Won't power up
The all-in-one won't power up at all; when the power switch is turned on the printer makes a slight sound and that is it, no indicator lights engage.
  • 1608 Answers
SOURCE: 97 lumina blinkers dont work. Causes brake lights
The problem is with your multifunction switch.The steering wheel has to come off and you need a special puller for this.Also the air bag is part of the horn pad that has to be removed so the S.I.R system has to be disabled.S.I.R means Supplemental Inflatable Restraint.The indicator switch is part of the multifunction switch.It does not come off like earlier models.If you are not familiar with air bag systems then You should not be trying to replace the multifunction switch on your own.There is also a clock spring that is on the steering column and if it is not installed properly then it will fail and turn the air bag light on.Then it will have to be replaced.The price for that spring here where I am located is over $200.00.Could be more where you are.Hope this info helps.Good luck.
Posted on Dec 26, 2009
  • 1572 Answers
SOURCE: Samsung R700 wont switch on, powers up but nothing happens...no hdd or bios lights
Remove the battery, hard drive, optical drive and memory. Install a known-good memory module. If the system starts up and complains about not finding a boot device, or just displays a blinking hyphen, one of the devices you removed is bad. Put in the battery and see if it continues to run. Shut down the system and reinstall one of the memory modules. Try it again. If it still starts up, shut it down, remove the battery again and put in the other memory module in place of the test unit.
Do the same with the remaining components (shut down and remove the battery before installing each part). Save the hard drive for last so you don't have to worry about messing up the operating system with the forced shutdowns. When the system fails to start, you've found your bad part. (If it won't start with all of the parts removed and test memory installed, the logic board has a failed part on it.)
Sometimes removing and reseating a memory module will fix the problem - that would happen automatically with the procedure I just described. Your User's Manual should have the instructions for replacing memory. I'd give you a download link and page number, but the Samsung support website says the SCH-R700 is a cell phone. Use the complete model number from the bar code sticker on the bottom.
Posted on Nov 24, 2011
MOTORWIZJ
  • 1343 Answers
SOURCE: Pool Pump Motor (AO Smith 2HP 56Y CX) won't turn over when switched on. Makes slight humming sound. Removed the motor from pump housing. When I spin the impeller when powered on, the motor starts up
3 THINGS QUICK.. RUN CAPACITOR THIS IS LOCATED ON TOP OF MOTOR HAVE IT CHECKED. OR START SWITCH DIRTY OR STAR CAPACITOR BAD.. SEARCH YOUR AREA FOR YOUR LOCAL POOL PUMP MOTOR REPAIR GUY WITH FREE TESTING.. WARNING THESE CAPACITORS HOLD HIGH VOLTAGE AND WILL NEED TO BE SHORTED ! USE A DRY RAG AND COVER CAPACITOR THEN SHORT WITH SCREWDRIVER
Posted on Dec 28, 2011
AJIN G
  • 6694 Answers
SOURCE: Tv won't turn on power indicator light not lit
As you mentioned the tv have problem with the power supply stage. Before suspecting for any intenal fault Chcek the following first. Remove the AC plug of the tv and connect the same in any other wall outlet. If then also it shows the same problem then its the powersupply board of your tv.
working on power supply board should be done by a skilled worker. Because there is risk of electric shock even if the power is disconnected. some of the capacitors will hold charge even if the power is not connected.
Here i have adde the link which will lead you the powesupply board.
Power supply board
Ajin
Posted on Apr 01, 2012
  • 6468 Answers
SOURCE: lawn tractor, blades won't engage
the circuit also goes to the trans so you can't mow in rev also on the brake/clutch pedal switch assuming you check the fuse already
Posted on May 11, 2012
Jammed it, removed all paper, now it won't start
Your shredder may be jammed with shreds of paper mashed into the mechanism. Access the mechanism and prepare to remove all ground-in residue bit-by-bit.
Oct 20, 2017 | Office Equipment & Supplies
Epson 610 Workforce Printer Error; Light Bar won't reset
Sound like the scanner is the issue, is it under warranty? OR the Scanner may be locked, check for the scanner release device unlock it,.
Dec 17, 2012 | Epson Workforce 610 All-In-One InkJet...
Sharp model lc-20sh1u won't turn on, just makes a clicking sound and indicator light flashes red.
The clicking sound may be a power relay coming on and then off--problem indicates a trouble in the main power supply.
Nov 02, 2012 | Sharp LC-20SH3U 20 in. EDTV-Ready LCD...
Dec 26, 2011 | AO Smith Pool & Spa
My DeLonghi Portable Dehumidifier Model DEM10 has stopped working. It doesn't make the same noise when you turn it on anymore i.e the slight refridgerator sound. Does this sound like a repairable problem...
First, make sure the reservoir is empty. If you plug the unit in and see a green power light, but the unit won't run, make sure the reservoir is properly inserted. Many dehumidifiers have switches or sensors to make sure that the reservoir is placed so that it won't leak. Look for these sensors and make sure the reservoir is engaging them. If your dehumidifier has a float or switch to indicate a full reservoir, make sure this switch isn't being tripped accidentally.
Good luck.
Aug 13, 2010 | DeLonghi Dehumidifiers
The power switch keeps flashing it won,t turn off i can.tprint
have you tried holding down the power switch fir a period of time
You cay you can print still, have you read through the manul as this light flashing may indicate a problem with the cartridges etc
Jun 02, 2008 | Office Equipment & Supplies
CanonIR 5570 Copier reboots then jams at sorter
Sounds like the sorter connection between the two is poor or disconnecting, check the cable from sorter and power lead to the sorter are secure.
Check switch that machine uses to know when sorter is engaged is closing proberly/not bent
Check sorter indicator lights (if any) after reboot,
Try running lead to it from elsewhere in case there is too much drain or something weird with power supply where you are
Jan 12, 2008 | Office Equipment & Supplies
27 people viewed this question
jasbo
jasbo
