LG f1256qd front loading washing machine, during fill up it makes a high pitch squealing
    Genius:
  • Washing Mach... Master
  • 1,461 Answers
Sounds like too high water pressure, could also be dirt in fill valve / faulty valve. Good luck
Posted on Oct 03, 2009
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Kenmore - high pitch noice during spin cycle
Sounds like bearing squeal,providing no leaks or shake leave meantime
Jul 01, 2012 | Kenmore Washing Machines
LG front leader washing machine;high pitch vibration during spin, the house is vibrating with it, we can feel it at the other end of the house, any fix?
You can buy rubber pads at the home center that damper the vibrations.
The high pitch noise could be an object stuck between tubs.
WM2277 service manual
Mar 08, 2010 | LG WM-2277HW Front Load Washer
High pitched noise during hot water only
This problem is usually caused by LOW water pressure going in the washer.
1. Remove hot water hose and flush all debree from water line.
2. Change water filters and you'll be good to go.
GOOD LUCK!
Aug 30, 2009 | LG WM-2277HW Front Load Washer
During fill up, machine makes a high pitch squeal
Have you checked your hoses for a leak? We could pin point which hose was leaking by trying all cold, then all hot...although changing both at the same time and on a routine basis is a great idea.
Aug 18, 2009 | LG WM-2277HW Front Load Washer
LG makes a high pitched sound during water add cycle
Hello.
The high pitched sound is a definite sign that the water valve in use is failing. The squeal is from a restricted water flow through the valve because it is not opening all the way. You will need to choose cold or hot to narrow down which valve is bad and replace that one.
Jul 15, 2009 | Maytag PAV2300 Top Load Washer
High pitched buzz/whine during wash cycle only, spin fine
1) Make sure valve is open all the way 2) some machines have a screen inside of the hose hook up which could be clogged. 3) last check to see if it is the hot or cold by switch your selector switch on your machine to hot then cold. If one of these positions eliminate the noise then the valve in the machine is bad.
May 16, 2009 | Maytag Atlantis MAV8000
Load squeal when it in the agitation cycle.
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
for detailed help with diagrams and step by step instructions click the link http://www.applianceaid.com/washerspinnoise.html
Dec 29, 2008 | Admiral AW22 Top Load Washer
Kenmore front loading HE3 makes knocking sounds during spin cycle
Ours started knocking several months ago and then progressed to a high pitched sound when in the spin cycle. I manually turned the drum and heard and felt a bearing roughness. I lifted the drum assembly and felt a fair amount of play, which I think the initial knocking noise came from. On the sears web site a new rear drum mount cost 293.00. Today we went and bought a LG model wm2455hw at Home depot, on sale until 2/20/08. I couldn't see paying to repair a machine that only lasted four years.
Feb 17, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
283 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
