Question about Dell SD-616 Internal DVD Drive
My pc detects the drive but it does not recognise when I put a disk it
    Guru:
  • 355 Answers
Your drive is ok but dives lence is problem cleane the lence then check
Posted on Oct 03, 2009
  • 165 Answers
It is the problem of your cd drive . Please give the drive to a authorised DELL service centre. then they will repair it.
External hard drive
take out the hard disk,install it directly on your pc's sata interface.
Dec 08, 2013 | Acer Computers & Internet
Acer aspire 5733z does not detect dvd drive
This sounds like your dvd drive stopped working. try with different cds or dvds. If not there is a complicated way but if you are not familiar with computers don't do that. A service technician can easily solve it for you.
Dec 02, 2012 | Computers & Internet
Compaq Mini 700EL hdd not recognised
If you are installing Windows XP then -
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Oct 08, 2012 | Computers & Internet
SAN Disk Pen drive detection
you connect your pen drive in your PC that will pop up one window named found new hardware....connect to internet and click on that window....that will ask tom install driver....follow the step and install the software.... restart your PC this problem will get over...\hope bthius will helps you... Thank you.....
Oct 10, 2009 | Express FormTool v5 (1077917SF)
DVD writer doesn't recognise blank dvd or playback
try using a lens cleaning disk if that does not restore it then you need a replacement other possible solutions are to check the cables in the back of the drive ensure they havent come loose
Aug 06, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Hard drive not installed if os not found re-install hit any key to exit
This usually happens when your BIOS fails to recognise your hard disk or else it is not enabled in BIOS or else there is a loose connection which makes your computer unable to detect the hard disk, You could try and use your BIOS to check if your hard disk is detected. In case it is not, then check the connections of your hard disk or ask your technician to do that
Jun 02, 2009 | IBM ThinkPad T20 2647 Notebook
I want USB port Driver for detect
No mention of Brand of Pen Drive so I would start there first.
Try www.pendrive.com
Also no mention of when the latest updates were done ,hmmm
Normally should auto recognise when plugged in
(should do anyway)
When you install usb drive,
and drive does not appear be present,
SOLUTION...............................................................
Assuming your using XP,
go to start
then my computer,
right click,manage,
disk management,
This will put you in the area where you can check the health and activitys of your hard drives,
If this drive was recognised in the port then it will be visable in this area,
here you can right click on the drive and update the individual drivers of each device that may have issues.
So go ahead right click and update the drivers,
click I have disk on the wizard prompt and let the wizard search for the correct drivers,
if it comes back saying please insert cd then let the wizard search the internet for the correct drivers.
If this does not fix the problem then a Factory Default Reinstall will fix this.
If the issue still remains after these steps its the motherboard replacement time.
BACK UP BEFORE FORMATTING.......
Jun 27, 2008 | Acer Aspire 3000 Notebook
System not detecting hard disk
Check the position of the master/slave jumper on the drive.
Oct 06, 2007 | Excelstor Technology J880 Hard Drive
PC not recognising the slave drive
Assuming you set it as slave or cable select as required by the motherboard, you have to first get the bios to recognise it press F2 or Del on boot up to enter cmos and then there should be an option to auto detect drives, save settings for a re boot. When in windows, right click on my computer icon and select manage>disk management and then your drives will be listed, right click on the slave drive and select format or set as active and it will then show, but only 137GB may show depending on the bios version.
Oct 03, 2007 | Samsung (MP0804H) 80 GB Hard Drive
CMOS auto detection of samsung SP0411N HDD stops and hangs
Hi download this program its seagates diagnostic tool, put in floppy disk and run program to make a boot disk, restart pc, and let it boot off the floppy disk and it will test the drive for you... http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=DiscWizard&vgnextoid=d9fd4a3cdde5c010VgnVCM100000dd04090aRCRD All the best john
Feb 16, 2007 | Samsung (SP0411N) 40 GB Hard Drive
Dell SD-616 Internal DVD Drive Logo
120 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
