Question about Hoover F6212-900 / F6215-900 SteamVac Agility Upright Vacuum
Brushes won't roate - Hoover F6212-900 / F6215-900 SteamVac Agility Upright Vacuum
    Scholar:
  • 190 Answers
(1) Assure the Brush Control on the hood is NOT set to the OFF position.
(2) Remove the brush assembly by pulling/unlatching it from base on each side.
(3) Does one of the brushes have the drive pin present? It should be about ¼ inch square, and two inches long. It attaches the brushes to the drive mechanism.
(4) Remove and clean the intake filter. One the base of the cleaner, behind the brushes, squeeze the two red abs together and pull the panel down to access the screen. Clean the hair/debris off the screen and reassemble.
Posted on Oct 03, 2009
Troubleshooting
Hi Janet. Thank you for asking this question. Your vacuum wasn't designed with a brush on/off switch so having the brush continually spin is normal for your vacuum.
Jun 29, 2013 | Bissell 3576 CleanView II Bagless Upright...
Brush won't turn on my Panasonic MC-CB467
There should be a safety reset button. So like if you suck up a rug it will shut the power to the brush roll off, then reset it.
Nov 14, 2012 | Panasonic MC-CG467 Bagged Canister Vacuum
Dyson dc25 off button won't turn off, brush button won't engage brushes
Hi ... did u get this fixed cos mine is the same hve to switch off on the wall?
Sep 22, 2012 | Dyson DC25 All Floors Bagless Upright...
Dyson DC41 brush won't spin
You need to check the belt hooked to the side of the brush (sometimes hidden by plastic)
Jun 26, 2012 | Dyson Bagless Upright Vacuum DC41 Animal
Why won't my brushes turn
most likely stripped gears on the end of the brushes. (beltless model?)
Nov 21, 2011 | Hoover WindTunnel V2 U8148-900 Upright...
Shark SV736R motorized brush won't rotate
The 2 metal pins of the motorized brush are not in contact with the vacuum cleaner. or the Motorized brush is clogged up. You have mentioned that it is cleaned, but still give a thorough inspection. For the metal pins, firmly insert the motorized brush into the air-intake nozzle. This will connect the motorized nozzle to the unit power supply.
Oct 21, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Brush won't turn
There is a good chance the belt is broken. The reason belts break is because the brush seizes up due to hair wrapping around tight at the ends of brush. Inspect closely with a flash light to check for this.
Aug 18, 2011 | Sebo X4 Bagged Upright Vacuum
The brushes won't spin. I put new brushes on and it still doesn't spin.
Usually when the brushes won't turn it is due to a bad turbine. Insert a screwdriver into the square hole that the pin on the brush fits into, and see if it turns. If it is seized up, the turbine assembly will need to be replaced.
Jun 28, 2011 | Hoover SteamVac F5914-900 SpinScrub...
My hoover carpet scrubber the brushes won
(1) Remove the brush block and assure the presence of the square drive pin on top of one brush. It should be about 1/4 inch square, two inches long to connect o the drive mechanism.
(2) Remove and clean the filter screen from the base, behind the brushes. Squeeze the two red tabs together, and pull down from the base. Clean the hiar/debris from the screen.
(3) Assure the Brush Speed knob on the hood is NOT set to the OFF position.
Aug 30, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Rotating brushes will not turn
If belts are ok then possibly needs new front brush motor replaced.
Nov 05, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Hoover F6212-900 / F6215-900 SteamVac Agility Upright Vacuum Logo
159 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
