Home | Canon | EOS 30D Body Only Digital Camera | Canon 30D spots
Canon EOS 30D Body Only Digital Camera
Problem for Canon EOS 30D Body Only Digital Camera
Canon 30D spots
By wccanon on Dec 21, 2007
My Canon 30D has suddenly begun capturing dark spots when shooting scenery or interiors that have consistently blank color areas in the upper regions. I've tried cleaning the mirror, and it happens with each of my 3 lenses, so it can't be a lens issue. Any ideas?
Best Solution
posted on Dec 21, 2007
Helpful)
Sunriser
Rank: Master
Rating: 87%, 40 votes
It's 99% dust, especially if it appears mostly in smaller apertures (<f/8). To test it, select a small aperture (e.g. f/16) and take a photo of a blue sky. The spots will show consistently on the same location.
They're hard to clean, so chances are you just missed them. Try again, or, better still, send it for cleaning to a professional.
Was this helpful?
Yes
No
Solution #2
posted on Jul 23, 2009
Not Rated)
mojo1160
Rank: Apprentice
Rating: 0%, 0 votes
Dark spots showing up in the same place on every image indicate your sensor needs cleaning. Usually these are most noticeable when you have large areas of a single color. As the previous poster said, a blue sky is a good measurement. Your owners manual will detail the steps for cleaning, but my recommendation is that you take it to a Canon certified dealer and have it done professionally. Unless it's REALLY nasty, they shouldn't charge you more than a few dollars for the job, do it while you wait and you're on your way happy. Some places will even do it free as a way of building goodwill. You CAN do some very minimal cleaning blowing off the sensor with a squeeze bulb, but it rarely has much effect. Whatever you do, DO NOT TOUCH the sensor with a cloth, fingers, cotton swab, or anything else.
You can't avoid dust on your sensor, but you can supposedly minimize it by turning the power off when you change lenses. This cuts down on dust attracting static (or so the manual says). Can't confirm or deny since I never remember to do it.
Was this helpful?
Yes
No
Popular Solutions for Canon EOS 30D Body Only
Questions and Unsolved Problems for Canon EOS 30D Body Only
Do you recommend Canon EOS 30D Body Only Digital Camera?
Answer
Answer
When I try to view images on a tv the connection in the camera does not hold and the image does not... (More)
Answer
Describe your how to fix the light meter inside canon 30d slr Problem
Answer
after cleaning the sensor (with a bulb air cleaner) the high-speed setting no longer works correctly... (More)
Answer
after beep sound of focusing,shutter is not clicked
Answer
Same thing, all images are extremely over-exposed. When using flash, however, exposure is (more or... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Canon EOS 30D Body Only...:
Top Digital Camera Experts
Rank: Guru Guru
Solutions: 881
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Digital Camera Experts
Top Camera & Camcorder Repair
(915) 239-6199
CamerasAndParts.Com Specializes in the Service /...
CamerasAndParts.com
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
