Question about Estate EED4300SQ Dryer
Dryer Drum Seems Unbalanced
The dryer seems to have a thumping sound like there is something in it but nothing is. Is there a balancing that I might be able to fix?
Let me know
David Snyder
  • Anonymous Dec 21, 2007
    Dryer drum is seperating from backside, how do i fix
  • meltramel Nov 04, 2008
    my dryer spins and dries just really loud like there is shoes in there
  • 833 Answers
David...sounds like a bad belt. You will have to remove and install a new one. It could be a bearing...but I doubt it. The issue the guest describes...I don't understand it.
Posted on Dec 21, 2007
Kenmore dryer making a thumping noise
Your dryer has rolls on the drum and they are going bad and need to be replaced
Mar 22, 2014 | LG DLG3788W Gas Dryer
Maytag dryer (LDE5914ACE) loud slipping/thumping sound
yes, it's called a blower wheel... it is what blows the air into the dryer to blow out the humidity through the vent... it has a D fitting and as you use it, the D rounds out and the 'squirrel cage' stops spinning and begins to slip... if you continue to use the dryer without replacing this, you could burn up your dryer motor... it will just over heat....
Mar 19, 2010 | Maytag Dryers
Dryer is making a loud banging noise.
there are bushings or rollers at the front of the drum that do wear out this will cause the thumping as it turns. A local appliance repair place may be able to source out new guides for you.
Feb 22, 2010 | Maytag Neptune MDE5500AY Electric Dryer
My LG Dryer (DLE9677SM) is making a continuous thumping sound throughout the cycle. Sounds like shoes in the dryer. Drum seems like it has excessive play in it...I can move it around from side to side.
you have a worn belt tensioner pulley that needs to be replaced. replace the belt as well for it will be worn from the bad pulley. the inner bearing has locked causing the roller to seize up receiving a flat spot on the roller making this drum thump
Feb 20, 2010 | LG DLE5977 Electric Dryer
Belt and drum turns but with a thumping sound.
check the idler pulley, it could be broken. Also check the inner side of the belt for a chunk missing.
Oct 03, 2009 | Maytag Dryers
Dryer has thumping noise.
Yes that is what most likely is the problem to begin with. The drum usually never goes out of round . Replace bearing best choice
Aug 28, 2009 | Dryers
Frigidaire Dryer making loud thumping noise in back.
Some things to check.
Worn rear drum rollers, idler pulley, or drum front slide kit.
Click here for illustrations.
Hope this helps.
Aug 12, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Dryer is making loud thumping noise.
Take off the back panel of the dryer and look at the motor and belt turning the drum. There may be something caught on the drum and is pinned in place causing the noise. The motor could be loose on the platform and needs to be tightened. It is probably something physical and seen causing the noise.
Jan 04, 2009 | Whirlpool LER4634J Electric Dryer
Estate EED4300SQ Dryer Logo
289 people viewed this question
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
