Question about GE Monogram ZISS480DRSS Stainless Steel
Any tips on replacing mother board
Hello!  The display went out that tells temp and water disp. status, etc.  I was informed it was the controler board.  I have the part but not the moolah to pay to have it put in.  I am far from a tech.  Any advice on how to replace this mother board in layman terms?
(48" Monogram fridge, part wr55x10159)
Thanks! Count
  • Anonymous Jun 09, 2008
    Temperature control of the freezer and fresh food registers OFF, and custom cooler drawer has no lights including set temperature. The refrigerators bulb lights are all on once 2 doors are opened, but the refrigerator does not cool once the 2 doors are all closed. The whole system is completely shut off once all doors are closed.
  • 833 Answers
Generally, these boards are located behind the button panel on the top of the unit. Find screws or pryouts. Be sure your fridge is unplugged before starting this operation.
Posted on Dec 23, 2007
Amana fridge, AS2628HEK fluctuates in temp.Keeps repeating. Replaced the front display board, has been on lock for some time, ice and water were not operating, now it works again but temps not stable?
Replacing the front display board will not do anything other then tell the main control board what you would like to do. The control board that controls the operation is in the fresh food section up in the console area. What do you mean by temps not stable? Refrigerators do fluctuate in temperature especially after defrost.
Dec 07, 2016 | Amana Refrigerators
My whirlpool double oven accubake GBD307PDS09 display went blank!!!! HELP!
Hello!
This blank display is a common control board problem. If the buttons beep when pressed, then the control board is getting adequate power. If the buttons beep.. and your oven light still turns on when the oven door is open.. this a text book control board failure. We at Fixyourboard.com can solve this problem for you, and back the remanufacture with a two year warranty. GBD RBD Whirlpool Oven Problems Causes and Solutions
May 03, 2017 | Whirlpool GBD307PD Electric Double Oven
Water dispenser on GE side by side not working. what should the refrigerator and freezer settings be? Can that be the problem?
Dispenser controls on any refrigerator actuate one of two things. Ice disp, or water disp. If the IM is not working also, then H20 valve is bad. If just the H20 disp feature isn't working in the door, try this: remove food and unplug unit for 24 hours. Then, plug back in and resume normal operation. If all checks ok, you have a frozen water tank, or frozen water line. Fix: on certain model ref's, there is a water tank service flash where an antifreeze insulation kit should be installed, contact Sears or your retailer for this information. On others, this is simply a freeze up caused by lack of H20 usage or temps in ref/freezer set too low. If this does not fix the water supply, and you still have ice production after 2-5 hours after restarting the ref, remove the dispenser cover and test the water supply actuator switch for continuity. of open after drepression, replace switch. If switch checks ok, then replace water valve as on side of the solonoid valve assy is not functioning. In rare cases, you may have to check or replace the wiring harness. This can be tested only after elimenating the disp switch test, and calling for H20 from the disp, voltage at the disp wires to the H20 valve, but no voltage recieved at the h20 valve, or by an ohm reading of the wires.
Jun 10, 2009 | GE GSS20IEP Side by Side Refrigerator
Speedo unit died then Fuel gauge went to max
the dash control board is the controler for the boards in the dash, fuel temp etc. inside the dash itself, a board on the rev counter controls voltage to feed the the fuel gauge etc. the back of the speedo burnt,there is the 3 pin voltage control chip on the board. you can replace the boards. you can remove them from another dash and place them into yours but if you say the board burnt out on the speedo . then i would just change the dash as it would be easier as you would need to replace the speedo as well. you will also need to inform dvla that the speedo has been changed as for mots its recorded. or have the speedo rectified to the right mileage. not informing dvla can affect your insurance.
Jun 30, 2017 | 1994 Audi Cabriolet
GE Fridge, Compressor not getting power from mother board
I asked that because in most cases, when it is a problem in a motherboard, it is likely a power surge or lightening. I can also tell you that when it comes to mother boards and component level, likelihood, it isn't transistors or anything unless it smells or looks burned. Most shops would just replace the motherboard and ship it as repaired becaue the cost of the IC isn't worth the possibility of something in another IC on the same board knocking iit out again. Short of plug and play, you have no real way of proving this board good/bad. You might try EBAY with your model number to see if you get lucky. I just got rid of an electronic stove because the control board went bad. New board was $150 with a possibility of it going out in 6 months. As I am not made of money, I now have a gas stove. I you could, please rate this as a fixya as I am just being honest and saving you time and aggrivation. Good luck
Jan 10, 2009 | Refrigerators
MY PACKARD BELL PIV HAS N1996 MOTHER BOARD and no display is comming
MY PACKARD BELL PIV HAS N1996 MOTHER BOARD I cant see any display on my screen when i turn on my computer. But it looks it has read all the information from harddisk and loaded the operating system. but on screen i cant see any raster i.e. display.
First At this time u observe one thing check the Numlock Status if it is ON/OFF (Glow ) in Keyboard when u pressing the  Numlock key, the system is giving display check with pci vga card.
If not u  remove the Ram module and heard the Beepsound,if Beep is comming Clean the Ram & Ram slot the try it again
If not check with another Ram module.
If it is also not problem u clear the CMOS once and check it
Jan 22, 2008 | Computers & Internet
Thermador model sc272t oven 2 doors have dim display
there is a dispay kit you can order from bosch to fix this problem. it will come with a new display board and power control which is located behind control panel as well
Nov 18, 2007 | Thermador SC272T Electric Double Oven
GE Monogram ZISS480DRSS Stainless Steel Logo
140 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
