Question about Kenmore Elite HE4 Electric Dryer
My washer keeps flashing f02 everytime i do a load of laundry
I have looked at everything the manual said it could be.
  • 15,935 Answers
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%%%%
Posted on Sep 29, 2010
Whirpool duet F02 code
On the bottom right hand side there's a flap put it down now your looking at a white or black screw plastic unscrew very slowly put a towel down as there will be some water try to put some thing under it so you can keep empty the water in to a bowl or bucket OK after its right out clean what ever you can see then put back job done hope this is helped you OK
Oct 22, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Door won't open on whirlpool duet washer frontload
Press the cancel button twice to cancel the error code. There should be an error code flashing -- for example 'F02'.
Nov 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
F1 comes up everytime you wash a load of laundry.
F1 = Primary Control Failure
F then 1 flashes when there is a primary control failure. Replace the machine control assembly
Thank you
Sep 10, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
F 02 I reset it to drain and spin for the first load. already took the bottom panel off and cleaned out the white container. still not working for the second load, still flashing F02.
f02 means long drain. something is stopping it from draining. takes the pump out and look in at the impeller, something could be caught in it
Feb 06, 2010 | Kenmore Elite 45986 Front Load Washer
Code nf shows on my washer
unplug for 15 mins and plug again to rest
Sep 14, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore HE3 front loader keeps getting F02 error message, most often when I wash towels. I was able to workaround by pulling half the load, but that no longer does the trick.
Long Drain
F02
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
Jul 13, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
F02 Error on Front Load Kenmore HE3
F 02 Is your key pad user interface that has failed. I would call back and get some free service from a different technician.
Oct 23, 2008 | Kenmore Elite 45986 Front Load Washer
Stopping mid cycle and won't spin
"F02" is a Long Drain error. This is usually caused by debris build up in the drain pump. The following link explains the error and what to do:
http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
The washer will not complete a cycle if it senses a condition that generates an error code. Follow the advice in the link provided and you should be okay. Now...it doesn't take much to cause irrepairable damage to the drain pumps in these washers. If you do everything I suggest and the error code returns, it is recommended that you replace the drain pump. I hope this helps you. Let me know if you require additional assistance.
Oct 10, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet model GHW9150PW3
I cleaned my drain pump fiter (F02 ). When I put everything back together and tried a cycle, there is no water flow resulting in FH. I did not touch the water supply. Help!
Aug 11, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite HE4 Electric Dryer Logo
51 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
