Question about Whirlpool Calypso GVW9959K Top Load Washer
I have a top loading Whirlpool washer Model No. LSR8433KQ0. I believe the belt needs replaced, but I can't figure out how to get the @#$@##@ cabinet off!! It looks like it should pull up from the top, but it appears to be screwed down from the bottom. The back panel, though, does not look like it is easy to remove. Help!!!
  • 15,935 Answers
First of all, unplug your washer. You will need to remove the console in order to get to the lid switch. The washer may have release tabs under the console at each front corner. Simply slide a putty knife straight in from the front at each corner and push in while lifting up. You should feel the release tabs push in and the console will pop up. If not equipped with this type of console, you may have a console that has removable end caps. They can be removed by gently prying up on the top of them from the rear on each side. You may have to use a small screwdriver for this. The caps should pop right off. Once removed, you will need to loosen a screw under each cap. Once you have the console loosened, carefully lift it up and lay it back over the rear panel of the washer in its resting position. Be careful not to damage the small plastic hinges that hold it in place. Now you will need to perform the following steps:
1. Under the console you will find the lid switch connector. Unplug the switch from the connector.
2. There will be two brass colored clips. You will need to remove these to remove the machine casing. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver away from you while holding into the groove and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Now pull the case from the frame by lifting from the back first.
You do not have to remove it all the way from the frame, just enough to gain access to the switch. All there is to the switch is a couple of screws holding it in and a ground wire. It's a pretty easy repair job. Some models will have the switch located on the right-hand side of the lid rim opening, while other models will have the switch located on the left-hand side near the lid hinge.
Once you've completed your switch installation, make sure you get the case back on the frame correctly by following these steps:
1. While looking down through the lid opening, place the front lip of the machine case UNDER the washer frame and start leaning it back onto the frame. There are four small cleats that must fit into four slots on the case or the washer will vibrate. Make sure the frame is seated properly, lean forward from the front of the washer, grasp both sides of the rear panel and pull towards the case. The rear panel should be seated and flush with the casing before inserting the retaining clips.
2. Insert the brass-colored clips into the slot on the washer rear panel first, and then push straight down into the opening on the top of the washer with some force. If you have the case seated correctly, the clips will snap back in.
3. Make sure you plug the connector from the console back into the lid switch receptacle BEFORE you reassemble the console. This is easy to forget.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 21, 2010
Replace belt for model CJ4732600
that model number you sent isn't a good model number,your problem is under Whirlpool Ultimate Care II LSQ9549L Top Load Washer,if this is your washer there isn't a belt in it,it has a motor coupling,let me know if this si your washer and i can help you out.
Jan 16, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
HOW DO YOU REPLACE A BROKEN LATCH
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (110.#######) and you'll see a list of major sub-components with diagrams and parts.
Also see the following for how to release the console and remove the cabinet:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=4a891e69ce522c88dc53ea3d0ddbd34e
And see the following Whirlpool parts list and diagrams for top load (commercial ) washers. Consumer models are basically the same:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
And see the Whirlpool / Kenmore Service manual for top load, direct drive machines:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
From these, you should see how the switch attaches to the cabinet and console.
Apr 20, 2010 | Kenmore 24032\24036 Top Load Washer
No cold water, how to remove washer cabinet
u do not remove cabinet on this model look @ whirlpool name on washer front . pry this off there is a 1/4 inch head screw there remove this pull top foward and raise caution there may b hoses to disconect I have not worked on this model for long time
Oct 27, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
How to replace the belt
this unit does not have a belt it has a direct drive coupler. you will need to remove the whole cabinet to continue with this repair. let me know if that is what you would like to do. i will give you step by step instuctions.
Oct 14, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Replacing timer on a whirlpool lsr8433kq0
Garret,
Yep... it sure sounds like a failed timer. I looked it up for you, the part number is 3948852. You can find it online or see if you can get one from a local appliance parts retailer.
SG
Apr 21, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Washer spins freely but clothes remain very wet
The two possibilities of which come to mind are, something in pump slowing the water outlet, belt loose or needing replacement. Sometimes an article gets over the barrell and sucked into the pump still allowing some water to pass by, but the belt needing to be replaced would prably be my first check. both need Power disconnect then cabinet panel pulled to view both the pump and belt
Feb 09, 2009 | Maytag PAV2300 Top Load Washer
Removing Back Panel of Kenmore Washer Model 11020902990
if its less than 15 years old its a direct drive whirlpool, no belt, remove the cabinet, not the back panel. look up direct drive whirlpool washer cabinet removal on internet, and replace the coupler, most likely, if it drains.
Jan 30, 2009 | Kenmore 22422 Top Load Washer
Opening top of cabinet
you have to use a putty knife. It is a pain in the neck. there are two clips where the top of the cabinet is there is a slot you can see the clip if you use a flashlight push theputty knife in and pull up. Then do the other side. They are directly in the frontt of the unit
Jan 03, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a Whirlpool top loading washer Model # LSR8233EQ0 that the water mixing valve needs to be replaced. How do you get to that valve? Do you remove the back of the machine or go from the front?
Do not remove the back.Take 2 screws off front ends of console and pull slightly forward and flip it up- it is hinged on the backPop off two spring clips that engage cabinet. Unplug lid switch wire. Tilt cabinet forward and the whole thing comes off. Thanks, please leave feedback or contact me again for more info if you need it.
Nov 29, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washer Tub Gasket
remove gasket from cabinet - just held onto cabinet by a simple clamp and fold gasket inside drum. this will give you enough room to access the retainer. you may find it easier to remove the top as well
Sep 09, 2008 | Whirlpool GHW9400 Front Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
181 people viewed this question
Dan Webster
Dan Webster
Sal De
