Question about Dryers
Dryer not heating. Drum rotates, fan blows, but not getting hot.
    Genius:
  • 1,461 Answers
Could be thermostat / or element,, Check no cut out at back casing.
Posted on Oct 03, 2009
The drum rotates and blows air, but it doesnt blow hot air. I already changed out the thermal fuse.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 01, 2011 | Dryers
Dryer blowing cold air . No heat!
Check the "Bias thermostat" for continuity with a multimeter. IF it is bad, replace with this part.
Nov 29, 2010 | GE DBXR463EDWW Electric Dryer
Dryer does not get hot
There are a number of things that can go wrong on an electric dryer that will make it not heat...
Check out this tip that I wrote about that problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Mar 31, 2010 | GE DBSR453EBWW Electric Dryer
Dryer has heat in back but cloths won't dry.
Howdy: Some models have a little fan that blows the hot air into the drum. I do not know what model you have but I would start there. Sorry - Good luck - Doug
Dec 09, 2009 | Maytag Dryers
Gas dryer get hot but than goes cold
This sounds like a problem with your fan motor. The dryer is getting too hot and the gas is shutting off until it cools down. That fan keeps the dryer cool by moving the heat to the clothes in the drum.
You can easily check this by feeling for air flow in front of the exhaust vent outside. No air movement = fan problem = heat shut off in 10 minutes. Good luck
Dec 05, 2009 | Dryers
My creda t622cw dryer had no heat so I have replaced the thermostats, but when I tried it there is heat but the heating element gets very hot and turns red, is this normal or do I need to replace this as...
The fact that the element gets red hot, shows that there is nothing wrong with the element, it will get red, more so if you tried it without a cover or panel over it, as normally the fan blows the air over the element, make sure the drive belt is o/k, and the drum is turning.
Please rate my solution.
Thanks.
Nov 13, 2009 | Frigidaire Electric Dryer
The tumble dryer does not dry The heater element warms up The fan motor is turning but no heat gets into the drum. Bosch Classixx wash and dry
does the element heat up then turn right back off after a few seconds? if so, there is 2 sensors that control the heat element, one is in the duct right after the fan. when this sensor senses too hot, it will shut down the heat element. either your sensor is bad, or the lint is not getting out, causing the heat to build up in the duct.
Oct 27, 2008 | Bosch Washing Machines
Dryer heater not working
If it is an electric heater that means that either the heating element, or the thermistor , or the cirrcuit breaker connecting the element must be replaced.
You find diagrams and replacement parts here, just enter the model number.
See also following suggestions from repairclinic :
There's no heat.
How Dryers work
Find a part for your Dryer
Oct 12, 2008 | Hoover Washing Machines
Tricity Bendix WDR1240W Condenser dryer problem
Check the fan that is supposed to blow the hot air into the drum. It may be seized or jammed. It should be situated on the top of the outer drum. You will need to remove the top cover from the machine and identify the blower fan.
Nov 01, 2007 | Tricity Bendix WDR1240W Front Load Washer...
Dryers Logo
47 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
