Question about Dryers
Drum will not turn and buzzing sound coming from timer
I have an electric kenmore dryer, model 110.C65654400, which is not turning when we turn the timer to dry. There is also a hummnig sound coming from this timer. I noticed that the heat is on and at times the buzzer works.
    Problem Solver:
  • 16 Answers
Try checking the motor, drive belt & such. the humming sound is likely a motor working against more resistance than it can handle. lubrication of all the bearings & bushings may help as well, many of these have a hole at the top for putting a few drops of oil in. to test if the motor works, remove the drive belt & see if it spins with the load removed.
Posted on Oct 03, 2009
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
Kenmore 110 65942401
sounds like it needs replaced? I assume by not working you have to turn it off manually? 9r does it even come on heres a link?.... http://www.repairclinic.com/vwo1/Kenmore-Dryer-Model-11065942401-ID-699123-Circuit-Board-Timer-Parts
Aug 19, 2013 | Dryers
Stopped working. Circuit breakers are not tripped, electrical plug in all the way
Hi and welcome to FixYa, I am Kelly. After this post I will need your dryers' complete model number For now check the door switch. As you just open or just close the dryer door, listen for an audible "Click" as in a micro-switch clicking sound. No click = door switch problem
Also open the door and turn the dryer drum by hand. It should also be turning the motor as you rotte the drum in both directions. I you can not feel the motor rotating or... it rotates in one direction but not the other there is a belt problem. The drum should not easily turn 360 degrees.
Check the door switch and check the belt. If after this is is still dead... there is more that can be done but, I need a complete model number for further comment. The model number will be 3 digits followed by 8 digits 110.++++++++
Thanks for choosing FixYa,
Kelly
Dec 15, 2010 | Kenmore 60172 Electric Commercial Dryer
Kenmore Dryer - No Heat
110 comes from the motor 110 comes from the timer remove the wire that comes from the motor see if you have 110 if you do the timer is bad if not the motor is. even if the motor is turning its bad
Jun 07, 2010 | Dryers
Kenmore dryer problem
Good day,
Sounds very much like the motor is going bad. Very slim chance that the timer could cause that problem because of pitted contacts, but that would not explain away the noise when trying to start.
Here's a good tutorial if you want to replace the motor.
http://www.applianceaid.com/wpmotor-change.html
Apr 01, 2010 | Kenmore Dryers
Dryer won't start
The problem is likely a malfunctioning centrifugal start switch in the motor.
More info, let me know.
Charlie
Aug 20, 2009 | Kenmore Dryers
Dryer drum will not turn.
Hello.
If the buzz continues to go for awhile(2-3 minutes before you stop it you will need to replace the belt on your dryer.
If the buzz quits pretty quickly after you let go of the start button and you smell something hot or electrical, you will need to replace the motor.
Please let me know if you have any other questions.
Jul 22, 2009 | Kenmore 94052 Dryer
Kenmore dryer not running
Ticking sound is the timer running--so it is not the problem unless a contact has failed or a wire has come loose.  Broken door switch, thermostat failed in open position, or clogged lint filter/exhaust vent/outlet would keep unit from running.  If you can hear the motor running but the drum is not turning then the drum belt is broken.
Jun 04, 2009 | Dryers
Kenmore 970 C81062 10 Electric Dyer WILL NOT
It sounds like the drum may be stuck. Turn the dryer on with the door open, just keep the button pushed. Then try to turn the drum by hand, and see if it will start to turn.
Dryers Logo
66 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
