Question about Dishwashers
I have just purchased a used dishwasher #MDC4650AWW. They said it was 2 years old. It is a portable. I have not been able to hook up yet to see if it even runs. Please let me know what year it is and if there has been a recall and/or trouble for this model.
  • 5,911 Answers
The dishwasher is manufactured by Maytag. The date of manufacture is determined by the last two LETTERS in the SERIAL number. The following link explains:
http://www.fixya.com/support/r2880528-determining_age_maytag_appliance
If you have any difficulties determing the manufactured date, please post back with your serial number and I can assist you. I hope you find this information helpful.
Posted on Oct 03, 2009
I recently purchased a portable Maytag dishwasher model # MDC4650AWW. So far so good but I would like to have a user/owner manual if possible. I am not seeing this model listed and wondered if it has...
You can download the manual from the manufacturer's web site at
http://www.kitchenaid.ca/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%206-920109.pdf
Nov 16, 2010 | Maytag 24 in. MDC4000 Free-standing...
Faucet solution for hooking up portable dishwasher
there is a generic adaptor that fits on your faucet; take the name, model# and, hose to a hardware store and, they can show you the right adaptor for your machine
Sep 15, 2009 | Dishwashers
Water leaks when black valve hooked up to water tap
Hello Wes. Begin by installing a new o ring. Take off the old one and take it to a hardware store to get the correct replacement. Also pick up a little tube of O ring lube.
Jun 08, 2009 | GE 25 in. Nautilus GSC3400J Free-standing...
Maytag portable dishwasher, dish racks are very rusted in 2 years
This is Maytags solution
Do the dishwasher racks have chips or scratches showing exposed metal underneath?
If minor rack repairs are needed, a dishwasher rack repair kit just might work. To review this product or purchase the kit, click here.
Should you purchase the kit online, enter Promo Code F9A75Q4 in the Review Order screen when you check out to receive a 10% discount on your order.
For more severe rack damage, a replacement rack may need to be purchased; call the Maytag Customer eXperience Center toll-free at 1-866-616-2601, Monday-Friday, 8AM-6PM, Eastern Time.
I would call the toll free number and see if a free replacement is available. If not at least try to get a big discount on replacing them.
Good luck and thanks for using Fix Ya, please take the time to rate this solution (from Fix Ya, not Maytag, I didn't like their solution).
clarkco
Feb 05, 2009 | Maytag 24 in. PDC3600A Built-in Dishwasher
Portable dishwasher won't stay connected to the kitchen faucet
it the faucet connector has a lever u push in order to latch on to the faucet, just jam something under it so it maintains upward pressure and wont come unlatched when the water starts flowing
Jan 30, 2009 | Maytag MDB9600A Jetclean II Built-in...
Maytag portable dishwasher is not draining
try to clean the filter by taking off the bottom section of the water jet, it might be clogged, if that does not work, u got the same problem as me, it just wont drain. The pump is probably broken.
Dec 05, 2008 | Maytag MDB9600A Jetclean II Built-in...
MDC4650AWW Portable Dishwasher
We've had a similar problem. A banshee screaming noise that's makes the skin crawl. Since our machine is well out of warranty I took the insides apart and found only a few cherry pits. (Lesson learned, always scrape your dishes before loading.) We covered out ears for a few minutes and the bad, bad noise went away. But the noise came back, it didn't stay away.. So here's what I found with more tinkering.
1. Problem: Small hard things can get lodged in the food mill/grinder assembly at the bottom of the dishwasher tub. It's there to cut up the big chus of organic matter I presume.Today I found a thin piece of plastic about an 1" long that got caught and was resisting being ground(even though we know resistance is futile) by the grinder thing. Anyway, I took the offending piece out, put it back together and the machine is working fine. I have a hunch that the first instance may have been one of those stray cherry pits that broke up enough to get caught.
2. Solution: take apart inside assemblies to get down to the "foodmill" like thingie and see if there's something hard organic or unorganic causing the noise. Discard. Put back together and hope that solves it. (It did for our machine)
3. What's needed? Good knees or a decent knee pad and a few simple tools as follows:
A. 1- medium flat blade screwdriver
B. 2- TORX screwdrivers, # T-15 and T-20, or equivalent bits for a portable electric drill/screwdriver.
C. Small pair of regular pliers or simialr tool.
D. Muttering under your breath like Fred Flintstone, or not.
4. Process:
Take out the water jet assembly. It is held by a clip at the back and top. Use the screwdriver to pry the tabs away from the clips, then pull the assembly out at the bottom where it connects. It's a simple slide in/out fit. The bottom whirlygig water jet is fastened with a threaded cap that can be removed with the pliers. (BTW, this can get clogged with gunk. while you have it of check for gunk. Then, keeping track, remove the remaining hardware with the TORX #T-20 screwdriver until you get to a round black piece. The black piece has to come off before you can remove the piece with the filter and grinding screen. Use the #T-15 bit for removal of the black piece. Then remove the rest 'till you see a "blade". Hopefully in that process, whatever was causing "the noise" will fall out and you can discard it. Observe how gross it is in there, shudder, and begin the process in reverse.
I do have some pictures of the process in stages if you want. E-mail me at: gpfn47atyahoo.ca (note: please use the "@" symbol to replace the "at")
Well, that's it. I hope it helps someone.
Have a Blessed New Year!
Greg F-N
Apr 01, 2008 | Maytag MDB9600A Jetclean II Built-in...
Dishwashers Logo
224 people viewed this question
Top Dishwashers Experts
