Question about HP LaserJet CM1017 MFP All-In-One Color Printer
It is printing bright blue streaks all over the
It is printing bright blue streaks all ovr the paper. Ink cartridges are half full so they should be OK. Ran cleaning cycle and that didn't work. HP Color LaserJet 1017.
Forget the answer above, this printer is a laser jet and dipping anything in water will certainly stop it working.
Posted on Jan 19, 2010
    Sergeant:
    Champion:
  • 240 Answers
Are they separate ink cartridges or just one with 3 colours in? If they are all in one cartride either the printheads are blocked or the other 2 colours have run out and only blue remains. You can remove your cartridge and clean the printhead by dipping it in a small amount of hot water until colour runs out through it-if this doesnt work then it has run out.
Posted on Oct 03, 2009
Cannon Pixma MG5520 printer
Remove all cartridges, clean the ink from where the cartridges make contact with cloth,(paper towels can leave trash in there) be sure all is clean then replace the cartridges and print something. Those streaks shouldn't be there any longer.
Sep 09, 2014 | Office Equipment & Supplies
I am trying to print and nothing comes out on paper. cartridge black half full and color full and it will not print anything from an open document to a new document with some typing on it. lexmark z600...
Try to clean the print cartridge nozzles. On your computer, go to Start menu > All Programs / Programs > Lexmark Z600 Series > select Lexmark Solution Center. From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a clean test page forcing ink through the cartridge nozzles and clean them. Try to print your document again and to check if print quality is achieved.
Jul 25, 2011 | Lexmark Z600 InkJet Printer
I have a Lexmark P3150 printer. It worked fine last time I used it but it has been several months since I have used it. I am now trying to print and cannot get it to print either in black or a color. I...
Your ink cartridge nozzles may be clogged. You may try to do a cleaning cartridge nozzles cycle.
Open the Lexmark Solution Center. Click on the Maintenance tab. Click on Clean to fix horizontal streaks. Click on Print. Depending on the diagonal lines results, you can click on Clean Again.
Jun 05, 2011 | Lexmark P3150 All-In-One InkJet Printer
Leaving black streaks down paper? Ink cartridge
If this started after cartridge was replaced, then it is probably defective.
Take the cartridge out and take a look at the print head. Clean the print head.
Put the cartridge back in
Try and feed paper (not printing anything on it, if you can not get it to just feed paper, print a blank page) and see if it still has lines. If so, you are probably going to have to clean ink from inside the paper feed area. If not, try using it for a while and if it starts again, get a replacement cartridge. You might want to save some of the bad prints to show the clerk and try to get the new cartridge under warranty.
Mar 18, 2010 | IBM Infoprint 1612 Express Printer
I just put a new ink cartridge in and it's printing in blue streaks after several tries. What do I do?
Remove the cartridge
Take a cloth or paper towel and lightly dampen with warm, distilled water.
Fold the towel in half twice and hold in the fingers of one hand
With your other hand, gently "Blot" the cartridge by pressing the printhead into the towel a few times.
Insert the cartridge back in.... Try this!! hope it works!
Feb 02, 2010 | Epson PictureMate Photo Printer
Canon Pixma iP4600 not printing cyan
I had the same problem and I finally FIXED IT. I first tried replacing cartridges - no good, I then took the print head out, dismantled it and washed every component, no good. I then noticed that there were small streaks of blue on the paper when I tried to print a blue image so I worked out that the blue ink is getting through, but very slowly (yours might not be getting through at all but don?t worry this should still fix it). So I got a very thin pin and pushed it into the cyan pad on the print head creating a thin channel for the ink. Tried to print again, perfect, blue now working. Hope this helps - remember, you do this AT YOUR OWN RISK, there is no guarantee this will work for you, it worked for me but there is the obvious risks that you may break your printer. I did it because it was broken as far as I was concerned and I had nothing to lose if it broke completely, you must make that choice yoursel
Aug 25, 2009 | Canon PIXMA iP4600 Color InkJet Photo...
Faded-out streak
check your ink levels. if its the ink that came with the printer it is probable running out of ink. they do not give a full cartridge with printers, only about 3rd full. also try cleaning the heads. and try changing your printer settings/prefrences to less ink, more drytime see if that helps.
Apr 26, 2009 | HP LaserJet 1018 Printer
Streaks down middle of and rainbow colors on top of printed pictures
hi dear
this the error code
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber full
First, download the software at http://www.box.net/shared/4yblbn34kg
Secondly, to run the software your printer has to be in service mode. Do that by
- unplug cable
- press and hold "power" button
- plug cable
- press "resume" and release
- release the "power" button
At this stage, your computer will detect a new hardware
Run the software.
or you can use a hot water to clean surface of your catridge
Mar 28, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Gestetner DSc332 streaks and smears when printing in color
Check to see if you have a paper jammed near the drum near the color ink cartridge interface.
Nov 28, 2007 | Gestetner DSc332 Copier
HP LaserJet CM1017 MFP All-In-One Color Printer Logo
746 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
