Question about Toshiba Satellite A135-S4527 Notebook
My A135-S4527 will not turn on. When i first tried to turn it on after noticing that it was off the power button and LED on the front would light up for a second and then go right back off. It did that a few times and now it doesn't do anything. There is no LED light when it is plugged in. My daughter had left her flash drive in one of the USB ports and it blinks when the charger is connected to the laptop but that is the only sign of life from it. Any advice would be greatly appreciated!
  • 153 Answers
Check for the adapter wether it is working properly .....ma be it has failed and your laptop isn't charging and the battery has gown down ....
regards
Posted on Oct 04, 2009
Toshiba A135-S4527 starts to power up then shuts down.
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Mar 08, 2012 | Toshiba Satellite A135-S4527 Notebook
My Satellite A135-S4527 will not power up. I press the power botton it lights up in color blue (as normal) and the power on LED indicater lights up. This will stay on for appox 10 sec and goes off. No HDD...
check your power fan of your processor underneath on the laptop, possible cause is overheat, bring it to the shop for whole diagnosed.. if you continously used on that situation it might cause some problems to other parts due to overheating..
Aug 27, 2011 | Toshiba Satellite A135-S4527 Notebook
What do the various led light colors mean? I have
The LEDs each indicate something is conected or normal. There is one for hard drive activity, power, battery, and wireless. Blue is good. Orange is bad. First take the charger to a shop to have it checked. If bad replace it. If good the the problem is either battery or the connector on laptop. Since the battery is new it sounds like the connector to me.
May 01, 2010 | Toshiba Satellite A135-S4527 Notebook
Toshiba A135-S4527 will not boot
Could be power supply (ac block and power cord) is dying or died. Laptops are notorious for this.
Aug 01, 2009 | Computers & Internet
Problem with toshiba A135-S4527 ,MOTHERBOARD NOT INITIALIZING
Have you left a cd in drive? It could be trying to read a disk to boot from if thats how your boot order is set up. This is the first simplest thing to check.
Char S
May 24, 2009 | Toshiba Satellite A135-S4527 Notebook
While turned off..You could take out the CD/DVD drive, HD, all the memmory(1 or 2 modules) and If you know how, even BlueTooth and modem and WLAN mini PCI/PCIE modules. Then try to start it. If you hear 2 beeps followed by any other numbers of beeps(2_x_x)...then you can be rather glad that your motherbord (still maybe!) works ok. If you hear other kombinations of numbers of beeps(1_x_x, 3_x_x or 4_x_x) then you may have problem with the motherboard :( .. in case you hear the 2_x_x beeps you have a memory problem..shut down the laptop...now put only one of the memory modules(if you have 2) and boot up...if you get the picture you should be able to see any BIOS POST warnings/error messages..if you still hear the 2_x_x beep comb. you have a memory problem..then you should buy a new memory! if you dont see any picture on the screen it could be the Graphics card problem or yet another indication to memory problem...if you get sure that the memory and the motherboard are ok then put in the components back in and boot after each to figure out witch part is problematic...
/BS
Feb 03, 2009 | Toshiba Satellite A135-S4527 Notebook
Toshiba's A135-S4527 Battery isn't working anymore
Have the battery checked or better yet, replaced. Prolonged use might damage the charging circuitry of your machine.
Jan 11, 2009 | Toshiba Satellite A135-S4527 Notebook
Toshiba laptop power light on but not working
Try this.Your VGA is problem or your battery is fully charge down.so please fully charge your battery atleast 8 hours and then press your power switch.it will on your loptop system.
plz Call 09944377607 V.RAJA
Jul 25, 2008 | Toshiba Satellite A135-S4527 Notebook
Laptop stuck in sleep / hibernate mode??
Try holding the power button down for at least 10 seconds, that should turn off the laptop completely. Then press the power button again to turn it on. Hopefully it will boot up.
May 14, 2008 | Toshiba Satellite A135-S4527 Notebook
My toshiba satellite a135-s2276 won't turn on
A coworker used to work for Toshiba and said that this is common for the Satellite A135 models and under warranty the fix was a motherboard swap for a newer/updated motherboard. Otherwise the unit is unusable.
Dana
Jan 24, 2008 | Toshiba Satellite A135-S2276 Notebook
Toshiba Satellite A135-S4527 Notebook Logo
139 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
