Question about Whirlpool 25.3 Cu. Ft. Frost-Free Side-by-Side Refrigerator w/Thru-the-Door Ice and Water - Satina Stainless-Look
Whirlpool My Whirlpool GD2LHG refrigerator quit cooling, icemaker and freezer not working. I keep hearing a clicking noise like a switch. How can I fix this myself? Model GD2LHGXLQ04 Thank you
  • 4,070 Answers
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Posted on Oct 03, 2009
Side by side fridge not working has power but not cooling compressor not coming on whirlpool gold series gd2lhg
Hello and sorry to hear about your problem. It sounds like you have a general compressor or control card failure.
You will need to call a service person.
I have tried to help you. please help me by Vote/Rate my response thanks.
If you live in the Denver area, I can help you.
Dec 21, 2010 | Whirlpool Refrigerators
Refrigerator not cooling has a clicking noise like a switch is trying to click on
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 02, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
My top freezer is not cooling, but the refridgerator section is cooling. Refridgerator makes a clicking noise. What could be causing this? I have a Whirlpool 21.0 cu.ft with icemaker
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then checkout the last two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Sep 20, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool refrigerator side by side freezer won't freeze
your over-load/contactor is defective, un plug it from compressor and shake it if it rattles its bad
Oct 28, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool Gold Model GS5SHAXNL 00 makes loud grinding noise about every 40 minutes
I would check your ice maker. You can shut it off by slidding the control on the right hand side of the freezer wall. If the noise quits you need to repair the icemaker. In door ice has had some problem with their icemakers. If that is it they make a kit part #8201515 that will fix it.
Sep 15, 2009 | Refrigerators
Freezer is working but the firdge part is not cooling.
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
  36. Some help for an Amana refrigerator fan motor that will not run
  37. Will my freezer or refrigerator work ok in my garage?
  38. Whirlpool built refrigerator defrost timer installation help
  39. Water line "Y" hose for icemaker broken helps
Apr 01, 2009 | Samsung Refrigerators
Fridge and Freezer losing cooling
thermostat control to deice the freezer is malfunctioning need a service tech to replace it so it doesn't keep the deicer on . Its exactly that, a warmer to deice the coils.
May 27, 2008 | Fisher and Paykel Active Smart E522B...
Whirlpool Refridgerator + ET1FTTXKQ02 - Water leakage!
Own the same model, the icemaker and the dispenser work properly but the leak is top center of the refrigerator compartment.
Nov 08, 2007 | Whirlpool ET1FHTXM Top Freezer...
Whirlpool 25.3 Cu. Ft. Frost-Free Side-by-Side Refrigerator w/Thru-the-Door Ice and Water - Satina Stainless-Look Logo
405 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
