Question about Canon MX300 Office All-In-One Printer
Color is faded - just installed new cartridges mx -300
  • 619 Answers
SOURCE: color fading
Hi , the printer are dried up need head cleaning twice then test print , if color of test print are complete color no spaces ,it means head are clean .
Posted on Jan 23, 2008
mattozan
  • 555 Answers
SOURCE: HP 2605dn laser - color fading
HP has a list of troubleshooting steps you can go through for the HP 2605dn when you experience print quality issues.
Two specific things I would try from that list are:
  1. Clean the electrostatic transfer belt.
  2. Clean the printer paper path.
Good Luck!
*If you find the solution helpful, please rate it!*
Posted on May 15, 2008
SOURCE: Kodak 5300 printer
every time I print it comes out purple it can be color or duo tone or black and white what d o I need to adjust?
Posted on Aug 16, 2008
SOURCE: ASKING INSTALL COLOR CARTRIDGE
I solved it. Firstly clean cartridges peak and the place that cartridges seated on plotter,be sure that the cartridges click into place properly. Propel the cartridges byhand. Then test and align the cartridges it will work!!
Posted on Dec 16, 2008
RPFinney
  • 385 Answers
SOURCE: color cartridge does not work - color faded. Just replaced AGAIN today - same problem
Remove it,replace it couple of times.
Run a nozzle and printhead cleaner check,
from your printer's properties, maintainance.
align too, just to be sure your setup correctly.
Check your printer settings for quality of the print.
there are various choices there for you.
Should be good then
Regards
Richard.
Posted on Apr 21, 2009
Hp laser jet 300/400 10.1000error
10.10 error means it does not recognize the chip on the cartridge or that the seal is still in cartridge need new cartridge
Feb 24, 2015 | HP LaserJet Pro 400 color M451dn - Printer...
Why is my printer not printing the right color? its very faded
Is your printer set to Economode in the printer settings? It may be and so its printing at low quality.
Jul 16, 2014 | Xerox Phaser 7400DN Laser Printer
Installed new ink cartridges mx 300, compatible B&W 40, color 41, printer status still says low ink, printing as if it is low ink. properly installed, tape removed, what i miss? can I check something...
Do you know what?. As a matter of fact,it is not compatible cartridges you buy. It is refurbished cartridges that repackaged with other brand as if this is their product. I say it is original cartridges that once empty and repackaged. So that's why when you install the cartridge the ink level stays low. You can make it sure by comparing it with new original cartridge. Find original cartridge,may be you can borrow from someone,which ink level still full and install on your printer. I am a hundred percent sure ink level will show properly :).
Feb 19, 2011 | Canon MX300 Office All-In-One Printer
Samsung CLP-300: Black print is fading replaced black cartridge twice all the other colors print fine
Dear,
This is a problem with a black developer. in the imaging unit. Kindly approach authorised service center. they will change for you.
Sep 27, 2010 | Samsung CLP 300 Laser Printer
I have the machine fax Canon Pixma MX 300. It writes "Recommend new C-CRT". Please, explain me what it means.
If the machine is a color printer it may mean Recommend new Color Cartridge. The color cartridge may be low on ink or defective.
May 18, 2010 | Canon MX300 Office All-In-One Printer
While printing in black middle of page fades out both sides of the page print well. this is about a 1 inch fade out in middle of page.
Replace the drum of the particlular color cartridges. To know which color you have to print in single color one by one. If problem persist then replace transfer belt .
Jan 05, 2010 | Samsung CLP 300 Laser Printer
Faded on left hand side
If it only happens with the black then you need to change out the black toner cartridge. The good news is isn't doesn't happen with color so it more than likely not the printer but the toner.
Jan 09, 2009 | Samsung CLP 300 Laser Printer
Color change
I'm not being eble to install my priner Z605
Aug 20, 2008 | Lexmark JetPrinter Z605 Color InkJet...
Faded or no printing of documents
First, have you removed the protective tape from the bottom of the printer cartridge? I know it sounds simple, but it's something easy to overlook when you install a new cartridge.
Jun 15, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Hey m8
  • Buxie, first off you have voided your warrenty, secondly
  • If marks repeatedly appear on the printed side of the
    page at even intervals:
    • Clean the inside of the printer. See “Cleaning the
    Inside of the Printer” on page 5.7. After cleaning
    the inside of the printer, if you still have the same
    problems, install a new toner cartridge of the
    problem color. See “Replacing Toner Cartridges” on
    page 5.3.
    • Parts of the printer may have toner on them. If the
    defects occur on the back of the page, the problem
    will likely correct itself after a few more pages.
    • The fusing assembly may be damaged. Contact a
    service representative.
  • If horizontally aligned color or black streaks or
    smears appear:
    • A toner cartridge may be installed improperly.
    Remove the toner cartridge and reinsert.
    • A toner cartridge may be defective. Install a new
    toner cartridge.
    • If the problem persists, the printer may require
    repair. Contact a service representative.
  • SXPRESS- It is normal to have to replace it after that because the starter cartridges are rated for 1500 pages but that is at only 5% page coverage and most people print alot higher coverage than that, and the replacements cover 2000 pages again @ 5% page Coverage
May 20, 2008 | Samsung CLP 300 Laser Printer
Canon MX300 Office All-In-One Printer Logo
26 people viewed this question
old marine
old marine
