Just moved house and re-plumbed up the washing machine Whirlpook AWO/D 4605 & did a rinse/drain to check and it stops on drain and the red light comes on the ''Clean pump'' indicator. I have checked the impeller and seems to be clear and spins fine. Tried it quickly open so I could see it spin. Any ideas how to solve this ? Many thanks.
  • rcscott435 Oct 03, 2009
    I just popped the flexible hose over the new long pointy plastic connection on pipework (the sink coupling ?) & tightened up the metal band. You saying I should cut that long pointy bit shorter to allow for a bigger opening ?
    Thought the hole in the end was sufficient. Brilliant, many thanks, will give it a go later when I get home. Ta.
    Genius:
  • Washing Mach... Master
  • 1,466 Answers
Make sure sink coupling has been cut to allow flow of water also , hose not kinked....
Posted on Oct 03, 2009
  • Gerry Harvey
    Gerry Harvey Oct 03, 2009
    Yes it need to allow water to flow..away
  • Gerry Harvey
    your most welcome ..hope you sort out.
When on spin the drum bangs is there a burning AWO/D 4605 ser end 104
Sounds like its just out of balance, the feet(1 at each corner) should have threads so you can balance it better by unscrewing or screwing back in as needed. Place a level on top of washer and see how out of balance it is and what corners you need to raise
Sep 24, 2012 | Whirlpool Washing Machines
Whirlpool washing machine AWO/D 5556 washing machine service light showing ?
The warning light comes on because the machine "thinks" that something is wrong. Since it stops on and off something is wrong.
Why not phone the Whirlpool service in your area and tell him aboout this and ask what you can do??
give it a try
Kolbrun
Feb 22, 2012 | Whirlpool Washing Machines
Water coming out of hose at home plumbing
Hello.Maybe the drain is blocked.it sounds like your machine is working ok to me,if you can hang the hose over the edge of a laundry tub & make sure the plug is out,see if the water drains away,otherwise it sounds like a plumbing problem not the machine.it started only after you moved houses so more likely the plumbing.hope i helped.
May 28, 2010 | Maytag HAV2557 Top Load Washer
Whirlpool AWO/D 4605 Clean Pump light on, how do I
Remove bottom plastic panel across the front of machine- it just clips off (use a small screwdriver or bread knife to prise off). You will now see a round filter behind this panel- unscrew anticlockwise to remove- this is the filter. Sometimes filter can be hard to remove if you have things jammed in it- give it bit of a jiggle and it should come out without forcing it. Remember- if there is still water in the machine, this water will come out on the floor once you remove the filter- put down some towels!! Happy fixing!!
May 11, 2010 | Whirlpool AWOE8748 Front Load Washer
Whirlpool washing machine say clean pump/ modal awo/d 4605 how do i do that?
Unplug the machine.
Remove the bottom front panel.
The pump will be directly in front of you. Twist and pull and the pump filter will come out.
Jan 07, 2010 | Whirlpool Washing Machines
Bosch wfr2460
The 03 error code is the drain. Disconnect the drain hoses and check for blockages. If no blockage "time" the drain interval. If it's more than 6 minutes it's the pump. Also make sure you're using the correct type of soap so the ball check valve on the bottom of the outer drum isn't getting fouled with excessive suds. Also disconnect the drain hose from your house plumbing and let it free flow on it's own. This will tell you if the block is in your plumbing, and not in the machine. Assuming that your filter is clean.
Pl rate me ‘very helpful’ for the free help!
Dec 01, 2009 | Bosch Axxis+ WFR 2460 Front Load Washer
My washer will not drain...it fills up and then stops no drain no spin
hi
if it fills then stops working,no washing motor action then you may have a motor or pcb fault,check motor brushes and connections.if it works fine upto rinse and dont drain check filter for blockage or drain pipe if plumbed to sink.
Aug 02, 2009 | Indesit W 123 Front Load Washer
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Freezer before Rinse
you hav'nt said if it drains. the problem just may be that you have plumbed drain hose onto a spigot on the sink drain and spigot is blanked off
Apr 24, 2007 | Creda W120VW Front Load Washer
Washing Machines Logo
195 people viewed this question
Top Washing Machines Experts
