Question about Cyberguard SG300 (00852503000366) Firewall
Cyberguard sg300 drops tunnel out and requires a power cycle to reconnect. (It stops at negotiating stage 1 after dropout)
Settings are aggressive mode, preshared secret, dead peer detection, but no compression.
Initiate stage 1,2 rekeying also set.
Firmware levels are all the same, v3.1.5u4
If you've got locked out of your CyberGuard / SnapGear firewall, as long as you still have SSH access you can regain access without doing a factory reset.
From the command prompt type "enableweb"
/> enableweb
The web interface has been enabled on ALL interfaces, for HTTP and HTTPS.
Please ensure you review the administration access control options.
As it says, this will re-enable access on ALL interfaces, including Internet, so you need to review the choices, FAST!
keep updated.thanks.
Posted on Oct 06, 2009
This seems like a a common problem for many who are using an SG300 (though I believe that other SG series are affected) for a few months on TPG ADSL2+.and ADSL+2 modems. It took too long to connect to the DSLAM, sometimes several hours. I
tried different modems in front of this router etc but all to no avail.
Different configs etc, but nothing worked. I'd simply have to leave the
router to connect of it's own accord. It'd continually try and fail
over and over until it connected. Once connected though it was always
stable.
I thought that I had the latest firmware as I only updated it about two
months ago. Anyway the latest firmware from Cyberguard/Snapgear
rectifies this problem in particular. It seems to be isolated only to
TPG ADSL2+ in combination with the SG series firewalls. Get firmware version 3.1.4u2 if you're having issues with SG series firewalls connecting to TPG ADSL2+.......This might solve this problem....sodeep
Posted on Oct 04, 2009
Hi
Thanks for using FixYa. These are the main causes due towhich drops tunnel out and need a power cycle to reconnect. Please make sure thatthe Cyber Guard SG appliance has a default gateway by configuring the Internetconnection on the Connect to Internet page or assigning a default gateway onthe IP Configuration page. Ensure that the tunnel settings for the Cyber GuardSG appliance and the remote party are configured correctly. Also ensure thatboth have IP Sec enabled and have Internet IP addresses. Check that the CA hassigned the certificates. The remote party has gone down. The remote party hasdisabled IP Sec. The remote party has disabled the tunnel. The tunnel on theCyber Guard SG appliance has been configured not to re key the tunnel. Theremote party is not re keying correctly with the Cyber Guard SG appliance. Forfurther reference see the link---
CyberGuard SG 300 User Manual
Please do accept the solution if the issue is resolved orelse revert for further assistance.
Thanks
Rylee
Posted on Oct 03, 2009
Jun 28, 2016 | Compex PS2216 16Port 10100Mbps Smart...
Jan 20, 2008 | Cyberguard SG300 (00852503000366) Firewall
Jun 21, 2011 | Cyberguard SG300 (00852503000366) Firewall
Jan 03, 2010 | Cyberguard SG300 (00852503000366) Firewall
Jul 06, 2009 | Cyberguard SG300 (00852503000366) Firewall
Nov 05, 2008 | Cyberguard SG300 (00852503000366) Firewall
Jun 15, 2008 | Cyberguard SG300 (00852503000366) Firewall
Feb 12, 2008 | Cyberguard SG300 (00852503000366) Firewall
Oct 19, 2007 | Cyberguard SG300 (00852503000366) Firewall
412 people viewed this question
Thanks for the reply, here are the complete details of the tunnel settings.
local interface - default gateway interface and tunnel enabled.
keying - aggressive mode
local address - dns hostname address
remote address - dns hostname address
initiate tunnel negotiation - yes
endpoint is specified
dead peer detect - yes
delay and timeouts are defaults
initiate rekeying - yes
tunnel name, dns hostname and endpoint are set
phase 1 settings are default, except for secret which is set
phase 2 settings are default except for the IP addresses
This link is one of 4 I have running from my Cyberguard and is how I support my brothers network. I think the cause of the dropouts is bad wiring in his house which will be recified, but the problem has appeared sometimes on the other links.
The issue is not so much that it drops out, but that it will not restart.
When I down the link from negotiating stage 1 state the log says (hornsby is the link)
Pluto[182]: "hornsby": deleting connection
Pluto[182]: "hornsby" #6863: deleting state (STATE_AGGR_I1)
When I enable the link again (stop msg seems odd to me here)
ipsecctl[1286]: Failed to stop ipsec tunnel hornsby: 21
flatfsd: Wrote 6582 bytes to flash in 2 seconds
Pluto[182]: | from whack: got --esp=3DES-SHA1;MODP1024
Pluto[182]: | from whack: got --ike=3DES-SHA-MODP1024
Pluto[182]: added connection description "hornsby"
Pluto[182]: forgetting secrets
Pluto[182]: loading secrets from "/etc/config/ipsec.secrets"
Pluto[182]: Changing to directory '/etc/config'
Pluto[182]: error in X.509 certificate: ssl_key.pem
Pluto[182]: X.509 loaded: ssl_cert.pem
Pluto[182]: error in X.509 certificate: ssh_host_rsa_key
Pluto[182]: error in X.509 CRL: ssl_key.pem
Pluto[182]: error in X.509 CRL: ssl_cert.pem
Pluto[182]: error in X.509 CRL: ssh_host_rsa_key
Pluto[182]: "hornsby" #6874: initiating Aggressive Mode
ipsecctl[1286]: Failed to start ipsec tunnel hornsby: 112
Regards Rod
Hi, you have described the problem well.. I am running 3.1.5u4 already so the issue is different. My setup is exactly the same as the example in the manual. I have noticed that if the line is good it works very well, its just that this link has some poor wiring (which will be fixed shortly) which makes the problem worse.
There must be a combination of settings that are the optimum, I am hoping someone has been here before me and has the answer.
Regards Rod
