Question about HP Photosmart M22 Digital Camera
Camera wont turn on
The camera wont turn on and when new batteries are installed both the camera and batteries become warm? Any suggestions anyone?
Canon rebel T3i does not turn on!!
The camera definitely either needs repair or replacement. If it becomes warm to the touch, turn it off immediately and remove the battery, as this could cause a fire.
Apr 17, 2017 | Canon Cameras
My digital camera is Samsung Galaxy, Model no is EK-GC100 and it won't turn on.
When the camera is becoming warm while charging the battery, the battery must be charged. So no need to check for dirty contacts. If you have a multimeter perhaps you can measure the voltage on the battery. While just measuring the voltage, the battery must give a little more then printed on the battery. So when on the battery is printed 3,7 V toy should measure 3.8 or 3.9.
Anything less means the battery is not good.
Now the causes of not switching on. Sometimes the on / off switch is defect. Sometimes the (mini) USB connector is defect and telling the camera, there is still a plug in the camera. It won't switch on. Sometimes the display button must be pushed several times, so the display shows something. And sometimes, the camera is defect.
Carefull investigate the connector and on / off switch, but be aware cameras sometimes become defect, without telling you what is wrong.
I wish you luck.
Nov 10, 2014 | Cameras
Kodak dx7630 got wet and won't come on now.
Please open the camera completely. Take the batteries and SD card out and let it dry in a warm place for longer than 24h. After this please follow the suggestions: 1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher). 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera 3. Turn on your camera without the memory card. (If it works then it?s your memory card that is faulty) There is no frimware accessable online for this model so if above suggestions don't work I'm sorry to say that the unit is officially ruined.
Feb 08, 2010 | Kodak EasyShare DX7630 Digital Camera
Camera doesnt work, got as a gift about 6 months ago and took out
1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable. This camera has an auto lens. Which means it will focus automatically every second, which makes this clicking sound. You can turn this option off: 1: Go into the menu 2: Chose option Cam Settings 3: Switch AUTO focus to single lens and click OK.
Jan 07, 2010 | Kodak EASYSHARE M1063 Digital Camera
I have tried several new batteries,and camera wont turn on.for some reason the batteries and flash button become very warm...
Pls. use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
Here are the steps:
3. Without the memory card,turn on your camera.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 18, 2009 | Kodak Easyshare C813 Digital Camera
New camera bought today will not turn on at all any help?
I do not want to offend anyone but 1. r u using the correct batteries. 2. is the batteries placed correctly inside the camera. 3. is the battery power rating fresh/strong. If u have read and followed the guides in the operating manual and u still have the problem, I strongly suggest u return the camera to the place you bought it for a replacement
May 16, 2009 | Sanyo Xacti VPC-S770 Digital Camera
Camera wont turn on even with new batteries.
I have the same problem as well. I have had my camera for a bout 2 years. The first time this happened was in March 2007. We had been using regular AA batteries, then we decided to go lithium and bamm! The camera started working. I was elited. Then in the beginning of December 2007, it let me take one last picture and then it wouldn't come on again. The lithiums wouldn't even work. We recently took it to a camera shop and they suggested the same as the other posts. I think it would be cheaper just to buy another camera and I think there should be a recall on this camera, if there are so many other customers having the same issue. I really did enjoy it while it lasted, though.
Nov 15, 2007 | Nikon Coolpix 4600 Digital Camera
Camera is completely dead & wont turn on...
Just the same problem here, anyone a sollution???
Sep 18, 2007 | Sony Cyber-Shot DSC-T1 Digital Camera
Olympus digital camera wont turn on
First: thank you, for suggesting battery terminals. It was failing to power on intermittently for some time; the problem became more-and-more frequent until it would not come on at all. Cleaning the terminals saved my camera! Second: for others, let me suggest plain old pencil erasers as a good way to clean electrical contacts (something I learned from HO model railroads as a kid). A vigorous rub with the brand new eraser on the end of a pencil cleaned the battery contacts inside the camera.
Mar 20, 2006 | Olympus Camedia C-350 Digital Camera
HP Photosmart M22 Digital Camera Logo
32 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
