Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
2 problems Time sticks at 001min. not drying - Hotpoint Aquarius WD640 Front Load Washer/Dryer
    Genius:
  • Hotpoint Master
  • 1,461 Answers
Are you not able to turn it on. Is it mechanical?
Posted on Oct 03, 2009
How much atf do I put into a Mitsubishi Magna executive 1996 v6 when completely dry
If you mean when you dipstick is completely dry, there is no sure way to know exactly how much is needed. even when the stick is dry there is still some in the pan so no telling exactly how much is beyond the stick. Safe bet is you will need at least two quarts of fluid. Add 1/4 quart at a time until you see something on the stick. From there at smaller amounts till it gets to the normal range. Keep in mind that you should be at normal operating temp so once it is close, drive the car for a few minutes then check and add more if needed to get to the "hot" fill range on the stick.
Nov 19, 2016 | Mitsubishi Magna Cars & Trucks
I have a 99 jeep it started acting crazy and checked the oil the dip stick said it was bone dry so I put 3 quarts in it and checked the oil again and this time it was about 3 quarts to much
my guess is you used the wrong dip stick,
i cant watch you mess up. so....no jeep stated a 99 what?
wrangler, Cherokee or grand Cherokee?
so i bet you have an automatic trans, right?
then pulled the dip stick on trans thinking its the engine
or the reverse. bad news if true.
rigth?
find someone that knows the difference or read the lost operators guide.
and error 2, the stick empty is not bone dry, not ever.
yes real low. so and 1/2 quart at a time , not 3 qt ever.
until the engine stick is at normal..
if this is a transmission, and you put engine oil in there
all hope is lost. and the method is hot running, to add ATF fluids.
unlike the engine method.
my best guess totally BLIND>
Aug 25, 2015 | Jeep Cars & Trucks
Why do front wipers on1999 Ford Windstar stick when window is dry work fine when window is wet ?
wiper blades are miniature squeegees and need water to lubricate the surface so that the dry rubber doesn't stick to the glass and so jump. The problem is made worse if the blades are old and hard.
Aug 17, 2014 | Cars & Trucks
How long to joint compounds have to sit to dry?
The time it takes for the joint compounds to dry depends on brand that your using. Generally 12 hours is enough, I like to let it dry over night.
Nov 10, 2013 | Adhesives, Coatings & Sealants
Does oil paint sticks dry slow?
Yes, Oil paint sticks have a slow drying time just like oil paint in a tube which gives you plenty of time to create your painting.
Feb 03, 2013 | Crafts & Hobbies
Oil dipstick tube broke
look on dip stick you should see cross hatched area with add oil or oil full mark.if you wipe oil dip stick with a clean paper towel and dip stick look dry no sign of oil add little oil at a time see if oil level reach add oil mark or the full mark.if oil is low. low oil light will turn on if bulb is blowed but if dip stick look dry oil level could be low,add little bit at a time dont over fill.
Feb 16, 2012 | Cars & Trucks
Damages joy stick, cannot move up, down, left and right
Most of the time joystick problem can be corrected by :-
-put some servicing liquid like petrol on joystick area and move your joystick up dpwn left right
then dry your board .
- most of the time this problem will be solved by this process. if not then change your joystick
Oct 20, 2010 | Sony Ericsson K700
Dryer won't heat and the timer doesn't move. It runs forever with no heat.2 different problems?
if you have timer on time dry and it doesn't move timer is probably bad, if you have it on auto dry or some say more or less the timer will not move if there is no heat
Nov 10, 2009 | Kenmore 63942 Dryer
My lincoln drivers side window sticks sometimes can i clean the switch?
Had the same problem with power windows sticking, either the motor is old and getting weak, or, a quick check fix is that as the weatherstripping gets old around the window it dries out and gets hard, the window when it slides will tend to stick on the weatherstripping, try cleaning the weatherstripping around the window with alcohol, then soak the weatherstripping with armor-all, or some spray silicone lube, you will probably have to do this from time to time, otherwise you can replace the weatherstripping..
Aug 22, 2009 | 1996 Lincoln Town Car
3 beeps wont boot
it is probably a ram error,
Unplug the computer and unclip the ram and remove it, clean the ram sticks and the slot that it goes into with a small dry paintbrush. While you have the unit open clean the dust away with a small paintbrush and a hoover at the ready. If you have more than one ram stick, replace one at a time to determine if you have a problem with both or one. If it boots with one, then shut down remove plug from wall socket and then replace the other one too. If it works okay then fine, if it causes problems then you know that the other stick is bad. If it does not boot on replacing first stick, then remove it and put the other stick in and try again.
I hope this helps
Nov 15, 2008 | E-Machines eMachines Desktop PC
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
37 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
