Question about Hitachi 50SBX78B 50" Rear Projection Television
Composite vdeo I get Squigly line when I try to plug in my HD receiver using Y B R inputs
  • 1,153 Answers
You can get more info at
Posted on Dec 21, 2007
Where do I plug in headphones?
Looking at the specs for your TV, it does not appear to have the jack for earphones.
You will have to connect an audio receiver to your TV and use the reciever's jack.
  • HDMI ports qty4
  • PC interfaceVGA (HD-15)
  • Input/Output connections3 x HDMI (19 pin HDMI Type A) - Rear,
    1 x HDMI (19 pin HDMI Type A) - Side,
    2 x Component video input (RCA phono x 3) - Rear,
    1 x Composite video/audio input (RCA phono x 3) - Side,
    2 x USB (4 pin USB Type A) - Side,
    1 x Ethernet (RJ-45) - Rear,
    2 x Audio line-in (RCA phono x 2) - Rear,
    1 x VGA input (15 pin HD D-Sub (HD-15)) - Rear
  • Video interfaceHDMI,
Jul 14, 2012 | Samsung PN50B650 50-Inch 1080p Plasma HDTV
Can I use a HD receiver as input for the Toshiba XS35? Will it record HD signals? Will it record anything if the receiver is HD? I want upgrade my exisitng Bell Canada TV receiver box to HD - can I...
Yes you can record any TV show HD or SD, however it depends on what connections you use and what the recorder does with the input signals. You can record HD shows but not in HD resolution if you connect using composite video (yellow RCA cable) you just get a down-converted resolution, probably 480. You must use a HDMI or a component video connection for HD BUT if the recorder cannot record HD video, it should just record it in SD resolution but it should record the input signal. DVD is not HD, you would have to go to Blu-ray for HD and there are not many Blu-ray recorders around. The hard drive has the potential to record in HD but the recorder would have to process HD signals and you would have to connect with HDMI or component video. I would say your Toshiba will record an HD show but in SD resolution. I don't think the recorder has an HDMI input or a component video input. Just composite and S-video inputs. To actually record in HD you should look at another recorder.
Mar 19, 2011 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
I am plugging in a satellite receiver, which coax input do I use and what source setting? Thanks!
If your using HD, then use the RGB component input 1. or AV 1 if your not using HD.
Dec 18, 2009 | Protron PLTV-37 37 in. LCD Television
What is the best way to hook up my HD Mitsubuishi TV to a satellite receiver to get the best picture quality? I just recently got the HD receiver. Do I receive HD automatically through the receiver. I have...
The best picture would be with the composite connections which is the red, blue and green plugs. when using these plugs you will also have to connect seperate audio cables for the sound. Then select the proper input on the tv.
Nov 03, 2009 | Mitsubishi WS-55809 55" Rear Projection...
I would like to know if I can connect a HDMI cable from My tv model WS-65315 to a Direct TV HD receiver?
NO> If your TV supports and have HDMI connections and your HD receiver has an HDMI output then you should have no problem displaying Video. Just make sure you change the input signal of your television to HDMI input. After looking at the spec's of this model these are the following inputs you have. your best picture quaity would be to use componet cables instead, which can show full screen 1080i format, your television does not show at 1080p whis is what HDMI is known for.
Rear Input Connectors S-Video x 2 - Component x 3 - Composite x 2 - DVI x 1 - RF x 2 - 1 x RS-232C - Audio (RCA) x 6
Front Input Connectors S-Video x 1 - Composite x 1 - Audio (RCA) x 1
Rear Output Connectors Composite x 1 - Audio (RCA) x 1 - RF x 1
Another good option is use to use a DVI to HMDI connector and hook it up this way. But note: you will have to use audio cables for the DVI input.
Sep 28, 2009 | Mitsubishi WS-65315 65" Rear Projection...
Samsung HCL5515W...when using coax input pic convergence is off, red and blue seem off....when I use the component inputs it constantly flickers between the squigly lines and picture with convergence off?...
on component your device may have to be on progressive. old dvd players you could switch back and forth on progressive and normal. the squigly lines sound like you need to make sure its on progressive. hook it up using the yellow video slot on player and tv (any cable will work). go into menu and look for progressive and change it on.
Jul 14, 2009 | Samsung HCL5515W 55" Rear Projection...
Video 4 not working properly
9 out of 10 times, the problem is the device that is hooked up to the TV, and not the TV itself. This is especially true in the case of cable boxes, which have a long history of failures.
Temporarily, you can probably hook up the composite (yellow red and white) cables to get a picture and sound on a different input.
You can try to hook up a DVD player on the inputs (component, I'm guessing) and it will probably work. Then you get to call the cable company!
Hope this helps...
Jan 09, 2009 | Sony FD Trinitron WEGA KV-36FV27 36" TV
Video issues w/ Pioneer VSX-816 AV Receiver
Receivers generally cannot or will not convert from one input type to a different output. That's not to say there may not be some high end models around that do that.
I have this receiver and have it setup as follows. Monitor out Component, S-Video, and the Composite video channel (since I have surround sound I have no interest in getting audio to the TV since I keep its speakers off anyways) to their different inputs on the TV. Warning on some TV's if you plug in S-Video you cannot then use composite on that same input channel as it will override and disable the composite. Then you only need to choose the appropriate input on the TV when you switch sources. In my case Tivo is S-Video, DVD is component, and most of my older video games and VCR are composite.
Having a TV that allows you to change the labels for the input channels is helpful with teaching others that may be less adept, or a snazzy remote that you can program to do everything at once.
Aug 30, 2007 | Pioneer VSX-816-K/S Receiver
Video input from dvd player shows as black screen w/ squigly color lines
have you tried other devices for input...vcr, or other dvd players to see if it is a problem with the player or with the tv? Check the output setting for the dvd player (1080i etc) and ensure you are connecting to the proper inputs for either analog or digital signals (RCA inputs or RGB).
Aug 15, 2006 | Hitachi 57S715 57" Rear Projection HDTV
Televison & Video Logo
26 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
