Question about Pride Value Line Revo Scooter 3 Wheel
My scooter was running fine a couple of days ago and now won't run. I've charged it with no results. Is there something else I can try?
  • 29 Answers
Does it give a beep code? do you have your manual? smithrm70@hotmail.com
Posted on Oct 24, 2009
Mobility scooter
Check the freewheel lever is not engaged.
Jun 03, 2017 | Health & Beauty
96 GMC Yukon won't turn over
Thats what i would try and if that dont help, maybe check the connections at the starter.
Feb 18, 2013 | 1996 GMC Yukon
I have a Pride legend three wheeler- I replace the battery charger because it would not charge the batteries. I pluged the new charger into the control module it will charge the batteries. Batteries are...
if I understanding this correctly , you cannot use the scooter why it is being charged, there is a inhibit pin that stops the scooter from being used,
All scooters are designed this way.
Regards
Dec 14, 2012 | Pride New Mobility Legend 4 Wheel Scooter
Roketa scooter won't start
Hi, Ammoncrosset and the usual suspects are:
1. Fuel tank empty.
2. The fuel tank has old dead gas.
3. Fuel tank bottom contaminated with ethanol sludge, dirt, water, rust, etc.
4. Fuel supply valve/petcock turned off.
5. Fouled spark plugs.
6. Engine flooded as a result of overuse of the enrichner.
7. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
8. Fuel valve/petcock or filter clogged.
9. Fuel line to carburetor or throttle body pinched, kinked or blocked.
10. Carburetor float stuck.
11. Fuel injectors clogged.
12. A severely discharged or damaged battery, you need 12.5 volts or better and be able to pass a load test if necessary.
13. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
14. Loose or corroded wire connection at the coil or plug between ignition sensor and ECM module.
15. Spark plug cables in bad condition and shorting check for spark leakage in the dark, cable connections loose, or connected to the wrong cylinders.
16. Ignition timing incorrect due to a faulty ignition coil, ignition module or MAP, CMP, CKP, O2, TPS, ETP, IAC sensors.
17. Faulty neutral, clutch lever, or kickstand safety switch.
18. Faulty fuel pump or fuse or relay.
19. A stuck bent or burnt valve.
20. Tilt sensor needs a reset.
21. Security system not disarming alarm needs a reset.
22. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
cranks but wont start
Scooter Troubleshooting Scooter won start All about Scooters
http://www.family-motorsports.net/GY6-50cc-150cc.pdf
http://www.roketapartsdept.com/catalog/Scooter_Parts-52-1.html
Roketa MC 08 50 User Manual
Mar 19, 2017 | Roketa 50cc Gas Moped Scooter
Razor Bistro scooter won't take charge - light stays red
i had the same problem with mine and it ended up being that one of the batteries was bad, there are two 12v batteries wired in series under the seat, usually you can tell which one is bad by looking at them, one of the batteries will be swelled up
May 09, 2012 | Razor Pocket Mod-bistro Retro Scooter
My 2001 Saturn SL1 with 140 miles won't start. It was running fine then went out to start it this morning and nothing. When I try to start it the clock on the dashboard resets. Headlights won't...
put a drop tester across the battery its flat for whatever reason or had its life so try charging it with a trickle chearger for a couple of days and if still no start then renew it
May 21, 2011 | 2001 Saturn SL
Hi there.I ve got this strange problem with my satelite Toshiba A200 1AB laptop.the problem is with the battery actually it wont charge when I plug in the charger with battery in it.But when I extract the...
Is the AC Power adapter the original adapter of the laptop? If it is, try to drain the battery and charge it for 8-12 hours without using or opening the laptop just charge it. After charging, remove the power adapter as you open your laptop. Make this way a habbit of using and charging your laptop to make the charging and battery life last long.
Mar 11, 2011 | Amstron Toshiba Satellite A200-1AB Laptop...
Shoprider cadiz scooter, batteries show full charge when first charged up but when driving scooter battery power runs out after about 3 miles. brakes work fine, no noises from motor or gearbox, what's...
I think your batteries haven`t been charged properly,or they have been left standing so the charge has leaked out.At a minimum your batteries need to be charged for 12 hrs a day for the first month if not they will not build the capacity and will dwindle and die for example it is at only 25% capacity,but looks like a fullcharge, it says it fully charged but will die
quickly this happens because it is charged to its full capacity but that is only 25% of the batteries true potential
resulting in short battery life.
Unfortunately majority of scooter batteries like this have to be newly replaced.
Nov 06, 2009 | Health & Beauty
Scooter is dead
Are you sure your charger is working? Is the free-wheel lever engaged? Also the charger has an inhibit line, it will not run when the charger is plugged in.
Nov 16, 2008 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
Pride Value Line Revo Scooter 3 Wheel Logo
167 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
