Question about Compaq MS Pocket PC 2002
Problem with hard reset
I have Toshiba e 350. when i hard reset it, it stuck onpop-up menus after the align screen. I ahve tried several times to hard reset it, it came out the same. kindly suggest me what should be the step that can help me to solve this problem.
It seems to me the operating system is damaged, anywhere to re-install the operating system?
Thank you
Edward
  • 1,006 Answers
Problem with registry :
Download from google registry repair and try to install again..If still not working just email me at : fixya-expert@live.com AND I WILL send to u screen shoot how u can REINSTALL OS!
Posted on Dec 21, 2007
How to reset error copier mechine estudio 2006
The Toshiba eStudio 350/450 copier is one of the more popular copiers available in the marketplace. It has several features that make copying, printing and faxing easier, such as password protection and customizable settings. There are times, however, when a lost password must be recovered. Toshiba has provided a simple method to recover the password and, if need be, reset the copier settings.
By Daniel Valladares
Resetting a copier to its original settings is a simple way to fix several problems.
Step Make sure the machine is off. While holding down the "0" and "8" buttons on the keypad, turn the copier back on. Keep holding the "0"' and "8" buttons until the copier lets out a long beep. This will activate "Test Mode D."
Step Type in '263' on the keypad and press the green start button. The password should now show up on the copier's screen. At this point, you can type in a new password if you choose to do so.
Step Press 'Set' to set the new password. Turn the machine off, wait fifteen seconds, and then turn it back on.
Step Go to the functions you wish to reset through the main menu and press "Function Clear." If prompted, type in the password. Repeat for any function you wish to reset.
Oct 11, 2017 | Office Equipment & Supplies
When I turn on my toshiba tp4880a tv it turns off immediately and then I have to unplug and plug it back in several times to get it to power on
You are probably experiencing primary stages of a convergence IC failure. This repair is composed of replacing two output IC's and alignment. Standard repair is around $350
Bill W
integrityhomeworx.com
Mar 23, 2011 | Toshiba 57H81 57" Rear Projection...
I own a Samsung Omnia I (SGH-i900) and I accidently reset its hard disk. I started the device once again and it got stuck at the "align screen" setup. I've been trying to align innumerous times...
Hello.
The screen digitizer could be defective.
But, try to align with a pen (if you haven't already). And, try the hard reset, again.
If still a problem and still under warranty, contact Samsung for a screen replacement. This is a common problem for the Omnias.
Hope this helps.
Mar 12, 2011 | Cell Phones
I have a i-mate jama Pocket PC, yesterday it turn off due to low battery. Today I recharge it but it hang on align screen message..... I have tried several times but all in vain...
you should reset your phone.reset code is 1234.after that "align screen" shows
tap the screen at target for few moment untill align screen does not go.it takes several attemp.after align screen disappear time & date setting option appear.set it.after this window will reinstalling.it takes few minutes.after this phone will be started.
Sep 26, 2009 | i-mate JAM Pocket PC
Screen Alignment Not working on SAMSUNG OMNIA
sometime it takes few attempts (once I had to do it 9 times !).
Sep 01, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
After hard reset phone hangs on the align screen
After hard reset i can not calibrate my touch screen. There is appear align screen and... nothing. Can i remove align ...
Aug 20, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
Garmin Nuvi 350 screen iz frozen. reset did not help.
Look near the SN # and press the reset button.
or
with the garmin off, hold down the right bottom of the screen and turn the garmin on, it will then ask you if you want to perform a hard reset. Choose yes and that should fix your problem.
Aug 20, 2009 | Garmin Nuvi 350 Car GPS Receiver
Stuck On Align Screen
This happened to me also. Drain the battery completeley and then do it again. You may have to do it a couple times but it will finally take.
Mar 20, 2008 | T-Mobile MDA
Cant git pass the align screen on my hp2215 ipack
Have you tried a Hard Reset?
This should get you through it but you will lose all of your info.
Information is here:
http://www.coldreset.com/modules.php?name=News&file=article&sid=713
Hope That Helps!
Dec 01, 2007 | Compaq MS Pocket PC 2002
Toshiba (Audiovox) PDA Genio e550c
Always start with the simplest answer first, so start by removing any memory cards, attached devices and cables and resetting it again. If you still have the same problem check the manual for the Hard Reset procedure, it may seem you've already hard reset it by killing your battery but it's worth a try anyway when your getting this kind of issue.
Aug 11, 2007 | Toshiba Genio e550
Computers & Internet Logo
32 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
