Question about Philips 42HF7444T 42 in. Plasma TV
Philips Plasma NO LIFE
Problem: A philips 42FD9954/17S Plasma tv set that has no picture. The set cannot be turned on by the remote or the power switch. The light at the power switch does not come on red or green. I have opened the back of the set and tested the fuses and they are good.
  • 3 more comments
  • mwnlan Dec 21, 2007
  • guitarbare Dec 06, 2008
    I have the same exact problem.. was working fine night before turned it off try to turn it on next day.. now nothing nada zip!! Which board is out?
  • Anonymous Jan 01, 2009
    I have the same problem except that the light by the power switch is red When I use the remote, it goes away briefly and comes back red.
  • Anonymous Feb 08, 2009
    I had the same problem (with 42FD9954/17S) that when turned on the unit, the green LED turned off and came back to red again some time later. I kept turning it on and once it went to a clicking relay sound and blinking green LED with it. It did that for a while and stayed turned on. I noticed that it is temperature sensitive. Colder the room is more often does it. Used a hair dryer and blown hot air into the unit at the left bottom grills. It helped and started to tun on quicker. Later it has deteriorated so bad that I took it a part and after several ice spraying test showed that on the middle big board (power board) there was an electrolyte condenser went bad. It is the one one which is at the middle, bottom center of the board near the fixing screw. There are two of them (cylindrical objects). The left one was the culprit. However when I fixed it, it turns on immediately but goes blinking red after that. Phillips say it is a static discharge problem. I might blown something when soldering the parts. I don't know what. Any ideas?
  • tul73 Apr 15, 2009
    I have a Philips PLASMA TV 42FD9954/17S 42" that does not turn on . I checked the web site solutions . TV worked for a few hours only and now is clicking relays again.
    power LED blinks red
Posted on Feb 08, 2009
2 Suggested Answers
eagle338
  • 4889 Answers
SOURCE: A PHILIPS 42FD9954/17S PLASMA
Does no picture imply that you have sound? Or it just turns on with no picture and no sound? Please clarify this info so that I can help you resolve you problem. It sounds like a audio/video mainboard issue. Just want to be sure.
Posted on Nov 24, 2010
Philips instruction manual
YOU NEED TO REPLACE BAD CAPS ON MAIN POWER BOARD 4167e67a-4c77-4574-ae00-a26d52afd0ea.jpg
Jul 29, 2014 | Philips 42PF5520 42 in. EDTV-Ready Plasma...
Power light but no picture or sound
Hi!
My name is Chris.
I have this Phillips Wide Screen TV that didn't have or come with a remote, so I had to go out and buy a universal remote for it today from a BIG W Store. I'm having some technical difficulties & problems with switching and turning it on, but as I use the universal remote to turn on the TV, I'm having a bit of a slight problem with it turning it on, Ok, Yes, it works and Powers on, but there is nothing showing or giving me the indication that there is no picture or sound showing up on this Wide Screen Phillips TV, But there is a little red & green light at the bottome right hand corner that keeps on flashing red when ever I use the universal remote to switch the power on. Is there a possibility, that i can get some help on here, to help me out with any suggestions, is to why I'm not getting any picture or sound showing up on this TV with this universal remote ? Is there anyway that i can maybe get some help with this to help me out with solving my issue with the Phillips Wide Screen TV ?
Nov 17, 2013 | Philips 42PF7320A 42 in. Plasma HDTV
Hi i have a magnavox 42" plasma TV (model
I'd look for the manual and see what it says about that red light. I can't find squat for "Magnavox KM42010P".
May 28, 2011 | Philips Magnavox MRD120 - home theater...
I have a philips model 50pfp5332d 37 We turned it on and it just clicks (like it is turning off an on) no picture, nothing. Will not respond to the remote or to the on off switch. Had to unplug to stop...
The tv power supply board is the causes and the problems.That the board,where the power a/c cord plug into it.Try website like Ebay.com to buy a whole refurbish power supply board for the replacement.
Nov 28, 2010 | Philips 50PFP5332D 50 in. Plasma...
42PF9630A 42 in. Plasma Television: hi there, I have a phillips 42 inch plasma flat...
This is because the power switch operated the socket that your TV is plugged into. Unplug it and plug it in another socket that is not operated by a switch. Appliances should not be plugged into a socket operated by a switch because of the inconsistency of power to the socket. Lights are about the only thing that should be plugged in.
Dec 23, 2017 | Philips 42PF9630A 42 in. Plasma Television
My Philips plasma only shows half the screen. The other half is just blacked out.
This model has PiP (Picture In Picture), find the button on the remote or check manual, this mode is most likely turned on and is being shared with one of the AV channels, or try turning on a plugged in SCART device to see if this picture shows on the other half of screen.
Sep 14, 2009 | Philips 50PF7320A 50 in. Plasma HDTV
My Philips 50pf9631d plasma tv turns on then red light blinks 7 times! Philips no help. Local electronics store wants $500 to fix! Set is only 3 yrs old! Please help.
Are you getting picture or sound at all? If not, you could have a very common power supply failure. If you get sound or picture, then you may have a faulty capacitor or resistor on one of the system boards
Aug 29, 2009 | Philips 50PF9631D 50 in. HD-Ready Plasma...
I need help tv plasma phillips
There is a firmware that can be updated via usb from philips. This fw was used to correct the tv powering on with no picture randomly (they called it a maintence session) but it was a problem. The tv would power on on its own and do this..
If that doesnt take care of your problem then the problem is with the main control board. or ssb
Aug 01, 2008 | Philips 42PF9630A 42 in. Plasma Television
Philips 42HF7444T 42 in. Plasma TV Logo
517 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
