Question about Bosch Drills
What type of grease do you put in the gearbox and main bearing at end of dril handle
  • 2,176 Answers
It depends on the type and function of the tool, Bosch uses a couple different lubes, but in general a good lube like a wheel bearing grease should work, Also note that the gearcase is not filled with grease, usually a couple ounces again depending on the tool.
Posted on Oct 03, 2009
Where can i get the lefthand side stabaxle for mazda 323 i60i
I take it that you are in the USA where the LH wheel hits the curb What ever it is of little consequence as it is a small problem that will damage the bearings. Wheel bearings fail because of 2 items that most important. First is grease and the second is adjustment. Over greasing or under greasing will cause premature failure. You need a high temperature operating grease to handle the heat generated by the disc brakes. Second if you have taper roller bearings then the correct adjustment is a no preload -no end float position. If the bearings are thrust ball bearings then the spacer between them gives the correct adjustment Ensure that the grease seal in the hub is in the right way to retain the grease
Nov 08, 2013 | Cars & Trucks
Proform ZE3 Elyptical screeches constantly
FOLLOW THIS STEPS AND FIX IT. God bless you Lubrication
Detach the ends of the pedals from the crank axles. Spread a layer of machine grease over the crank axles, then reattach the ends of the pedals.
Remove the bolts connecting the pedals to the swing arms. Detach the pedals from the arms, then spread a layer of machine grease over the axles on the swing arms. On some models, the bolts may also serve as the axles. Reattach the pedals to the arms.
Remove the bolts connecting the swing arms to the elliptical's upright. Detach the swing arms from the upright, then spread a layer of machine grease over the axles on the upright. Reattach the arms to the upright.
Link Arms
Unplug the power cord. Identify the pivot points where the lower handlebars and the footpad link arms connect at each side of the machine. Use a screwdriver to remove the inside and outside elbow covers at each connection. This will expose the pivots.
Put a box wrench on the lock nut at the inside of one pivot and loosen the bolt with an Allen wrench. Remove the bolt and check the assembly for nylon spacers or a bearing. If no spacer is found, proceed to the next step. Replace the nylon spacers, reassemble the connection and reattach the elbow covers. Repeat this at the opposite side of the machine.
Have an assistant hold a deep socket against the inside face of the pivot hub. Make sure the socket is large enough to allow the bearing to pop out. Insert the point of a flat screwdriver into the outside of the hub until it contacts the bearing. Tap the handle of the screwdriver with a hammer to remove the bearing. Repeat this to remove the bearing on the opposite side.
Hold each bearing next to one ear and turn the inner race with your finger. If you hear grinding noises or the bearing is rough, it must be replaced. Lubricate the bearing with lithium grease and a grease gun. Replace the bearing into the hub. Reattach the lower handlebars and footpad link arms and put the elbow covers on.
Pedal Arms
Use a flat screwdriver to unseat the tabs that hold the front top cover in place. This will expose the flywheel and pedal arm connection points. Rotate the flywheel by hand and determine whether lubrication will accomplish the repairs. If the bearings are exposed, use a grease gun with an extension nozzle and lubricate both bearings with lithium grease. If the bearings are damaged or sealed, proceed to the next step.
Remove the front and side covers on the main frame. Hold the flywheel with one hand and use a box wrench to loosen the bolts that secure the pedal arms at each side of the flywheel. Pull the arms away from the flywheel and remove the bearings from each side.
Test the bearings as before. Lubricate exposed bearings with lithium grease and reinstall them. Sealed bearings must be replaced. Reattach the pedal arms to the flywheel. Replace the main frame covers and front top cover to complete the repairs.
Mar 22, 2013 | Exercise & Fitness
Tension to tight on bike won't losen
Step 1:
please follow the instruction and fix it. God bless you.
Pedal Arms
Step 2:
LUBRICATION
Prepare to oil by filling a grease gun with lithium grease. Check your owner's manual for the exact type of grease for your unit.
Locate where it is you need to lubricate. Focus on the bearings, free-moving joints and attachments with moving parts such as handle bars, wheels, pedals arms and guide rails. Go to each location one by one when greasing.
Unfasten the bolts or screws that hold the joint or attachment that you wish to lubricate.
Grease each bolt and screw liberally. Tighten each bolt and screw back into its place when finished.
5
Wipe away any excess greas
Step 3:
Drive Belt
Remove the screws or bolts securing the ends of the pedals to the crank axles. Slide the ends of the pedals off the axles. Remove any screws or bolts securing the left and right disc shields to the base unit. Pull or pry the disc shields off the base unit and set them aside.
Remove any screws or bolts securing the left and right side shields to the base unit. Detach the side shields and set them aside. Examine the interior of the base unit and locate the drive belt.
Pull the drive belt free of the crank pulley, flywheel and any other pulleys. Discard the old drive belt and install a new belt in its place. Turn the crank axles by hand to confirm that the belt will turn smoothly when the device is in use
Jan 04, 2013 | Weslo Pursuit R 3.8 Upright Exerise Bike...
Pedal tention too tight
Step 1:
please proceed with this step . Happy new year and God bless you
Lubrication
Step 2:
Pedal Arms
Step 3:
Link Arms
Jan 01, 2013 | Exercise & Fitness
My proform spacesaver 500 eliptical is making a clicking sound
follow this steps and fix it. God bless you
Lubrication
Link Arms
Pedal Arms
Nov 30, 2012 | Exercise & Fitness
I have a Freespirit 110 Elliptical purchased from Sears some time ago. Recently, there is a grinding noise coming from the wheel, possibly worn bearings?
Link Arms 1
Pedal Arms 1
Oct 15, 2012 | Free Spirit FREESPIRIT CROSSTRAINER 970...
Noise from bearings
see this steps and fix it. God bless you
Pedal Arms 1
Link Arms 1
Lubrication 1
Oct 15, 2012 | Proform Pro Form Sears Elliptical Drive...
I just replaced the clutch plate, disc, release bearing and pilot bearing with new oem ones. After installation, at idle speed my clutch is noisy. If i depress the clutch pedal, the noise goes away.
the lay shaft bearings inside the gearbox are worn,remove level plug and pump a grease gun full of grease into gearbox as this will help quieten it ,
Apr 17, 2011 | Mercedes-Benz 300-Class Cars & Trucks
2005 BMW 320D E90 MANUAL TRANSMISSION Hi a noise on my clutch when pushing it down and releasing it just after the free play travel the clutch seems to be 100% still pulls well not slipping or shuddering...
most likely its the thrust bearing noisy but it could also be the layshaft bearings in the gearbox as well ,check the gearbox oil level and check its ok if ok then its a thrust bearing ,these modern motors with a nylon bearing holder are not very good to say the least ,now if oil level is low in gearbox then before you top level up use a grease gun and remove the nipple thing on the end and then pump a good grease gun full of LM grease into gearbox and then top up with EP90 as this will help seal any leaks and stop a lot of the noise ,you cannot hurt anything by putting the grease in the gearbox i do it lot to stop a leaky gearbox from leaking as the grease gets hot and sinks to the bottom and solidifies stopping a lot of the leaks from gear linkages and around the drive shafts although this is a rear wheel drive vehicle so that is less of a problem
Mar 03, 2011 | BMW 3 Series Cars & Trucks
When moving the mixer tiped over in the trunk and oil leaked out. It is making a grinding sound at times when mixing thicker things. I need to know what kind of oil to use and where to put it. Thank you....
First off -- if it's still under warrantee, you'll want to go to kitchenaid.com and find the nearest service center. The next thing I say starts with "void the warrantee" steps. :)
It's very simple to open a stand mixer to see if you've got a simple problem or a bad one.
Unplug it.
Follow the aluminum "Kitchen Aid" band to the back of the unit, there's one main screw. Remove this, and set it aside with the band which should come right off at this point.
Now, there should be two screws on each side of the unit where the band used to be. Remove each of these. They're all identical, so no worries if you mix them up.
Now you can lift the top off of the unit and see inside. The motor is at the back of the unit, the gear box at the front is where the oil is coming from. Try (GENTLY) to tighten the screws that hold the gearbox together. With a little luck, the gearbox screws had come loose and it was oozing oil out through the seals. If they're all firm, then you've got more serious problems and you'll want to find a service center for it.
If the leak was just that the gearbox housing was loose, then you can open it up and see the grease that's inside. It's very thick grease, not liquid oil at normal temperatures, but I don't know what type of grease it actually is in yours.
The grinding sound you describe makes me think you've broken or dislodged the bearing chase though, and you've got bits of metal and/or small (1 - 2 mm diameter) bearings loose in the gearbox.
Jul 12, 2009 | KitchenAid KSM5PS Heavy Duty Stand Mixer
Drills Logo
726 people viewed this question
Top Bosch Drills Experts
Matt Olenzek
Matt Olenzek
woodzowl307
Are you a Bosch Drill Expert? Answer questions, earn points and help others
