Cctv monitor I have a white band across the screen. Any ideas. Regards .Joe
    Problem Solver:
  • 20 Answers
Firstly check poewr supply amp and volt and check for lecage current of Vertical yoke coil and next step check all capaiciter in E.H.T Section .if problem is not solve then check monitor for mositure.
Posted on Dec 29, 2007
    Problem Solver:
  • 5 Answers
Xxz
Sound like the vertical deflection circuit is defrctive. Check for cold solder around the vertical IC, Check the Diode and cap that supply power to the Vertical IC. If it still do not work, change out/ replace the virtical IC.
Jerome
A horizontal band of green and red lines across the screen
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Type in the brand name to your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Mar 17, 2015 | Panasonic TC-P46C2 - 46 Inch 720P Plasma...
Display problem
Sounds like the LCD has some damaged crystals in it. Try connecting the netbook to an external pc monitor using a VGA cable. Hold the Fn key and hit the F8 or F7 key until the display shows on the external monitor. This will determine if it's a driver/settings or display issue. If the display is fine on the external monitor, the LCD display on the netbook is the problem. Good luck!
Jun 06, 2012 | Computers & Internet
My side bar on acer monitor screen has become white. How can I solve this problem? I was told to click on the auto configuration key but can't find it.
If you have a white bar running up the side of the monitor, then it is probably dead. Acer has 3 year warranties on their monitors so you should call them to see if you are still in warranty. If so, they will fix it free!
If more than 3 years old, try it on another pc. If it is the same on another pc, get a new monitor.
Hope this helps!
Regards,
Joe
Apr 04, 2011 | Acer AL2223W 22" LCD Monitor
Band of virtually solid white lines (ca 7cm wide)
check on bios if still there then monitor needs repair.
Sep 15, 2009 | Dell E176FP 17" LCD Monitor
White Vertical Band on Screen
Hi...there,
It's seems you got a busted screen panel...
Dec 15, 2008 | Dell E171FPb 17" TFT LCD Flat Panel...
Focus on monitor
Try replacing the filter capacitors on the video circuit.
Apr 28, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
HP L1706 monitor with thin white/blue horizontral line
It is the problem of monitor pcb in vertical section.check vertical ic for dry soldring. Resolder the ic if problem still on then change ic or check components related ith it. check continuity of vertical deflection coil.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Mar 13, 2008 | HP L1706 17" LCD Monitor
Wide vertical black and white bands
Hi, You may want to try and unplugging the power and video connectors of the Dell monitor. Check for anything out of the ordinary with the AC plug and the video connector. If none, plug them back in making sure that they are snug and fitted properly. If problem persist, see if it is possible to rotate the way the AC plug is connected to the mains (sometimes this works and can be done if you are not using 3-prong or the uneven 2-prong AC plug. Sometimes, this can also be done on the other end of the AC plug). Check your docking station (though unlikely but possibly). If still a no go and your laptop works ok, then your external monitor needs some looking at. This would involve circuit analysis and component level repair. Perhaps your best bet is to have a qualified professional take a look at it. Good luck and pls post back how things turn up or if you need further information. Kind regards.
Aug 20, 2007 | Dell E171FPb 17" TFT LCD Flat Panel...
Horizontal banding on Dell monitor
Hello, My name is Richard and I am part of Dell's Online Community Outreach group. Looking at you monitors issue; it would be most advantageous that you contact our technical support. Your monitor seems to be a fairly now model and is probably still under warranty. Call 1-800-WWW-DELL and provided the technician the PPID number on the back of the monitor. The Dell rep will be able to determine your warranty options. Regards, Richard B Online Community Outreach
Jun 21, 2007 | Dell E173FP 17" LCD Flat Panel Monitor
Computers & Internet Logo
507 people viewed this question
Alun Cox
David Payne
David Payne
