Question about Epson Stylus Photo 1290 InkJet Printer
Hi - my 1290 is flashing red then green then red...and so on. Can't access the ink cartridges by the yellow button - please... what's up doc??
SOURCE: Ink cartridge unit will not move to replace
Printer has pads for excess ink, once pads are full this happens.
Pads will need to be replaced
Posted on Aug 03, 2008
SOURCE: Red and Green alternate flashing lights, screen indicates communication error
Try this one here, it worked for me in the past. Below is the link.
Resetting waste ink counter
Posted on Nov 22, 2008
gwbm
  • 353 Answers
SOURCE: flashing red/green lights
The Waste Ink Pads in your printer are saturated with ink and the waste ink counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utility - download from
http://www.ssclg.com/epsone.shtml
and reset the Protection Counter. This will stop the red lights flashing and restore normal operation. However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. If you want to have a go at this yourself, the service manual can be downloaded from
http://www.mediafire.com/?m6ouftizois
Please report back if you need further help
Posted on Feb 01, 2009
ITTech7574
  • 85 Answers
SOURCE: Epson Stylus photo R230
go to the printer setting under control panel, right click on the icon then properties..you can check the ink level there...normally if your printer blinks and ask for a new cartridge..better follow what the printer says... : >
Posted on Aug 31, 2009
goodgold
  • 389 Answers
SOURCE: epson r220, power light flashing green, ink light red
Include the printer. Press and hold the buttons STOP, MANITENANCE ("drop") and POWER whereupon switch off feeding.
http://files.mail.ru/N287AI
Posted on Sep 24, 2009
Colour ink cartridge empty but the on off light and red ink light flashes alternately and the carriage will not move to allow access to remove the empty cartridge.
hello, are you sure its not the error light that is blinking alternately with the power light, or is ink light indicator blinking , and just the power light blinking. i would first problably pull the power cord. then plug back in, and try again. the alternating error light and power light would be inkjet service, maint or waste pads are full, as far as the other error, i looked it up, and that error not coming up, unless there is something else going on. maybe cover for ink cartridge is caught, and not allowing printer to cycle.
Oct 05, 2010 | Epson Stylus Photo 1290 InkJet Printer
Photo 1290 Changing ink cartridge
You may have to reset your printer, for when the green an red are flashing. Please do the following in order to reset the printer;
1-switch off printer itself
2-switch off at socket for 20 seconds
3-hold down both black buttons on front
switch on at mains
4-switch on printer itself
green and red flash together
5-now switch off at mains and leave for 3 seconds
6-while holding down both front buttons again, switch on at mains
both green and red flash together so release
7-quickly hold down the left botton, the one with the scroll icon above it.
Hold this until it resets itself, - the print head will re
charge and it will be obvious.
Restting by unpluggin rather than turning off at mains tends not to work.
This must help you as it worked for me.
Regards,
Anirban Mazumdar
Jun 05, 2010 | Epson Stylus Photo 1290 InkJet Printer
My 1290 has been working fine doing a lot of printing today. I have tried to print additional work but have alternative flashing red and green lights. I cannot replace the ink cartridges as it will not...
Hi
Not know if it will work for your printer but you can gave it a go.
Step 1: Manual Temporary
1. Turn off the printer. And disconnect the printer cable.
2. Press and hold the POWER button, turn on the printer.
3. The indicator (L.E.D.) should be green.
4. Press and release the RESUME button , the indicator (L.E.D.) should be orange.
5. Press and release the RESUME button again, the indicator (L.E.D.) should be green.
6. Release both buttons.
step 2 : Software for Permanant
1. Reconnect the printer cable.
2.Open General Tools software and select (USB PORT2_bing.gif)
3.Choose (SET DESTINATION 1) And it should be reset.
Sofware Download "After service mode Pls use software for permanent reset
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 10, 2010 | Epson Stylus C46 InkJet Printer
Red and green lights flashing, won't print or respond to commands. Problem started when cleaning heads and subsequently testing with the print pattern. Monitor says a general printing error and suggests...
The heads are clogged. Unplug the printer remove the cartridges and dump them (never use the same brand of it or the same ink),pour some cleaning fluid there and leave it to soak. If you have some empty cartridges fill them with cleaning fluid and use them.
Oct 04, 2009 | Epson Stylus Photo 1290 InkJet Printer
Pictures coming out green
On a picture that you have printed, when you see an area of green, what color should it be? You probably have reduced flow of one of the "balancing" colors. Blue, Yellow and Red add up to Black. If your picture is supposed to be almost black and you don't have enough red, the color will pull toward the blue and yellow, giving it a green tint.
Aug 04, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Changing color cartridge on my epson stylus color 980 printer.
If you need to replace an ink cartridge in your printer, please follow the instructions below:
To confirm which ink cartridge requires replacement, please use the printer's control panel (there is a black ink out indicator, as well as a color ink out indicator ), or the Status Monitor in your computer.
Red light flashing - Low ink
Red light solid - Out of ink
1. Open the printer cover and press the INK (Cleaning) button for 3 seconds. The print head moves to the center and the lights flash.
2. Lift up the ink cartridge clamp. The cartridge rises up from its holder.
3. Remove the cartridge and dispose of it carefully. If ink gets on your hands, wash them with soap and water. If ink gets in your eyes, flush them immediately with water.
4. Unpack the new ink cartridge and remove the yellow tape. You must remove the yellow tape from the top of the cartridge. Do not remove the clear seal underneath the cartridge. Do not touch the green circuit board on the back of the cartridge, or you may inhibit normal operation and printing.
5. Tilt the new cartridge toward you slightly as you insert it. Lower the cartridge so that the tabs rest on the hooks. Do not place the cartridge tabs under the hooks.
6. Press down firmly on the ink cartridge clamp until it snaps in place.
7. If you need to replace the other ink cartridge, repeat steps 2 through 6 before continuing with step 8 (to move printhead over to color (if black was replaced first) press the cleaning button once).
8. Press the INK (Cleaning) button once, and close the printer cover. The printer begins charging the ink delivery system.
9. Wait until ink charging is finished (the power light stops flashing and the red error light goes out).
May 11, 2009 | Office Equipment & Supplies
Alarm flashes ink emptyhas ink! color was printing only yellow/green now prints only red/pink!
any chance it has dried out? run the test / head cleaning / did you reset the cartridge when you replaced it? generally if one or two colors work - the problem is the ink cartridge or the head for the colors not working. Did you remove the "tape" on the new cartridge?
Apr 16, 2009 | Office Equipment & Supplies
Steady red light feed paper button
your printer needs to be reset put this in google scc download it and that should work
Nov 23, 2008 | Epson Stylus Photo 1290 InkJet Printer
Change printer ink
Turn on the printer.
lower th epirnter's output tray, pull out the extension, and open the cover.
press and release the ink button.
if your ink lights is on or flashing, the printer head moves to the left, and the cartridge that need to be replaced stops under the ink out mark.
open the cartridge cover
Pinch the back tab of the empty cartridge as your left it out of the printer.
shake the ink cartridge 4 to 5 times while it is still in the package.
unwarp the new ink cartridge and lower it into the holder. Push down gently until the cartridge is firmly seated.
repeal the procedure if more than one ink cartridge is out.
close the cartridge cover.
close the printer cover and press the ink button.
The green power light flashes and the printer makes noise. charge takes about a minutes. When it's finished, the green power light stops flashing and stay on, and the red ink light should go out.
Oct 10, 2008 | Epson Stylus C66 Photo InkJet Printer
Epson stylus 1280 printer
Based on the lights you are already out of one or more ink cartridge or an ink cartridge is not being recognized/expended.
-You cannot print if any ink cartridge is expended.
-Leave the empty cartridge installed in the printer until you have obtained a replacement.
Once you start the ink cartridge replacement procedure, you must complete all the steps in one session.
1. Open the printer cover and press the INK REPLACEMENT button, located under the printer's cover. The print head moves to the center and the lights flash.
7. If you need to replace the other ink cartridge, repeat steps 2 through 6 before continuing with step 8.
8. Press the INK REPLACEMENT button and close the printer cover. The printer begins charging the ink delivery system.
Jun 17, 2008 | Epson Stylus Photo 1280 InkJet Printer
Epson Stylus Photo 1290 InkJet Printer Logo
106 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
