Machine is stopping before rinse and spin cycle and allows door to open
    Genius:
  • Washing Mach... Master
  • 1,460 Answers
Could be faulty rinse solonoid valve ,,you can check this with a multimeter if your handy
Posted on Oct 03, 2009
I dont have a stop buttom
You're start/pause button should pause the cycle, cancell should completely cancell. After pressing the Start/Pause within a cycle, the door lock may require time to unlock as indicated by the lock light on the panel.
Apr 11, 2014 | Frigidaire Affinity ATF7000E Front Load...
WMA36 washer going through wash cycle then stops can turn knob to rinse and spin and only sometimes it will then work. Otherwise it just keeps rinsing and not draining much and sometimes not spinning!
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Jan 19, 2013 | Hotpoint Wma32p Wma34p Wma36p Washing...
My GE SpaceSaver Washer/dryer will wash, but when it's time to rinse and spin the machine stops. It will not drain, riinse , or spin.
Jul 27, 2012 | GE Spacemaker Washer and Dryer Electric...
We have a Whirlpool 7KG frontloader washing machine (6th sense) model AWM8121. The problem is that the door light is flashing, the cycle has stopped at rinse (rinse light is on) and the machine is not...
We have an awm8121 and there seems to be a fault on the Spin cycle indicators with th 0 RPM and the 800 RPM flashing..
We can't seem to get the frontloader to finish the drain cycle and continue into the next was.
The last load of washing was still saturated when we managed to open the door.
Apr 20, 2011 | Whirlpool AWM8123 Front Load Washer
My asko regardless of selected wash program stops after the main wash, it will drain the water, but then not start the rinse cycles. The washing machine will allow you to open the door. I thought it was...
When your rinse cycle does not work it is your outlet filter that is clogged. If this is a front loader the small door is in the bottom front side of machine. Be prepared for some water to come out when u open the door. Unscrew and clean out filter and refit.
Also please note
with the Asko there are several possible things that can interupt the cycle either during wash or drain/spin. Have you checked the pump insert/button trap for debris or obstruction of any kind ? ( below main door to the left ) Are you using "he" ( lo-sudsing ) detergent ? Does the machine provide any error code, i.e. If it's a mechanical timer model does it stop at "C" or "S" or if electronic a symbol in the display ? Will it complete a cycle without any items in the basket ( empty ) ? Will the unit rotate in both directions and will it spin if you try both parts of that specific cycle ? This will help determine if the problem is with the drive motor brushes.
Nov 29, 2010 | Asko W6021 Front Load Washer
Machine stops after rinse cycle
Check that the lid/door is closed all the way. Otherwise check the safety switch that the door actuates when it's closed all of the way. The switch prevents the washer from spinning when the door/lid is open for safety reasons.
Oct 18, 2009 | Kenmore Washing Machines
Maytag Atlantis MAV7200 doesnt drain at end of rinse goes to OFF
It sounds like it may be the lid switch. It may be as simple as adjusting or tightening. But ultimately it may need replacement.. Hope this helps
Apr 04, 2009 | Maytag Atlantis MAV7000
Whirlpool Washing Machine Quitting during rinse cycle
I would say that based on your problem description that the lid /door switch has a loose or faulty contact .. If you open and close it a few times..it starts to spin and yet when you open it.. it doesn't always stop the spinning.. It is either the switch or the actuator that bumps that switch.. That is where I would begin diagnosing the problem... Hope that helps..
Aug 30, 2008 | Washing Machines
Maytag neptune won;t rinse
Check latch mechanism for alignment. Often operation of machine loosens latch mechanism causing internal switch for "door open (or ajar)" preventing rinse or spin cycle. Opening and closing door presses latch mechanism closing internal switch allowing for continue processing to rinse or spin cycles.
Mar 24, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
