Question about Bosch Drills
I can't change the bit on my Bosch PSB 650 RE drill
    Problem Solver:
  • 4 Answers
See if there's not secured to the shaft with a screw inside at the bottom of the bit. try to slack it by turnig it clockwise. then catch a 19 mm. open end spanner in a bench wise put the shaft with its two flat sides in the spanner and with a pump pliers catch the bit and unscrew the bit turning counterclockwise this time
Posted on Oct 06, 2009
How do you remove the keyless chuck on a Bosch PSB600 RES drill?
Here's a link to an exploded view:
Bosch PSB 600 2 0603338003 Spare Parts
If you need more help - you should contact Bosch directly:
Contact Bosch
Apr 14, 2015 | Bosch Drills
Psb 650 re
You have wound the threaded section of the jaws fast the thread in the case so sorry the chuck is broken as the teeth will be damaged. Best replace it with a new chuck
Jun 18, 2013 | Bosch Drills
A bit is stuck in the chuck of my Bosch drill
Hello. Wrap a towel around the chuck and use a pipe wrench or a pair of channel locks to put a little force on the chuck. J.
Jul 19, 2010 | Bosch Drills
How do you replace the chuck on a Bosch 650 RE
while holding the drill like a gun, hold the lock button REALLY tight and pull the black part to the right really hard. this will unlock the chuck and if you keep twisting the black part to the right it will loosen it enough so that you can remove it
Jan 03, 2010 | Bosch Drills
Hi, I let a friend use my Bosch 5600 PSE key less
you can't drill counterclockwise the bits are setup to drill clockwise and the chuck would become loose. try using two wrenches to free up the chuck then spray a little wd40 in it it is just bound up
Nov 05, 2009 | Microwave Ovens
New bosch psb 550 re with hammer action. Hammer action does not seem to engage. even with 5mm bit progress is non existent. The bits were bosch masonary bits and I was drilling into concrete blocks
your pin under the selector switch my have broken off. also the hammer rod could have broken too. if its drilling and not hammering that more likely. you may be under warranty call bosch or log on and go to dealer locator's for the closes dealer to you. hope this helped
Oct 09, 2009 | Bosch Power Tools Hammer Drills
Drill keeps on stopping and won't restart
Check the cord...sometimes if the brushes are not seated well or if there is a cut in the cord you will run into that problem....If it is not that then possibly you just have a faulty drill
Jan 04, 2009 | Drills
Drills Logo
644 people viewed this question
Top Bosch Drills Experts
Matt Olenzek
Matt Olenzek
woodzowl307
Are you a Bosch Drill Expert? Answer questions, earn points and help others
