Question about Sharp AL 1631 Copier
Sharp al 1631 error code l-1 - Sharp AL 1631 Copier
  • Sharp Master
  • 1,294 Answers
The problem it in exposere lamp section.The forward scan is not compelet.Cause is the mirror motor control board or mechanical parts.
Posted on Oct 03, 2009
Testimonial: "CURED THE PROBLEM THANK YOU"
Al-1631 coper will not clear misfeed # 6
Posted on Jul 11, 2015
checkitright
  • 1362 Answers
SOURCE: H3 ERROR CODE SHARP AL 1631
H3:
00:TEMPERATURE OF FUSER UNIT HIGH,THERMISTOR CONTROL BOARD FAILING
Did you replace the thermistor? check the thermofuse also for continuity
Posted on Oct 20, 2008
SOURCE: Sharp AL-1631
try this. Press C (cancel), Press Auto, Press C, press Auto
Enter 14 (code) e Press Print (green)
It´s a code to cancel H4, if it´s don´t work, send me e-mail to montgomery@brturbo.com.br
Posted on Feb 15, 2008
  • 4 Answers
SOURCE: sharp al 1631 error code
think its door switch /dv unit not installed properly
Posted on Aug 04, 2009
wheatlandsvc
  • 1110 Answers
SOURCE: sharp al-1631 copier. drum error code
You can reset this indicator by pressing these keys in sequence:
Press "C" then press "Exposure Mode" then "C" again then "Exposure Mode" again.
Note that the Exposure Mode key is the far left key on the panel.
One you press these 4 keys in sequence the display should go blank. Then key in 24 as if to make 24 copies. Then press Print (Green Button)
Then key in 7 as if to make 7 copies.
Press print again. You should now get flashing 000.
Turn machine off then back on and the light should be gone.
Here it is in a short version:
C, far left, C, far left, 24, print, 7, print,
then power off and back on.
Posted on Nov 16, 2009
Testimonial: "Ok sorry thank u. I am new sorry i will be better in the future."
xptareq2000
  • 1447 Answers
SOURCE: sharp al-1631 error L1
When scanner unite was dirty,all sensor dirty or scanner position lock.please clean all surface ,unlock position.
Posted on Dec 19, 2009
Sharp al 1631 need drum roller reset code
enter code 42 start 1 start.
(press C auto C auto 42 copy1 copy)
Apr 28, 2010 | Sharp AL 1631 Copier
Sharp al-1631 copier. drum error code
Nov 16, 2009 | Sharp AL 1631 Copier
Sharp AL 1631 is flashing 1 L. What does that
Hi:
This might refer to your scanner assy being locked. The scanner assy is the unit under the glass that scans your document prior to copying it. Look inside the cavity where you pick up your completed copies. Look at the upper left corner and see if there is a knob there. If there is, make sure it is in the completely unlocked position.
Andrew
Aug 09, 2009 | Sharp AL 1631 Copier
Sharp al 1631 error code "CH"
it is signal door open or cartridge unite not atast
Jul 24, 2009 | Sharp AL 1631 Copier
What is the code to reset the Sharp AL 1631 copier
Sharp - How to reset code
To enter service mode press thesekeys: orange C button,Interrupt, 0, Interrupt. The screen goes black when you have done itcorrectly. It may take a few tries – must be done in certain time.
To clear the maintenance indication (service man): press 20, start,1, start (the display will start to flash when entered correctly).Power off/on to make the copier dude go away. Good Luck!
Jan 31, 2009 | Sharp AL 1631 Copier
Sharp AL 1631
E7 has to do with the scanner. Make sure it isn't locked up or binding.
Oct 30, 2008 | Sharp AL 1631 Copier
H3:
Oct 20, 2008 | Sharp AL 1631 Copier
Sharp AL-1631 has 3H error code
3H error means overheating...what you can do is supply new fans or clean the unit for dust and others. check for the exhaust fans if its still working. this will reslove your problem.
hope this helps
Jan 27, 2008 | Sharp AL 1631 Copier
Sharp AL 1631 Copier Logo
575 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
