Question about Pentax Optio 43WR Digital Camera
Memory card error now appears on the screen of my camera and I cannot take any pictures. It doesn't work when I attach to my PC either
  • carol_sear Oct 04, 2009
    Hi dimdimdim and thank you for your post. Apologies, but I cannot see a solution in your post or anything related to my problem. I'm new to this site so perhaps I'm doing something wrong? Regards
Brault
SOURCE: Memory card error
I have the same problem, just started this week. I've been using this camera for 4 years, over 8500 photos, with no problem like this...
Posted on Jun 10, 2008
SOURCE: plug usb lead into side of camera pc does not recognise camera so cannot pictures from memory card to pcdownload
After trying different suggestions I inserted the c d that came with the camera while the transfer cable was still attached to the camera, and this seamed to solve the problem, the p c read the memory card and recognised the camera and all went well from there.
Posted on May 05, 2009
  • 11967 Answers
SOURCE: memory card error
Are you formatting the camera or the memory card? You should do both. Also, make sure of the position of the slide switch on the side of the card.
Posted on Nov 30, 2009
  • 11967 Answers
SOURCE: My camera doesn`t read memory card.I tried with 2
On most cameras, once you start to use the internal memory, the camera doesn't want to read a memory card. You need to go into the menu and "reset" the camera. Then, with no card in the camera, go into the menu and "format" the internal memory. Then, insert the card and "format" it. This will erase it so download any pics first.
Posted on Mar 01, 2010
lock123
  • 6831 Answers
SOURCE: When I insert a memory
Hello
Ok, here is something that just might work.
In your case the problem is not with the card but rather with your camera's card reader. This is a rather hard problem to fix yourself but here is what you can do.
Open the card slot of your camera and peer inside with a sharp light or torch. You should see a little metal tab or switch inside the card slot. This is the write protection switch. Contrary to popular belief , the switch on the card does not impact the operation of the card itself but rather tells the camera that the card should be locked by depressing the little pin inside.
If you put a protected card into a camera with no protection switch , the card would operate normally.
However , with time and repeated use , the switch will start to bend slightly until it will no longer depress when a unlocked card is inserted.
With a toothpick or needle , slightly and very gently push this tab up a little bit. (some camera's will require you to pull the tab down), This will allow the switch to operate once again and should solve your problem.
Kind Regards
Andrea
Posted on Aug 13, 2010
File error appears on screen when viewing pkotos
can have different causes. To many pictures on the memory card card is full. From the last picture file name ends with 999 or 9999.
Or there was an error while writing a picture to the memory card, caused by a power failure.
I would put the card in an external memory card reader and try to put all pictures in a folder on the computer. Then format the card FAT 32 or FAT 16 and then put it back in the camera. When switched on, first format the card again, in the camera, to make sure the camera can work with the card and the format.
Success.
Apr 19, 2015 | Cameras
I have a J10 fujifilm camera and it currently has an error message: FRAME NO. FULL! I have the following picture card: Fujifilm xD xD-Picture Card M1GB Any advice would be appreciated.
Try formatting the memory card. If that doesn't work, try a different memory card. If that doesn't help, sadly, it's probably time to return the camera if it's still under warranty.
Jul 13, 2011 | Fuji FinePix J10 Digital Camera
What do I do when screen says file error
file error appear on the camera because of corrupted file or virus attached in the pictures due to incomplete saving or virus attached on mmc upon conncting to the pc. "dont panic". the first thing to do is back up your pictures to your desktop or laptop. then the next thing was format the memory card.After reformatted insert the mmc to the camera then take atleast 15 pictures and try to preview it.
If same problem occured, try to contacted the service center near you.
hope it will help..
Feb 05, 2011 | Samsung L200 Digital Camera
How do i get the internal memory pictures onto my computer?
Simply remove the memory card from your camera before connecting the camera to your computer. The computer will then see the camera's internal memory instead of the card memory, and you can copy the pictures over.
If you have been accessing your pictures by removing the card from the camera and placing it in a card reader attached to your computer, then this won't work for pictures in the internal memory. You will need to use the other method, connecting the camera to the computer with the USB lead.
Dec 02, 2010 | Panasonic Lumix DMC-FS3 Digital Camera
My digital sony camera has file error with a blue screen on certain pictures. What does this mean?
That symptom appears when memory card in camera got defective/ imbalanced.
Format memory card in camera by camera Menu, Format option and problem will be fixed.
Note, all data/ pictures in memory card will be deleted by formatting so take back-up of importatnt pictures.
Thanks.
Feb 19, 2010 | Sony Cyber-shot DSC-W120 Digital Camera
Xd memory card
A card access error may indicate that an xD-Picture Card memory card is in a write-protected condition. xD-Picture Card memory cards have a special protection feature to ensure that your pictures are kept safe. NOTE: During this condition, you can still use the printer for printing and saving photos from the xD-Picture Card to a secure location, such as the computer hard drive. To resolve this error, try the following:
  • Reinsert the xD-Picture Card memory card into your camera and turn on the camera. In most cases, the camera automatically makes the necessary changes.
  • Reformat the xD-Picture Card memory card. See the documentation that came with your camera for instructions on reformatting the memory card. Note that this process erases the pictures currently saved to your memory card. To save these pictures, transfer them to the computer before reformatting the memory card. Once you reformat the memory card, transfer those photos back to the memory card using the computer.
Jul 29, 2008 | Fuji FinePix Z10fd Digital Camera
I have error 99 in my camera canon 400d
Error 99 is a general fatal error.
which includes the problems above mentioned by Q4SteveB but also many others.
It can be caused by a dicky shutter, problems with the CF card interface.
If cleaning and trying a different lens has not worked. Not definitive but as a rule of thumb...
If it letting you take one picture then giving error 99.. and the picture is saved to the card (but may just be black) this is most likely the shutter needs replacing..
If it takes a picture and gives error 99 but there is no picture on the card or the picture is 0KB its a CF interface problem.
If you get an error 99 when you plug in the USB its a USB interface error, you can try a different cable but unfortunately in most cases if another lens or cable wont work it needs repair
Feb 22, 2008 | Canon EOS 30D Body Only Digital Camera
Gateway Camera DC-T50
Check memory card from computer with card reader.
If that doesn`t help.
Try formatting memory card from camera or from computer (it will destroy data on card).
Most likely your pictures are alredy lost.
Feb 13, 2008 | Gateway DC-T50 Digital Camera
Pentax Optio 43WR Digital Camera Logo
60 people viewed this question
Top Pentax Cameras Experts
mohamed salim shaikh
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
