Question about Canon PIXMA MP460 All-In-One InkJet Printer
Yes i do get blue stripes - Canon PIXMA MP460 All-In-One InkJet Printer
Does anyone know which colour does what for a madza demio stereo wiring harness
It sounds like the the ones with red and black stripes are possitive and negatives for your speakers then the others are positives also you would need a 12v test light to see witch wires have power to them and go from there
Sep 06, 2014 | Cars & Trucks
What are the coler s of the speeker wire for a 1996 ford explore
Right rear speaker Orange with red stripe is negative brown with a black stripe is positive Right front speaker Dark green with orange stripe negative white with light green stripe positive Left rear speaker Gray with light blue stripe negative Tan with yellow stripe positive Left front speaker Light blue with white stripe negative orange with light blue stripe positive
Aug 15, 2011 | 1996 Ford Explorer
Carradio pioneer DEH-171 i want to connect the wires for the speakers & found 4 different colors ... white, grey, green & purple & i suppose that the wires with black stripe are the ground....
white is left front
grey is right front
green is left rear
purple is right rear
blue is power antenna(if available)
blue with with stripe is amplifier remote(should have one if there are RCA connectors on the unit)
black is GND(ground)
yes you are correct. the stripes on the speaker cables are the GND
dreamsystems.
Feb 11, 2011 | Car Audio & Video
Tell me the color coding of wall jack to connect cat6 cable to the switch
You can use either T 568 A or B providing that both ends of the cable are wired in the same format. If one side is allready ended thenI would try T568 B standard first.
Pin T568A Pair T568B Pair Wire T568A Color T568B Color Pins on plug face (socket is reversed) 1 3 2 tip 60px-wire_white_green_stripe.svg.png
white/green stripe 60px-wire_white_orange_stripe.svg.png
white/orange stripe rj45plug-8p8c.png 2 3 2 ring 60px-wire_green.svg.png
white/orange stripe 60px-wire_white_green_stripe.svg.png
white/green stripe 4 1 1 ring 60px-wire_blue.svg.png
white/blue stripe 60px-wire_white_blue_stripe.svg.png
white/blue stripe 6 2 3 ring 60px-wire_orange.svg.png
white/brown stripe 60px-wire_white_brown_stripe.svg.png
white/brown stripe 8 4 4 ring 60px-wire_brown.svg.png
Sep 09, 2010 | Leviton (102-5G108-RW5)
Cat 5 cabling
Straight Cabling :
Side 1 Side 2
White Orange White Orange
Orange Orange
White green White Green
Blue Blue
White Blue White Blue
Green Green
White Brown White Brown
Brown Brown
Cross Cabling :
Side 1 Side 2
White Orange White Green
Orange Green
White Green White Orange
Blue Blue
Green Orange
Brown Brown
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 11, 2010 | Computers & Internet
Speaker wire colors
1991 Ford Explorer XLT Radio and Speaker Wire Colors
Pulled out the stock radio and found two plugs on the back of it. One plug had 7 wires (Power, Dimmer, Amp etc.) and one had 8 (Speakers).
7 wire plug (I could see these wires immediately from the plug):
Car Radio Battery Constant 12v+ wire = Light Green w/ Yellow Stripe
Car Radio Ground Wire = Black
Car Radio Accessory Switched 12v+ wire = Yellow w/ Black Stripe
Car Radio Dimmer Wire = Light Blue w/ Red Stripe
Car Radio Illumination Wire = Orange w/ Black Stripe
?? Don't know ?? Red Wire (No power to wire Constant or Accessory)
Car Radio Amp Wire = Blue
8 Wire Plug (Wires were wrapped in a grey outer sleeve, had to cut sleeve to get to wires.):
Right Front:
White w/ Green Stripe (+)
Brown (no stripe) (-)
Right Rear:
Purple w/ White Stripe (+)
Light Blue (no stripe) (-)
Left Front:
Light Green (no stripe) (+)
White w/ Orange Stripe (-)
Left Rear:
Light Blue w/ Black Stripe (+)
Yellow (no stripe) (-)
Speaker Wires (found at the individual speakers in the doors)
Right Front:
Green w/ Orange Stripe (-)
Right Rear:
Orange w/ Red Stripe (+)
Black w/ White Stripe (-)
Left Front:
Orange w/ Green Stripe (+)
Blue w/ White Stripe (-)
Left Rear:
Red w/ Green Stripe (+)
Red w/ Blue Stripe (-)
Aug 10, 2009 | 1991 Ford Tempo 4 Door
Yellow stripe across middle of the picture
yes rteh color of the wires(ends)red,blue,green,sounds like they may ahve gone bad or are interchanged, what does it do with a dvd picture
May 23, 2009 | Hitachi 42V710 42" Rear Projection HDTV
1995 Ford Windstar Speaker Coding Scheme.
www.installer.com as speaker schematics
Dec 22, 2008 | 1995 Ford Windstar
Wiring a new radio in 1991 ford explorer
Right Front:
Right Rear:
Left Front:
Left Rear:
Right Front:
Right Rear:
Left Front:
Left Rear:
Hope this helps. I spent hours looking for the correct color key and this one works for my '91 Explorer.
Feb 08, 2008 | JVC KD-G230 CD Player
Canon PIXMA  MP460 All-In-One InkJet Printer Logo
14 people viewed this question
old marine
old marine
