Question about Aiwa Audio Players & Recorders
How to connect an Aiwa LX70 turntable to an Aiwa NSX-AV95 stereo system . The red and the white are fine where does the cable with the plug fit and where does the loose end wire fit ( i thought it was fitted to one of the case screws??)
  • 69 Answers
There should be a small round connector on the rear of the turntable for the mains transformer supply and the loose wire is the earth/ground connector which should be connected to the screw connection on the rear of your amplifier? just loosen the screw ( usually brass or steel ) on the back of the amp, wrap the thin earth wire around the thread making sure it has some exposed copper ie, strip a bit of the cable and then tighten it back up? good luck
Posted on Oct 04, 2009
Aiwa cxna115 - trying to jack-in Belkin stereo cable for Apple IPhone so I can play through stereo speakers. Should I be jacking into video aux on aiwa or the jack next to it? Neither seems like a good...
Hi!
You can play audio equipment like turntable, MD player, mobil phone ( headphone output). You must connect the equipment to the Video/AUX jack, Press Video/AUX then play the connected equipment.
Jan 01, 2013 | Audio Players & Recorders
Aiwa NSX-A-J800 Manual
Retrevo has the manual for the Aiwa NSX-AJ800 Stereo System here: http://www.retrevo.com/support/Aiwa-NSX-AJ800-manual/id/1076dj383/t/2/ . You will need to enter a code to download the pdf.
I hope this helps.
(note you will need Adobe Reader or a similar program to read the file)
Dec 23, 2011 | Aiwa NSX-DS55 CD Shelf System
I want to play my music from my itouch on my Aiwa NSX-TR77 system (because of the speakers) but do not know how to, or if this is even possible to do so?
It is in fact possible... you can play whatever source to whatever sound system with the correct cable... you need a cable with at one end a headphone output connector (compatible with your Itouch) to an input of your choice on the Aiwa system... usually RCA input (RED & WHITE RCA type connectors) at the other end of the cable...
Cheers!
Aug 31, 2011 | Audio Players & Recorders
What type of cord do i need to connect my subwoofer to the aiwa XR-EM20 stero system i bought a adapter and the red and white plug ins fit in my subwoofer but the the other side that supposed to plug into...
The picture is unclear what size that is but they make adapters for RCA-Stereo-Cable-pair-to-single RCA (Y-adapter) or to smaller 3/16" mono or stereo jacks.
The manual in case you need it. No guidance on operating the optional sub.
http://www.docs.sony.com/release/CXLEM20.pdf
Your unnamed sub's manual should have some advice, huh?
May 17, 2011 | Aiwa XR-EM20 CD Shelf System
When plugging in system will light up for a second and shut down what is the problem
aiwa stereos were notorious for having poor solder connections ,especially on their regulators , if you have solder experience i would do a visual look for poor solder
Sep 01, 2010 | Aiwa NSX-AJ20 CD Shelf System
Hello. A dog chewed the falt cable that connects the RX-NAVH80 to the FD-NH80. Is there a replacement cable available anywhere? If so, do you know what the cost might be> Thanks. Russ RussRossRR@aol.com
The company, Aiwa, is defunct. Parts & support, therefore, are zip. I used Gorilla tape to bind the cable ends together. It works as long as there is no movement to the cable. Best solution: time to shop for a new stereo.
Dec 02, 2009 | Aiwa NSX-AVH80 System
Aiwa nsx v900
did you check on speaker wires? Red is +Positive, Black is -Negatives....
Jul 12, 2009 | Aiwa NSX-DS55 CD Shelf System
I NEED A MANUAL FOR AN AIWA STEREO BOOKSHELF SURROUND SOUND SYSTEM CX_NHMA86
Click Sony-Aiwa Support to download instruction manual of NSX-HMA86 (CX-NHMA86) stereo system.
Apr 28, 2009 | Audio Players & Recorders
Audio Connection For GT-USB Turntable
The red/white plugs on the cable are called "RCA jacks", you'll need to get an adapter which will convert the rca jacks into one stereo pin jack to plug into the input jack of your computer
Apr 02, 2008 | Audio Players & Recorders
CX-NAJ20
hopefully u didnt get the male 1/8"-male 1/8" adapter (aka.. headphone-headphone sized jack)
..what u need is the headphone sized jack (that plugs into your ipod) with an end that is RCA stereo (red n white) these go in the back of the stereo...
hook everything up, and voila...
(no need to tell u what u already know, as far as pressin aux.. and all that..)
Oct 01, 2007 | Aiwa NSX-AJ20 CD Shelf System
276 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
