Question about Sony Ericsson K700i Cellular Phone
Sony ericsson k700i
My data cable dose not comply with any computer.the computers can not recorganise the says there no drivers which drivers should i use and were should i get them? thanks
  • butnu750il Oct 03, 2008
    conects fine and charges but does not sync
Please tell me what i can do ?
i have installed cable drivers for sony ericsson but i can't connection my computer with my phone it's been written no connect. please give me some advices or get me free version k700i for downloading.thanks a lot
Posted on Oct 30, 2009
  • 3 Answers
APC with a pentium 11 233MHz computer connected to your mobile with USB cable, one available USB port, Local Hard drive with 20MB free space, 32MB of ram under windows 98,Millienium,and NT 4.0; 64 MB of RAM under windows 2000 and XP
If you could find USB Data cable with the above features then your problem is solved.
Posted on Dec 28, 2007
Looking for drivers for sony ericsson k800i
Dear, if u wanna connect your fone with computer through usb data cable so you don't need to install drivers.when you connect your fone with computer via usb data cable then cancel every window appears regarding installing drivers and select FILES TRANSFER from your fone.After sometime fone removeable drives appear in MY COMPUTER.thanks
Feb 10, 2010 | Sony Ericsson K800i Cellular Phone
My cellphone sony ericsson k770i got drop suddenly memory card doesnt work when i shut it off it say that i need to reformat it how can i reformat my cellphone
connect it to the pc download the phone driver from google if u dont have it .after installing the driver the phine will be visible in my computer as remuvable disk.right click it format.
Jan 16, 2010 | Sony Ericsson K700i Cellular Phone
Master reset
The default master reset code is 12345 unless it was changed
Hope this helps !!!
Apr 17, 2009 | Sony Ericsson K700i Cellular Phone
Sony Ericsson W580i USB Driver for Windows 7
Try this.....
Sony Ericsson - Update Service - Update service software
Follow the instructions to install the USB Flash driver. ... W580i. W200i. K550i. W800i. K508i. K790i. K530i. W960i. P910i. K700i. W550i. Z520i. M600i. W660i ...
hope it will fix the issue so dont forget to rate it...
Apr 17, 2009 | Sony Ericsson w580i Cellular Phone
SE K700I
You have not provided any details regarding your problem. What type of cable are you using? Is it dcu-11 from sony ericsson or some other cable like the one from mobile action? In both cases you will need to install the necessary drivers for the cables. If you're using dcu-11 google for dcu-11 drivers and you will get plenty, and if you're using mobile action, most probably the cable code would be MA8910P, search for that driver and install it. The most hasslefree software to connect your phone is "Myphone explorer" download it as well to manage your files. Get back if you have any queries about driver installations or so.
Apr 11, 2009 | Sony Ericsson K700i Cellular Phone
No connection beetwen my Sony ercsson p900 and my computer by usb
hello there!!! thanks for using!
just a little information...
PDA USB Sync/Charger/Data Cable for Sony-Ericsson P800,Sony-Ericsson P900 Features:
  • USB Sync/Charge Data Cable for Sony-Ericsson P800,Sony-Ericsson P900
  • Auto Sync with computer in USB port and charge Sony-Ericsson P800,Sony-Ericsson P900 PDA with same cable
  • Directly connects with USB port, need no extra power
  • Plug and play, need not software installation
  • Eliminates the need for cradle and AC/DC converter when traveling
  • Compact, lightweight and easy to use
  • One of the best USB hotsync data cable for Sony-Ericsson P800,Sony-Ericsson P900!
    If you experience problems when using the USB cable during synchronisation:
    1. Check that the USB cable is properly connected to the phone and the computer.
    2. Make sure the phone is turned on.
    3. Restart the computer, without disconnecting the USB cable or turning off the phone, and try to synchronise again.
    4. If you still experience problems using synchronisation software, e.g. Sony Ericsson PC Suite or Active Sync, try to uninstall and reinstall the program you are using.tang-shop_2031_105590869 Or you may go to this website for further information
  • Feb 09, 2009 | Sony Ericsson w580i Cellular Phone
    Sony ericsson k700i
    You can easily unlock this sonyEriccson phone using the unlock code and instructions in the site
    Dec 24, 2008 | Sony Ericsson W200i Cellular Phone
    Data cable
    I conect my phon with data cable but phon not working
    Jul 24, 2008 | Sony Ericsson K700i Cellular Phone
    Sony ericsson w610i
    Go to Sony site and download the driver for your phone
    Step 1
    Remove data cable from usb and put it into a different one
    Step 2
    Connect your phone to the computer with the cable and turn it on.
    You might see "Found New Hardware" wizard. DON'T let Windows search for the driver; point it to the driver you just downloaded, and install the drive on your computer.
    After the driver as installed you should be working 100%
    Jan 09, 2008 | Sony Ericsson K610i Cellular Phone
    PROBLEM with DATA cable connection with PC
    these are always troublesum try your ericsson customer service number and ask for an it tech they are usually very good
    Nov 06, 2007 | Sony Ericsson K700i Cellular Phone
    Sony Ericsson K700i Cellular Phone Logo
    194 people viewed this question
    Top Sony Ericsson Cell Phones Experts
    Computer Repairing
    Computer Repairing
    Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
