I LOADED SOME CLOTHES FOR WASHINH. WASHUNG CYCLE IS NOT COMPLETE. iT BLEEPS THREE TIMES AND i AM UNABLE TO OPEN THE DOOR
    Genius:
  • Washing Mach... Master
  • 1,474 Answers
Check no water in machine if yes , check clean filter
Posted on Oct 03, 2009
Is there any kind of recall on a Maytay front loading washer, model #MAH6500AWW? I am having problems with mildew in the rubber part and terrible smelling water in the bottom.
The cleaning process for your Maytag Neptune front-loading washer, for example, requires some time and patience. Over time, your washing machine will need to be cleaned. It can develop offensive odors through multiple wash cycles. This makes the washing machine less effective at cleaning the clothes you put into it. Maytag offers some sound advice for cleaning your front-loading washing machine.
  • Pour 2/3 cup of liquid chlorine bleach into the bleach compartment of the dispenser drawer of your Maytag Neptune front-loading washer.
  • 2
    Run your Maytag Neptune front-loading washer on the "Clean Washer" setting. Press "Start" to start the cycle.
  • 3
    Leave the door open once the cycle is complete to allow the inside of your Maytag Neptune front-loading washer to ventilate and air dry.
  • 4
    Look closely at the gray seal of the Maytag Neptune front-loading washer's door opening. This seal can have a buildup of debris or detergent residue.
  • 5
    Spray the seal with an all-purpose appliance cleaner and scrub away any debris or residue with a cloth or scrubbing pad. Dry with a clean cloth.
  • 6
    Remove the soap dispenser drawer. Press the release lever and lift it out to clean.
  • 7
    Take out the inserts and rinse them and the drawer thoroughly.
  • 8
    Wash with a mild soap and cloth to remove any residue. Dry thoroughly before replacing.
  • ALWAYS LEAVE THE DOOR OPEN WHEN NOT IN USE! This prevents the mold and mildew from forming once you get it cleaned.
    Aug 20, 2011 | Washing Machines
    I have the Kenmore front load washer HE2. How do I use the clean washer cycle.
    Hello, welcome to FixYa.
    In order to perform a "clean" on the HE2 is as follows...Read these instructions completely before beginning the cleaning process.
    **If necessary, the cleaning cycle may be interrupted by pressing STOP. This will stop the cycle. A RINSE/SPIN cycle must then be run to thoroughly rinse the remaining bleach from the unit. Failure to do so will cause damage to the unit and clothing added to the next cycle.**
    Begin procedure
    1) Open the washer door and remove any clothing or items from the washer.
    2) Be sure the door is closed.
    3) Open the dispenser drawer and immediately add 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment.
    NOTE: Do not add any detergent to this cycle. Use of more than 2/3 cup (160 mL) of bleach will cause product damage over time.
    4) Be sure dispenser drawer is closed.
    5) Select the CLEAN WASHER cycle.
    6) Press START.
    NOTE: The basket will rotate, then the door will unlock, lock again, and then the cycle will continue. The machine will not fill, but the basket will rotate while the washer runs a short sensing cycle. This will take approximately 3 minutes.
    7) The cycle will determine if clothing or other items are in the washer. a) If no items are detected in the washer, it will proceed to step 8. b) If any items are detected in the washer, all cycle lights will flash and "rL" or "F/34" will be displayed. Associated LED status lights will remain lit. The door will then unlock. Press STOP to cancel the failure code. Then repeat steps 1, 2 and 6 to start the cycle again.
    8) Once the cycle has begun, allow the cycle to be completed.
    9) After the cycle is complete, leave the door open, slightly, to allow for better ventilation and drying of washer interior.
    Good Luck and thank you for choosing FixYa. Please take a moment to rate the info I provided and a short testimony is appreciated.
    Regards,
    Macmarkus :)
    Aug 14, 2011 | Kenmore HE2 Plus Front Load Washer
    I load the clothes into the washing machine, I turn it on select cycle and the door locks and will NOT unlock. The door will however unlock after the cycle is finished.
    Not sure if you're unable to open the door AFTER you stop the cycle. That may be normal operation as a safety measure (won't open until after your cycle has completed). However, if your model DOES allow for opening the door during cycle operations then your electronic door lock may be defective.
    Mar 08, 2011 | LG WM-2277HW Front Load Washer
    Washer smells like mildew after a load of wash, clothes smell.
    Use a washer cleaner like AhFresh (all three tablets) with the tub clean cycle, no clothes in the washer. Now, only use 1 to a maximum of 2 tablespoons of HE laundry detergent per cycle. Due to low water consumption of these machines, you must adjust soap usage or odors will result. It may also help to leave door open for a hour or so after cycle is finished to allow inner tub to dry completely.
    Jan 12, 2011 | LG WM-2277HW Front Load Washer
    Mold build up around ribber gasket . Heavy, black and hard
    Front load washers are notorious for developing mold/mildew to build up because they retain a lot of moisture in the round gasket the door closes into. Wash it down with a 50:50 soulution of bleach and water. You may have to use a brush on the "hard" stuff. Occasionally, run a quick load with no clothes and just bleach through a complete cycle in the washer. After a heavy day's washinh, leave the door open a little to help dry it ou.
    May 28, 2009 | Washing Machines
    Spin mode does not work
    Dear "FixYa,"
    I have fixed the problem with my washer.
    I started clothes washing machine with one load of clothes.
    Wash and rinse process completed, as it came to spin,
    Machine stop, only I heard was running motor. I opened
    machine and found coupler is cracked (broken) and was
    unable to rotate the gear.
    I replaced new coupler and machine started to work normal.
    Thank you
    Kanu
    Apr 18, 2009 | Whirlpool Washing Machines
    During the drying cycle, the dryer door opens
    Chances are the little plastic latch keep is broken. Look at the door and locate a peice that will press into the front area where the clothes go in.
    Once you see it, check the keeper and see if it is broken. The door should not just pop open.
    Feb 25, 2009 | Dryers
    Maytag epic front loader
    Suggestion: Check the wall inlet to see if water comes freely; then check if the inlet valves behind your machine to see they are not clogged. Best that u open the valve full before you begin your wash. The water coming 3 inches/door is normal. Dont try opening the door until after you hear a click or aft 2 or three minutes aft wash cycle completes.
    Sep 11, 2007 | Washing Machines
    Washing Machines Logo
    20 people viewed this question
    Top Washing Machines Experts
