Question about Toro Lawn Mower With Toro Power Tools
Toro sprewing oil
I topped off the oil in my 5.5 hp toro. After topping, oil level was still below the max line on the dip stick. After starting, oil spewed from the oil fill spout. What shoud I do?
    President:
  • 1,129 Answers
The filler spout tube may have pulled out of its seat push and twist to reinsert it down. if the oil is over filled you must drain some out to return it to its correct oil level, if it did pull out of its seat the small bolt holding the filler tube in place may have loosened up and fallen off it must be replaced if this happened.
Posted on Oct 03, 2009
How to accurately read the oil dip stick on a Toro mower?There is never a clear line of oil on the stick which has two holes as markers.
Did you ever consider checking manual for guidance? It is very clear regarding correct fluid level. Read it.
Aug 28, 2017 | Toro Garden
How to determine the oil level on dip stick
In other products, the upper hole is max and the lower hole is min. Somebody at Toro forgot to change the manual when the dipstick was reengineered.
Apr 23, 2014 | Toro Garden
How to check oil
have the car on a flat part of the road,remove the dip stick and check the level ,top it up to max if low .from low to max should be 1ltr but check online to find the amount.
Apr 04, 2014 | 2002 Chevrolet Impala
Does a catera have a dip sick
A dip stick is the indicator so the opeator (driver) can check your oil. The dip stick got its name because the end "dips" into the oil reservoir, or as some call it "Oil Pan" The oil dip stick is located on the left side of the engine towards top and is colored yellow at the circular loop for a finger hole. Find your oil filler cap, where you add oil.. it will say 5/w20 or something along that number. Standing at the front passenger side of the car with the hood up look to the front left corner area about a foot into the engine compartment area. DO NOT RUN ENGINE IF YOU BELIEVE THE OIL LEVEL IS EXTREMELY LOW. You can do step 3-6 with a cold engine to guage if you are extremely low on oil before starting the car. Also note that your oil should be checked in the following fashion. 1. Make sure car is on a level flat surface. 2. Make sure the engine off but warm. Either after having driven it or running for 5 minutes. 3. Pull dip stick and wipe all oil from it with a clean cloth, paper towel, etc. I say "Clean" as you will be able to see the color of the oil and if its contaminated in any way. 4. Place the diptstick back in the tube all the way until the finger hook sets in place. 5. Remove quickly and observe reading at tip of dispstick. 6 Proper oil at this point should be 3/4 of the way to Maximum indicator. YOur dipstick may say MAX or may have two dots seperated by a hashed area. Either way you should be 3/4 of the way to the top dot or max indicator. If you arent then add the recommened oil for your vehicle (you can find the best oil for your car at www. mobil1.com and the proper weight and type) I would add it a half quart at a time depending you how far you are from MAX mark. If you are within 1/4 of the MIN or Lower dot.. closest to the end of the dipstick then you should add a quart fully and then add in 1/2 quart increments until you can do the test and see the oil at the proper level. DO NOT RUN CAR if you believe you are extremely low on oil.
Jun 13, 2010 | 2000 Cadillac Catera
How many quartz of oil are required in a oil change? what is the proper oil level on the dip stick?
level should be on max if its hot or just below the middle if cold. in order to top up oil we do it in two stages leave cold slowly fill to bottom mark, then wait 5 mins check again should be around middle if not add another 100 mils wait check again. then run car for 10 mins stop engine wipe dip stick clean then check again level should be slighty under top mark this should answer your question
Jun 11, 2010 | 2000 BMW 7 Series
How much gear lube do i put in the crank case of my 93 yz 250?
There is always a dip stick in the crank case to check the oil level. On the dip stick you will find two marks for Min and Max oil levels. The oil should never be more than the Max level and never below the Min level.
Mar 15, 2010 | 2003 Yamaha YZ 250
How much oil does it take
how much oil does my 1995 toyota camry 4 cylinder engine take?
Feb 15, 2010 | 2001 Toyota Camry
How do i check the oil level on a yamaha tw125?
check oil once the engine has been off for a few mins undo dip stick or look in window whatever you have hold bike level and clean the dip with a rag then dip the stick in till it stops dont screw it in to check the level pull it out and it should be on the upper line or mark if you have a window it should be on the top line if you need to top up just a 1/4 of a litre at a time the bike only holds one litre.
Oct 15, 2009 | 2002 Yamaha TW 125
Amount of oil in Chevy Cobalt
add 4 then top it off, it takes a little less than 5.
Jun 25, 2009 | 2008 Chevrolet Cobalt
Reading the gauge on the oil dipstick 1998 saab 900
The dip stick end should have a plastic square piece with two roundish bulbs on each end. The oil level should read just at the bottom of the top bulb (the bulb nearest the yellow cap at the top end of the dip stick). This indicates full. A level reading anywhere between the two bulbs is adequate but not optimal. Oil below the top end of the bottom bulb, means 1 quart low, and no oil at all on the bottom bulb means get some oil in there double quick.
May 02, 2009 | 1998 Saab 900
Toro Lawn Mower With Toro Power Tools Logo
138 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
