Question about Cameras
Hi ive got a casio exilim exz10000 camera. Ive got pics on the camera memory but didnt get a data cable with it so can i transfer the pis on to a memory card? or are they stuck forever. Thanks Tracy
How do I transfer pics on internal memory to external memory Casio Exilim Z77
Hi, just follow the instruction below
PREVIEW - MENU -PLAY then look for the COPY here you can choose (Built-in to card / Card to built -in) so you need to choose the first one.
goodluck and thank you my friend
Jul 18, 2010 | Casio Exilim EX-Z77 Digital Camera
After transferring pics to my pc, when memory card is back in camera, it says no files are there. how do i retain pics on memory card to show on camera?
Check for a setting in the software that deletes pictures fom the card when transferring pictures. Set it to another setting, if this is available.
Jul 04, 2010 | Casio EXILIM EX-Z1000 Digital Camera
I lost the download cable for my Exilim camera. There is a picture in the internal memory that I really, really need! How do I transfer the picture in the internal memory on to a memory card?
This procedure will copy all files from internal memory to a memory card.
1. Load the memory card to which to copy the files.
2. Turn on the camera, enter the PLAY mode, and press the MENU button.
3. On the "PLAY" tab, select "Copy" and then press right-arrow.
4. Use up/down-arrows to select "Built-in->Card" and then press SET.
Wait until the Busy message disappears before doing anything else. After the transfer the last file transfered will appear on the display.
Apr 14, 2010 | Casio Exilim EX-Z77 Digital Camera
Casio exilim z750 sd card unreadable
If the memory card is not recognized in the PC or it is impossible to access the data on it, the controller on the card is damaged. There is only one way to get the data back, unsolder memory chips and directly access their raw data with a programable chip reader. Software can't help, that is a physical damage! Have a look at: CF xD SD memory card/stick photo recovery
May 08, 2009 | Casio Exilim EX-Z750 Digital Camera
Hi i have a Casio Exilim 8.1 digital camera, ive had it about a year and its worked fine but ive just put it on charge and on the charger thers a red flashing light, were normally the red light doesnt...
The cradle is defective.  Casio replaced the first one of mine for free then they told me to sit and spin when the second one broke 8 months later.  I had only used the camera ~ 10 times.  So, I went to a big box electonic store (Best Buy) and bought a Digipower travel charger.  It charged the battery up just fine.  I also bought a Dynex Memory Card Reader/Writer to transfer the photos to  my computer.  Good luck.  The defective cradle is a known problem that Casio is refusing to correct.
Jan 25, 2009 | Casio Exilim Zoom EX-Z80 Digital Camera
Blurry?
i have the same problem buy a sandisc memory card not any off brand ones such as A data and it should be just fine i dont know if you have noticed by if you take pictures without the memory card just using the cameras built in memory the pictures show up fine
Apr 10, 2008 | Casio Exilim EXZ75 Digital Camera
Cameras Logo
60 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
