Question about Dyna-Glo Heating & Cooling
Propane to control box but pilot won't light. No propane going to pilot. Model#rmc50lpt.
  • 80 Answers
Remove pilot tubing from gas valve and push the pilot knob to verify gas makes it out of the valve. If not, bad gas valve, if you do get gas, replace pilot orifice located in pilot assembly.
Posted on Oct 04, 2009
Jandy lite 2 pilot won't start
check fuses that go to ignitor if ok ohm out ignitor when unplugged should be about 78 ohms if shorted or open replace if ok check safety circuit
Apr 20, 2013 | Jandy Laars Lite 2 Pool Heater 400000 BTU ...
Napoleon Fireplace propane Pilot won't light main burner even though gas flows in?
  • I'm going to assume your fireplace has a pilot light.
  • Follow the little holes in the burner that lead to the pilot light.
  • Make sure the pilot flame is pointing directly at the closest burner hole. (adjust if necessary).
  • Often, you will need to sprinkle a layer of "glowing embers" in this area. The embers will help the gas travel to the pilot light and ignite.
  • Always start your propane appliance on "High" never "Low". Cold propane likes to drop to the bottom of the firebox and accumulate until it reaches the pilot (this is called delayed ignition). Keeping it on "high" will help the fuel travel over to the pilot without buildup.
Jan 21, 2013 | Napoleon 36" Zero Clearance Top/Rear Vent...
The pilot light won'jt light in my warm morning propane gas stove
If you dont have gas coming thru while holding down the button, you have one of the following; no gas, main valve off, or a bad gas valve.
Jul 21, 2017 | Heating & Cooling
Sterling RF-45 Pilot light comes on and the burner won't fire. The pilot goes out and fan keeps running.
clean pilot check flame sencor is clean , jump high leval limit first see if it lights , if not try low limit , check thermocouple is tight if fitted ,
Sep 24, 2011 | Sterling RF45 Propane Gas Heater (45,000...
Unit ( model SR142gp serial 0608MA0448 - propane fuel ) operates as designed, but can not cut flame to pilot with the thermostat. must cut the gas control to pilot to the get pilot flame & pilot...
The pilot light should remain "ON" all the time. It is not intended to ever go off, unless you are not going to use the fryer for several months at a time. Then you can just shut off the propane which will shut off the pilot light flame. It does not cost that much to run the pilot light all the time. About one to two dollars a week.
Sep 11, 2010 | Frymaster Dean SR142GP001 Deep Fryer
Control valve not working
Lots of time, the pilot light lites and heat up the pin (thermocouple),to tell the gas valve to open and send gas, or the oxygen sensor could be plugged up and needs blowing out ,,,,or the pilot tube could be plugging up and not letting enough gas from the pilot light to shoot past the thermocouple to sense a flame...(.See where i,m going with this?)
Dec 17, 2009 | Procom ML300HGA Heater
Pilot light has no gas coming out, verified gas going into gas valve, but no gas coming out when pilot light button depressed.
Pilot orifice may be clogged. Remove pilot tube and orifice. Blow out orifice with compressed air only and reassemble. Also, control valve may be bad.
Sep 30, 2008 | Cozy Enclosed Front Console Heater 20,000...
Heating & Cooling Logo
234 people viewed this question
Top Dyna-Glo Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Dyna-Glo Heating and Cooling Expert? Answer questions, earn points and help others
