Question about Motorola iTECH iQfive iQplus GP350 Compatible Two Way Adapters 2-Way Radio
Mororola gp 68 ihave 3 but only 1 is transmiting the other 2 seem to locked so they cannot transmit
    Problem Solver:
  • 12 Answers
Define "locked" Also, you can check out http://www.batlabs.com/gpman/top.html and maybe that will help.
Posted on Dec 28, 2009
Yaesu 3100 transmit problems
There are several reasons you may not be able to transmit with the FTM-3100R:
1) Your antenna is not matched to the frequency of use and presents a high SWR. The 3100 protects itself from high SWR by refusing to transmit
2) You have somehow enabled the busy-channel-lockout feature in the setup menu, and you are operating with an open squelch
3) Your DC power supply voltage is too low to support transmit current
4) You are transmitting with too low a power setting and the receiver cannot hear you
5) You are attempting to transmit to a repeater that uses a CTCSS squelch tone, and you do not have the proper squelch tone configured
Both of the LEDs to the left of the display should turn red to indicate you are transmitting. If both LEDs turn red, your problem is likely either #4 or #5.
May 21, 2017 | Yaesu Radio Communications
Portable motorola gp 340 can receive but cannot transmit
Don't know your capabilities but if it were me I would open the phone and check the contacts for transmit button. Sometimes contacts get corroded and need cleaning or it just may be no connection at all and a adjustment of the contacts will resolve the issue.
Mar 10, 2014 | Motorola Walkie Talkies 2-Way Radio
My hr2600 shows error 3 when it is keyed up and does not transmit
0 = Transmitter Timeout timer has timed-out
1 = Transmit Frequency is lower than TX Lockout Lower Limit
2 = Transmit Frequency is greater than TX Lockout Higher Limit
3 = Phase-locked-loop (PLL) won't lock at this transmit frequency
4 = PLL is intermittently coming out of lock during transmit
*If your radio displays error 3 or 4, don't keep trying to transmit on this frequency. The cause of the problem could be low power supply voltage to the radio or the radio's VCO loop needs adjustment. Refer to a qualified technician for service. Contact the installer of the chip first. If, however, you installed the chip yourself, contact a qualified technician for service.
Sep 24, 2013 | Magnum DeltaForce CB Radio
On our 2-way radios you can transmit on one but you can't transmit on the other the model # is RDU2020
I had a similar problem - my Talkabouts would not transmit - after checking the interference codes, qt, etc, it turns out the rechargeable batteries weren't able to handle the 1-watt mode. I switched to another FRS channel that only transmitted at .5 watts, and that seems to have cured the problem, but the range is probably reduced. With another set, I chucked (recycled) the rechargeables and placed 3 new AAA's in and it worked like a champ for a long time. Hope this helps
Jul 15, 2011 | Motorola Two Way Radio
Cannot select gears on column shift 68 impala, stick very loose and does not move selecters on box , thanks
I would check the linkage going to the transmition, seems like they have come apart, disconnected.
Jun 08, 2011 | Chevrolet Impala Cars & Trucks
Only 1 of three transmits
You do not mention which model of TalkAbout radio you have, so we will correspond in general terms. If you have the user guide, read the section describing the "interference code eliminator" or "privacy code". Most likely you have the "code" set differently between the radios. Also, if your model has a Qt filter, set it to off (zero).
Best regards.
Apr 10, 2010 | Motorola Walkie Talkies 2-Way Radio
Transmition is not shifting in 1,2,3,d it stays in
Can you please confirm if the "N" light on your instrument panel, was flashing when locked in 3rd gear?
If so, was it flashing:
a) 1 flash per second?
or
b) 2 flashes per second?
Scott
Nov 12, 2009 | 2001 Mitsubishi Galant
Correct wiring for a ASTATIC TEARDROP MIKE to a RANGER RCI 2950DX
here is the info you asked for the following is the correct wiring.
Mic Wiring Info
Stock Mic Wiring
1. Ground Shield
2. Audio Yellow
3. Transmit Red
4. Receive Black
5. CH. Up White
6. CH. Down Blue
Turner 4-Wire MIC. Wiring
1. Ground Shield
2. Audio White
3. Transmit Black
4. Receive N/C
5. CH. UP N/C
6. CH. Down N/C
Turner 6-Wire MIC. Wiring
1. Ground Shield & Red
2. Audio White
3. Transmit Blue
4. Receive N/C
5. CH. UP N/C
6. CH. Down N/C
Astatic 4-Wire MIC. Wiring
1. Ground Shield
2. Audio White
3. Transmit Red
4. Receive N/C
5. CH. UP N/C
6. CH. Down N/C
Astatic 6-Wire MIC. Wiring
1. Ground Shield & Blue
2. Audio White
3. Transmit Red
4. Receive N/C
5. CH. UP N/C
6. CH. Down N/C
Mar 11, 2009 | Connex 3300 240-Channels Base CB Radio
Loss of power
I have always assumed this has to do with the level of the signal coming in.
I have had these headphones for a few years, getting them at a discount outlet for cheap, and have been quite pleased with them.
The light on the front indicates 3 things.
1) no light = not transmitting and not charging
2) green light = transmitting
3) red light = charging
When there is sufficient signal to transmit, the green light comes on.
If you are getting the signal from a Stereo, the line output may NOT be enough to keep the transmission on.
There seems to be a sensor, that figures out if htere is an incoming signal to transmit. I have toyed with the idea of locating that and disabling, so it would always transmit what is incoming, even if a low signal! But I don't have the know how.
As is, I use the headphones with my PC and generally it finds the signal strong enough to continue to transmit.
.. Thanks... Andrew
PS..The toughest thing about these haedphones, is going to be finding NiCad batteries to keep them working. If you go in the store these days, you can find lots of NiMetal Hydride, and NiCad are gone from the shelves!
Jun 13, 2008 | RCA WHP150C Consumer Headphones
Problem with Headphones
Can you pls add a few more details:
1. are the 2.5mm jacks stereo (3 pins) or mono (2 pins):
2. is your universal headset monaural or stereo; and
3. originally, did the universal headset came with 2 separate plugs?
At most that I can give you is a general/generic idea. The external speaker/microphone (or in your case the universal headset) uses also the charge jack, chances are that it is a multi terminal/pin jack. Pls refer to the diagram below.
The reason it is in continuous transmit is because one of the mini speaker is wired to the PTT trigger or the pins are wired wrong;
This would also explain why no transmit audio either manual or via VOX.
Hope this be of some help/idea. Post back how things turned up or should you need additional information.
Good luck and kind regards.
Nov 02, 2007 | Radio Communications
Motorola iTECH iQfive iQplus GP350 Compatible Two Way Adapters 2-Way Radio Logo
69 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
bill tarkulich
Level 1 Expert
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
