Question about Vacuums
Kirby Heritage II. Beater bar does not turn. One end rotates freely, but the other sticks, preventing the bar from rotating. No obvious means to disassemble the end of the bar. Is there a way to repair this, or does this require replacement of the beater bar? Did clean the front end assembly, and removed all hair, threads and similar obstructions.
    Novelist:
  • 152 Answers
The bearing is bad on the end that turns hard. You will need to purchase a new brush roll assembly. If the roller is older that 4 or 5 years, it should be changed anyway. The brush strips that scrub the carpet loose their strength after many years of combing through the carpet, so it's a good idea to change it every 5 years or so.
Posted on Oct 10, 2009
Testimonial: "Actually I had arrived at this same solution already. I have even ordered, received and installed the new beater br by the time I received this. "
My XV 11 Vacuum keeps on bringing up the message " My vacuum is stuck"
This message generally means that the beater/brush bar is not turning. Try rotating the beater/brush bar manually to see if it can turn freely. If not, you will need to remove the beater/brush bar and ensure that it is clean; that the orange end caps on the brush are free of hair and dirt, and that the bar housing area is free of obstructions.
Note, when I said "beater/brush", it could be either/or, depending on whether you're using the "standard" beater bar, or the upgraded pet brush.
May 31, 2014 | Neato XV11 Vacuum
Kirby roller
the brush bar has 3 settings marked on the end of the plastic clips that hold the bar in place make sure it is set to no 2 both ends,lay machine down and start roll should spin also check bar is free to move by hand
Jan 18, 2014 | Kirby Heritage II Vacuum
Installing new belt
+>> Unplug the mains lead from electrical socket <<+
• Turn cleaner over in flat position.
• Release lower plate by rotating the 3 lower plate latches to the UNLOCK position.
• Remove lower plate and remove any dirt that may exist in belt area.
• Remove beater bar by gripping the belt side of the beater bar and carefully lifting it out.
• Remove worn or broken belt.
• Clean beater bar and the end caps.
• Loop new belt around motor shaft and beater bar belt groove.
• Reinstall the beater bar by inserting the end cap of the beater bar to the slots at both ends of th beater bar.
• After reinstalling the beater bar, turn it by hand to make sure that belt is not twisted or pinched and that all rotating parts turn freely.
• Reinstall lower plate by hooking front end of lower plate into slots on front of nozzle.
• Press lower plate onto nozzle and secure by rotating the 3 lower plate latches to the LOCK position.
Jan 12, 2013 | Panasonic Mc-Ul594 Eco Max - Bagless...
Brushes not rotating on kirby vacuum
Change the belt, they stretch after while. If it made a burnt rubber smell or it's > 1 year old this is probably your problem.
Here's what you need:
http://www.vacuummedic.com/product.php?id=279
Good Luck!
Vac Dr.
Oct 15, 2012 | Kirby G4 Bagged Upright Vacuum
Hy, I have a dyson 14 that sometimes make a terrible racket when I am vacuuming rugs. This happens even after I've cleared the roller brush of strings, hair, etc.
Check the beater bar to see if it turns freely. It should spin real easy. If it takes just a little effort, your problem would be the beater bar is binding on one or both of the end caps. When the bar gets bound up, there is a clutch with three balls in it which slip in and out of their position which cause the loud noise you describe - like something is caught up in it. To solve, you need to remove the bottom plate and pull up one end of the beater bar - the end opposite the belt is easiest. Pull off the end cap (it just slides on. You may have to rotate some). If the shaft comes out, that's okay. That just means the shaft came out of the opposite end cap. Clean out both ends and reassemble. Before putting on the bottom plate, check to see if the beater bar turns freely. If it still makes the sound, I would suspect the clutch has a bad or broken internal spring. This would require repair or replacement of the clutch.
Jan 29, 2011 | Dyson DC14 All floors Bagless Upright...
Hi, My Kirby Ultimate G upright has very little suction. The engine sounds fine when turned on and the bag is not full at all. Suggestions?
In general, when the beater brushes on vacuum cleaners are not rotating, the debris on the carpet is not "bounced up" and into the suction area of the vacuum. With this in mind it might be a good idea to see if your beater brush or brushes are rotating freely. If they are not it could be due to the ends of the brushes being bound up where they meet the vacuum case or the belt(s) could be loose or broken. That would be the least expensive thing to start with. Please let me know if you have questions.
Sep 15, 2010 | Kirby Ultimate G Bagged Upright Vacuum
Replace belt
Take the head off the vacuum, look at back. You will see two metal latches, the latches hold the bottom of the head on. If the latches are stiff, you can use a small hammer to tap the in the right direction, don't go crazy. The bottom will swing away towards the front. The beater bar can then be pulled out and a new belt slipped on. Replace the beater bar, be sure to get the black ring at one end installed so it is line with the little light that tells you the bar is turning. Replace the metal bottom, if you have trouble getting it to seat check that you have the front side seated properly over the 'bumps' on the front of the head. Lock the clips back in. Turn the finger to catch & pick up the belt so you may place it back on the vacuum.
Ted
May 23, 2009 | Kirby Heritage II Vacuum
Why does the belt keep breaking on my kirby
Odds are that the problem is not with the belt or the pulley, but with an agitator (rotating brush) that isn't turning freely. Remove the rotating brush and check to see that it spins freely. If not, you would either need to disassemble it (removing the end caps) to see if removing whatever hair / diebris is stuck between the end caps and the body of the agitator, and if that doesn't cause free rotation, then it means your agitator bearings are likely bad which means you will need to replace the agitator assembly.
May 06, 2009 | Kirby G6 Bagged Upright Vacuum
Carbon Brushes wearing out quickly on Kirby Heritage II
4 possible reasons.
1 – one or both bearings are worn so armature (rotating part) wobbles as it is spinning and cause motor brushes to wear fast. Solution – change bearings too.
2 – Whoever replaced brushes – did not use some brush seating sticks to make cmutator smother and contour brushes to the shape of the comutator (not likely). Solution – appropriately install new set of brushes.
3 – Comutator is so warped that seating sticks do not help anymore – solution – new armature or turn the old armature.
4 – The fact that ONLY ONE brush was worn may mean that there is something wrong with the brush or housing. Maybe it could not move freely within the housing? I think this may be most likely cause it it may be a combination of all 4.Is it worth to fix? Hmm depends how much will it be. If this is 100+ - I’d say get newer Kirby for 300 ad enjoy the tech drive (Heritage does not have tech drive so it is much harder to vacuum with than the newer models)
Nov 05, 2008 | Kirby Heritage II Vacuum
Vacuum turns on and suction in hose works, beater bar won't turn
If you hear the motor in the head running and the beater bar isn't rotating, you probably need a drive belt. With the power off, make sure you can rotate the beater bar freely by hand, if it isn't bound up.. then locate and remove the baseplate screws to gain access to the beater bar itself, you'll see a drive belt pulley system and chances are, a broken belt. Replace it with a new one by pulling the beater bar assembly out of the housing and plcing the belt onto the motor shaft pulley as well as the beater bar pulley.. nest the beater bar back into the holder and reinstall the cover. Hope that helps !
Aug 14, 2008 | Eureka Vacuums
Vacuums Logo
169 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
