Question about Microsoft Windows Vista Ultimate Edition
Prints wrong on windows Vista
I have create a card plus 3 installed on my olde exp computor, It works find , but when I install on vista it prints the inside of the greeting card backwards. This is a ssingle fold card, half page. How do we fix it?
Roy Hickman
birddog31@hsnp.com
8142 Park Avenue,
Hot Springs, Ar 71901
    President:
  • 2,666 Answers
That would point to either an incompatability with Vista or incorrect config settings.
Posted on Oct 03, 2009
Lexmark 3350-Vista-Prints but Won't Scan
Is this the driver you downloaded. If so , sounds like a Lexmark software or driver problem. I am a little confused as the heading on you question says x1270 but the bold type says 3350?
http://downloads.lexmark.com/perl/downloads/downloads.cgi
Dec 24, 2008 | Lexmark X1270 All-In-One InkJet Printer
Hp psc 1210 not working in vista - but diagnostic utility shows all ok - and prints test page
Here is the full-write up on the HP PSC1210. Read through this thoroughly to ensure that you follow all the steps to make it work in Vista, since there is no Vista native driver.
Hope this helps - remember to rate :)
Oct 02, 2008 | HP PSC 1210 All-In-One InkJet Printer
Creatacard 3
i hate Vista as well. i am trying to find a solution. my whole life over the past couple of years is wrapped up in the eventminder and fmnot32 files but after installing Creatacard on my machine with Vista, it will not recognize the files.
i open my address book, it's empty. i open my calendar it too is empty. how can i get this program to recognize the files i copied from the old machine? PLEASE HELP! i've tried everything including dragging them both over at the same time (file plus .BAK). i don't know what else to do.
Apr 23, 2008 | Broderbund American Greeting CreataCard...
Windows vista
How To Make Vista Bootable DVD with WIM Downloaded Files If you have purchased Windows Vista online and taken the delivery of the latest operating system via web download from Windows Marketplace, you would ends up with a few downloads with .wim and .exe file extensions. Rather than paying additional shipping and handling charges, you can burn or create a bootable ISO DVD image from downloaded Vista files with the following trick, where the .iso image can subsequently write to a DVD. The DVD created will be the typical 32-bit Windows Vista DVD that available in retail channel, and can be used to clean install.
How to make a bootable Windows Vista ISO DVD media
1. Put all 3 downloaded files (namely install.wim, boot.wim and an executable X13-49120.exe) in the same folder (for this tutorial, let’s assume the files are put on C:\ else you need to modify the path accordingly).
2. Run the X13-49120.exe executable. Windows Vista Setup Preparation will create a new folder “Vista” inside the folder and will populate the folder with all necessary Vista setup files which takes up about 2.52 GB disk space.
3. Exit from the Install Windows screen.
4. Download CDimage 2.52
5. Extract CDimage from CDimage.zip to the C:\ root directory.
6. Open a command prompt shell, and run the following command:
cdimage.exe -lVISTA_EN_DVD -m -u2 -bC:\Vista\boot\etfsboot.com C:\Vista\ C:\Vistax86.iso
Bootable Windows Vista x86 DVD ISO image in UDF format will be created as vistax86.iso in C:\ or any folder you specified above.
7. Burn the newly create ISO with a CD/DVD burning software such as Nero or Alcohol 120%. Try to burn at low speed (i.e. 4X) and turn on verification to ensure that the DVD creation is fine.
Create a Windows Vista ISO image and DVD with Oscdimg
Another possible way to create a bootable Vista ISO and DVD is by using Oscdimg CD-ROM and DVD-ROM Premastering Utility, available via WinPE (Windows Preinstallation Environment) via Business Desktop Deployment 2007 or Windows Automated Installation Kit (AIK)
1. Complete step 1 - 3 as above.
2. In the command prompt window, run the following command:
oscdimg -bC:\Vista\boot\etfsboot.com -h -u2 -m -lVISTA_EN_DVD C:\Vista\ C:\VistaDVD.iso
A VistaDVD.iso UDF DVD image will be created and can be used to boot the computer from DVD to install Vista.
3. Burn the ISO image file by using last step above.
Mar 24, 2008 | Computers & Internet
HP DesignJet 450c driver for windows vista
THIS SOLUTION IM ABOUT TO TELL YOU IS IN MY EXPERIENCE THE EASIEST ONE JUST DOWNLOAD THE WINDOWS XP DRIVER FOR THE HP DESIGNJET 450C PRINTER AND INSTALL IT INTO THE WINDOWS PRINTER PLATTFORM, YOU MAY SEE SOME ANOUNCEMENTS FROM YOUR COMPUTER TELLING YOU THAT THE PROGRAM YOUR TRYING TO INSTALL MAY NOT BE COMPATIBLE "DONT LISTEN TO THEM" JUST CONTINUE YOUR INSTALLATION AND PRESTO YOUR DESIGNJET PRINTER WILL WORK PERFECTLY
Feb 20, 2008 | HP DesignJet 450c InkJet Printer
Problems loading Vista
What edition of Vista do you have? Without full version you can't put vista on first. You will need to have an old windows virsion like 98, 2000, .xp
Vista has about 7 differt Editios exp Home version complet, or upgrade,
Prof upgrade, or profel
if you have bought upgrade profl. You will need to have an old op of xp prof.
Jan 06, 2008 | Dynex DX-UC104 (DXUC104) Serial Adapter
HP PSC 2210 Vista prints part of page
Call HP tech support - they walked me through an easy work-around that solved this problem for me.
Dec 06, 2007 | HP PSC 2210 All-In-One InkJet Printer
BAD, BLURY, SMEARED, PRINTING
This is from the lexmark website
"Attention Windows Vista Users
If you have installed your printer on your PC using an original Lexmark Driver CD that came with your product and you are experiencing problems when printing, you may have installed the Windows XP driver.
Follow these steps to resolve:
· Disconnect your USB cable from your printer.
· Uninstall all Lexmark printer drivers on your PC.
· Download the correct Vista driver for your model.
· Install the driver on your PC.
Important - Do not reconnect the USB cable until the install software prompts the question of how the printer is connected."
Oct 26, 2007 | Lexmark X4270 All-In-One InkJet Printer
Network link
Did you make sure that you installed the latest driver from HP's web site for Vista? Some systems will grab the wrong driver if you let it do an automatic install.
Jul 03, 2007 | HP Deskjet 3845 InkJet Printer
Microsoft Windows Vista Ultimate Edition Logo
55 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
