluid to your differential due to leaks or changing seals, or it may be time to change out the gear oil completely. Either way, it's just a few steps to fill the rear differential and get your vehicle back out on the road!This article will explain how to fill a rear differential. jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); Difficulty: Moderate
Instructions and Things You'll Need:
  • 3/8 inch drive ratchet with extension
  • 2 quarts gear oil (gear lube, differential fluid)
  • Side cutters
  • Oil drain pan
  • Shop rags
  • Flashlight or shop light (optional)
  • Lock tight (optional)
Filling a Rear Differential
  1. Be sure the car is raised on four jack stands and is level. It will be more difficult to fill the differential if you've only got it raised in the rear.
  2. Place an oil drain pan underneath the plug to catch any leaks or drips. Keep shop rags handy for any spills.
  3. Check your service manual for the amount of fluid your differential needs, if you're completely refilling the system. Two quarts should be enough in most cases.
  4. Remove the spouts on the gear oil containers. Peel off seals, then replace spouts. Use side cutters (or any cutting tool you've got handy) to clip off the top of each spout.
  5. Remove the differential fill plug using a 3/8 inch drive ratchet with extension. (Some models may require a hex key or screwdriver, but the 3/8 inch is the most common plug design.)
  6. Take the gear oil container and fit the spout into the fill hole. Pour the fluid inside. You can gently squeeze the bottle to speed the process. Repeat with a second bottle if necessary.
  7. Fill the differential until the fluid starts draining back out of the hole.
  8. Clean and replace fill plug. Use lock tight (thread locker) to help seal if desired. You can see my eHow article "How to Replace Rear Differential Fill Plug" (video) for more information.
  9. Take the car for a drive around the block to get the gear oil moving. When you return, check underneath for any leaks from the fill plug or differential cover.
Hope help with this.
Mar 12, 2010 | Jeep Grand Cherokee Cars & Trucks
2000 ford expidition has a leaking rear differential. Probably a gasket? how easy is repair? what tools and fluid? Thanks JB
no big deal if it is the inspection plate on the rear,
just removal of the ring of bolts,a pan to drain fluid in,clean both surfaces and install new gasket,refill with 90wt gear oil.
Dec 27, 2009 | 2000 Ford Expedition
Differential noise when gear is place. in reverse or drive.
If it's only happening when you initially place it in those gears before going forward or reverse, your U-Joint in the rear is going bad. Replace both when you replace the one. This way you don't have to go there again when the fron U-Joint decides to go out. Cheap insurance.
Feb 06, 2009 | 2000 Chevrolet Silverado 1500
Troy Bilt 5.5hp Self Propelled Mower Logo
132 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Mike Squire
Tim Whalen
Are you a Troy Garden Expert? Answer questions, earn points and help others
